As I can hear the chain become stiffer towards the end of every 100 mile ride, I think time to replace the chain/sprockets. This would be for my '97 which is just about stock with exception of DMR suspension and Delvek can. Previous owner did replace the chain, with what I have no idea other than a clip master link was used....UGH!..
I have been wondering what if any advantage is to go down to a 520 chain and lite sprockets or stay with the stock 530 chain and sprockets.
I only do one up riding, usually day trips, have soft side bags and a tank bag and my weight is about 180 lbs.
Asking for good and bad about the 520 conversion, lite vrs stock sprockets...any and all experiences.
If it's a keeper, I'd go with a Honda front because it has the rubber cushion, a Sunstar rear because it's a stock duplicate and a D.I.D 530 nickel chain.
It's a hard rubber plate on each side of the sprocket that softens the striking of the chain link and reduces vibration. Google image it and you'll see it.
King is right: the rubber-damped OEM front sprocket runs alot quieter and a bit smoother than a replacement all-steel one. Sorry i didn't know that first time i needed to replace things.
I am actually looking into a sprocket and chain replacement on my 95 as well, just reached max adjustment on chain so I have a little bit to shop for parts.
Okay, went to order the Sunstar rear sprocket and DID chain from sprocketcenter.com and the price for these two items is $10 less than the price of their "kit" which includes JT front and rear sprockets!
So I could spend the additional $10 and have a spare JT front sprocket and use the JT rear instead of the Sunstar rear....I already purchased an OEM front sprocket.
Is the JT rear sprocket okay to use...or is the Sunstar sprocket "better"???
Well, so is Sunstar. Sunstar is Japanese, and allegedly supplies many of the rubber-damped sprockets to the Japanese manufacturers; JT is focused on the aftermarket and is based in Thailand. I'd probably choose Sunstar over JT for front sprockets (if not Honda OEM), but for rears it's a toss-up.
