Satnav Mounting
10 posts Started 1 Apr 2015 Last recovered post 9 May 2015 Wayback Machine snapshot 26 Jan 2016
Has anyone fitted a satvav to an eigth generation yet? I'm looking to purchase a Garmin and ideally mount it centrally on the yoke. Does anyone know a way of mounting a satnav to the yoke? Can you use a Ram Ball on the yoke centre nut?
Also the Honda 12 volt accessory kit states that it's mounted under the seat on the Honda webpage. Does anyone know if there's sufficient cable length for the socket to reach by the bars and if the socket itself is waterproof to be out in the open?
Hi
I fitted a tom tom rider V5 to my bike using a ultimate addons 17.5 to 20 mm mount attachment (don't know if there is any mounting difference or ball size for the Garmin). Fits great, I have the socket under the seat and just ran the wire for the GPS attachment to the socket, tidy job, and all the wire is hidden.
Hi
I bought a RAM-mount for pipes, got rid of the u-bolt and put it to the bike using the two bolts that keeps the tank in place at the front. Longer bolts are needed though. They are standard metric.
The RAM-mount for pipes:
http://www.clasohlso...ör-Ram/38-5995
Ram's article no. is RAM-B-213ZU
When mounted, it looks like this:
[image: Attached File]  140926-175905-DSC_0878--.jpg   25.03KB   22 downloads
[image: Attached File]  140926-175914-DSC_0879--.jpg   18.42KB   16 downloads
[image: Attached File]  140926-175927-DSC_0880--.jpg   33.62KB   15 downloads
If you also buy a longer arm, you can use it if you have a tank-bag mounted or so...
[image: Attached File]  140926-181212-DSC_0881--.jpg   29.27KB   16 downloads
It was no problems to get the power cable from the mounting bracket back to the power outlet under the rear seat. I tuck the cable in along/behind the side frame of the bike.
Edit: I'm referreing to the Zümo-cradle's power cable. When no GPS is mounted there is a small rubber cover to protect the power connector on the cradle.
Exactly :fing02:
  • [image: Attached File]  IMAG1375.jpg   38.29KB   19 downloads
I found this pretty good:  http://www.telferizer.com/
Small family business and made in the UK.  Fits into the centre of the top yoke and is very secure (on my 5th Gen).  I expect they will make one for the 8th Gen too.
Thanks for the great tips, hyperlinks and pictures everyone. Very appreciated.
Hi I am in the process of fitting a TomTom Rider to my 8th Gen' VFR and not too sure what i should be wiring the positive to? I guess i can wire the neg to the battery earth terminal, but what about the positive?
Unit came with the standard lead for use with the TomTom
    [image: Attached File]  WP_20150424_001.jpg   31.94KB   12 downloads
On my original tomtom i just had it wired direct to the battery through a fuse, only trouble with that is that it is live all the time, but on my vfr i have the accessory socket under the seat so i just fitted a plug and it switches off with the ignition. So maybe trace the wiring for the socket and connect it there!!.
Is it worth getting the Honda power socket first, and then plugging the Sat Nav into that ?
Or is it just as well to wire the Sat Nav to the battery and a suitable fuse box outlet (like the lights) ?
(Very happy, have taken so long to get round to putting a Sat Nav on the bike that Tom Tom have released a new line of Navs in the meantime !
one should be here any day !! :biggrin: )
Tomtom Rider 40 mounted using a "Telferizer" found at: telferizer dot com
  • Made cup of tea
  • Pulled the plug out of the centre stem, using Swiss Army knife bottle opener attachment
  • Inserted telferizer, and twist, this causes  the rubber bung to expand and grip inside the headtube
  • Mounted Satnav using supplied Ram mount, on the telferizer ball joint.
  • Fed wires through side of fuel tank and black trim panel
  • Removed seat sections
  • Removed battery cover tray
  • Cut supplied SatNav wires as appropriate
  • Appropriate negative wire to negative battery terminal
  • Appropriate positive wire to suitable fuse in fuse box ( I chose headlight fuse) so removed fuse, stuck wire in as appropriate, and put fuse back in.
  • Tidied spare wire as appropriate, and put everything back together.
  • Tested that it powers on and off with the ignition key, which it does,
It does seem a bit low, and have not had to use it yet to find my way around.
[image: Telferizer_zpsgilymh0l.jpg]
[image: Tomtom%20fited_zpsbs1yhqjk.jpg]
End of thread · 10 posts recovered Wayback Machine snapshot 26 Jan 2016
