3rd Gen rims on a 4th Gen
7 posts Started 27 Apr 2016 Last recovered post 29 Apr 2016 Wayback Machine snapshot 29 Apr 2016
Can anyone here confirm that a third Gen rim set will fit a 4th Gen? I know I've seen the 8 spoke rear on other bikes but I have a third Gen front without rotors and before I spend the money on rotors and powder coating I want to make sure it will fit with my calipers. I know the rotors are a different bolt pattern, but if the diameter is the same when installed and the distance between ( 135.7 mm +/-) is the same then I'm guessing its just a bolt on mod. Otherwise I'll buy a 4th Gen rim (my current one is bent) and powder coat it white.
The first pic is my bike, the second is the bike I had in England last year. The white rims kinda grew on me :)
Thanks, Michael
[image: DSCF1865.JPG]
[image: DSCF2312.JPG]
Wow I really like the white!
1 hour ago, mcrwt644
yes, yes, yes
Thank you!
BTW I was down in Winchester a few weeks ago riding around the area, mostly WV. Stayed at the George Washington hotel downtown. Nice town, wish I had known, I would have bought you a beer
The wheels interchange almost perfectly.  I have just replaced the 4th-gen front wheel on my 3rd-gen with a 3rd-gen front wheel (which was, in fact, the bike's original wheel before I had replaced it with the 4th-gen wheel).  I hope that's clear!
The discs on the 4th-gen wheel are 0.5mm thinner than on the 3rd-gen wheel, but this difference is not noticeable in practice--the brake pistons move accordingly to compensate.
The only issue with the 3rd-gen rear wheel is that it is 0.5" wider, and in theory could fit a wider rear tyre, which could interfere with something on a 4th-gen, but the 180 rear tyre many people fit isn't wide enough to cause any problems.
14 hours ago, JZH
Many thanks for the reply, its good to have personal experience applied to a question. I have already posted a WTB in the temporary Classifieds for 3rd Gen rotors.
I have a Bridgestone S-20's ready to go on the rims once they are PC'ed, a 120/180 combo. I measured my 180 on my UK bike and don't anticipate any problems with clearance on the 4th Gen with this rear. My only problem now is I have been called back to work early and am off across the Atlantic on the ship I work on for who knows how long shortly. So I'll try to have everything ready to go for when I return. And it better not be winter :)
End of thread · 7 posts recovered Wayback Machine snapshot 29 Apr 2016
