Hopefully a simple question: I want to remove the seat pad from the rear seat cowl on my 3rd gen. I thought it would come off after removing the screw but it seems pretty tight on there. Is there a nack to removing it? There are two black plugs and it looks like the trick might be to squeeze them while pressing them out at the same time. Can anyone confirm? Doesn't seem to want to budge and don't want to break anything...
I've replaced one before. You have to unlock 2 plastic push pin tangs on the pad after removing the screw. A small screw driver with a little pressure does the trick.
Thanks guys - successfully removed with a bit of pressure and squeezing on the plastic tangs... bit embarrassed to have asked such a simple question... must be getting lazy in my old age!
Hey guys, i want to buy a seat cowl for my 93` VFR750, I`ve found one but the color of the pad is grey, my seat is black. Is it possible to paint it black, it is plastic or leather? (i only saw it on pictures) thanx
I actually changed the colour of mine using VHT Vinyl Dye... not sure if it is available worldwide, but did a good job... It worked on the seat, too, so it is pretty tough stuff.
End of thread · 10 posts recoveredWayback Machine snapshot 11 Mar 2016
