'99 And '00 Throttle Bodies Differences?
14 posts Started 4 Aug 2015 Last recovered post 5 Aug 2015 Wayback Machine snapshot 25 Aug 2017
Looking at buying a '99 model throttle body. It's a California bike. Are there differences in the California models verses non California bikes? Do the '99's have wax units?
Cheers,
Jeffrey
'99 have a choke cable... no wax units. Not sure if the '99 California models have any additional plumbing for evap canisters and such for emissions
I did a quick check of the parts list for 99 VFR800fi at Huntington Beach Honda and the list included a part, canister (Cali only).
Years ago, I cannot remember why, I asked what a certain model designation among fifth gens, was told it meant: for Cali. That was for a whole set of fiche. Not just one part. Can't find it now.
I think California should be it's own country. :goofy:
Yeah. '00 and '99, any bike, CA or not, you have the wax unit difference vs. fast idle cable.
'98-'99 CA throttle bodies and '98-'99 49-state throttle bodies are the same, just vacuum hose routing differences.
Anyone have a pic of the top of their '99 throttle body? Want to see if a wax unit will bolt on. Really don't want to go through putting a cable on.
I've changed out the darn thermostat twice (hate removing that '00 air box, a ridiculous number of vaccum tubes and digging down to it!). The second time the wax unit got stuck and started acting funny on start-up. It fixed itself in short order, but it had me sweating bullets after buttoning it all back up. And it had me wishing for that cable, which I had heretofor considered silly and old-fashioned!
How about these pics? 99 5th gen with manual fast idle.
[image: post-22267-0-32315800-1438661953.jpg][image: post-22267-0-81538600-1438661946.jpg]
Thank you for the pics. I can see it would take some work to fit a wax unit on it....bummer.
If your swapping out your TB why don't you go for a later 6th gen with the better fuel injectors? Plus it is easier to service with the injectors on top...
I picked up a 2009 TB for ~$100... uses the same injectors as the CBR1000 (4 instead of 8 injectors though :)
I didn't realized that would work on a 5th gen. Has anyone here done this? How much is involved to make it work?
JeffInFranklinTN
RangerScott is the originator of the mod... I haven't installed mine yet, from what I understand the airbox may be slightly different and require an adjustment or swap. I believe the injectors are plug and play and the 5th gen ECU doesn't have any problem driving them.
End of thread · 14 posts recovered Wayback Machine snapshot 25 Aug 2017
