I was lucky to come across a mint condition Red 2001 with 12k miles. It only had two owners and just got serviced at the dealer. It has Heli Bars, Corbin Gumfighter,Zero Gravity and a Vance and Hines SR2 exhaust.
My plan is to spend $2k to unleash all the factory "built-in" power and plus some well proven and reliable "add-on" power that will not drastically reduce the engine life.
Plus another $1k for the good folks at DMR for suspension upgrades.
it took me about a month to find and buy this bike, another week to get it registered and tagged and another month to find the parts.
The first thing I did was send the Corbin seat back to Corbin to get redone like new. (In the meantime I found a like new OEM seat for $80 on ebay)
Here is a breakdown of how I am spending the $2k on unleashing the engine, plus another $1k at DMr for beefing up the suspension for the added power. (Everything is ordered and on the way)
1. $400- Corbin Seat 2. $150- ECU (Germany) 3. $ 20- OEM Air Box 4. $ 60- K & N Air Filter 5. $500- Staintune (Australia) 6. $350- SS Headers (UK) 7. $300-Power Commander 8. $ 20- O2 Eliminator 9. $120- HealTech Gear Red 10. $160- RDMOTO shorty 11. $595- DMr fork kit 12. $420- DMr CBR shock 13. $350- Clutch Porthole 14. $350- Stator / Rectifier 15. $200- Barnett Clutch Kit First I will modify the OEM air box by cutting away and removing the flapper assembly and install a 2nd Snorkel in its place. (Also unplug the pair valve) My theory is the snorkel is necessary, the flapper is not, so by adding a second snorkel it will add power without compromising the underlying purpose of the airbox design. Next steps: 1) Remove headers & exhaust 2) Install catless full system 3) Remove ECU 4) Install Euro Spec ECU 5) Install gear indicator 6) Install Power Commamder 7) Load Fuel Map file Start bike..... 8) Install DMr fork kit 9) Install DMr CBR shock Go for test ride.... 10) Install Barnett Clutch 11) Install Thurn Motorsport clutch case window 12) Install Thurn upgraded Stator, with Rectifier relocation mount kit. 13) Install Thurn Rear Hub Cover 15) Install RDMOTO short reach clutch and brake levers.[image: IMG_4140.JPG]
[image: IMG_4160.JPG]
[image: IMG_4161.JPG]
[image: IMG_4162.JPG]
[image: IMG_4163.JPG]
[image: IMG_4165.JPG]
[image: IMG_4166.JPG]
[image: IMG_4167.JPG]
[image: IMG_4168.JPG]
IMG_4171.MOV
[image: IMG_4172.JPG]
[image: IMG_4174.JPG]
[image: IMG_4176.JPG]
[image: IMG_4177.JPG]
[image: IMG_4175.JPG]
Nov 5 Update:
Now that the headers are installed, the double snorkel (no flapper)air box mod with a fresh K & N filter and adding 3oz Lucus octane boost every fill up. Still waiting on Euro ECU to show up before I do any new fuel mappings. DMr suspension kit has shipped. Also waiting on 2nd engine clutch cover. First job is to switch out the stator with a $50- el cheapie china stator so I can get my OEM over to Gerhard, along with the engine case clutch cover. As far as riding the bike all week, its starting to really open up 😄😃
IMG_4198.MOV
[image: IMG_4206.JPG]
[image: IMG_4207.JPG]
IMG_4213.MOV
[image: IMG_4219.JPG]
[image: IMG_4230.JPG]
[image: IMG_4233.JPG]
[image: IMG_4231.JPG]
[image: IMG_4232.JPG]
[image: IMG_4234.JPG]
[image: IMG_4237.JPG]
[image: IMG_4238.JPG]
[image: IMG_4239.JPG]
[image: IMG_4243.JPG]
