Halfway there
8 posts Started 19 Jul 2016 Last recovered post 21 Jul 2016 Wayback Machine snapshot 10 Jul 2017
The rear from my 91 that I had in England last year is finally on my bike here in Maine.
The front is awaiting some bearings and rotors. The rim on the right is a 16" off a CBR900RR. I bought it for my VF1000R but haven't gotten around to doing everything to make it work. Out of curiosity I mounted it on the VFR and it only needs some different spacers to line up. Although I've only got about 20 miles on the new 180/55, I can tell the bike turns in slower than with the 170. If I can't get my head around the new handling I might do the calculations on the rake and trail and try the 16" on the front.
[image: DSCF2819.JPG]
[image: DSCF2817.JPG]
One thing you might want to consider, if you haven't already is tire availability for a 16 inch rim. If you were to raise the forks in the triple clams a little, that'll quicken up your steering. Looks good with the 8 spoke out back!
One day the rims in redslut will be white....
Looks beautiful, but needs moar high mount.
24 minutes ago, Dutchy
Does that mean she'll be a trans-gendered VFR, or will that just require a name chage to the politically incorrect "whiteslut"? My VFR is waaaaay beyond all that!
White or Gold wheels seem to set the red VFRs off! Although the white can be a PITA to keep clean.
Well anything but flat black is a chore
Looking good! Yes, pull the forks through the triples up to an inch, also throw a few thick washers under the rear shock mount to bring up the rear. Don't put too many in though, else the top shock mount will rotate.
End of thread · 8 posts recovered Wayback Machine snapshot 10 Jul 2017
