HI guys - just wondering if anyone can explain why the coolant in this engine isn't draining away: I would have thought that with the pump hoses and radiator removed, the coolant would have drained out?
- [image: 20160301_125227.jpg]
There are three drain bolts,one by the pump and two under the front exhaust outlets. Did you take those out?
Nice work - thanks Duchy... it'll be the drain bolts by the front headers that I need to take out.
As usual, I should have "RTFI" ! :)
Also important...be sure to re-fit these drain bolts before refilling the cooling system. Go on, ask me how I know....
