As part of my hybird restoration (5th gen engine into 6th gen chassis with 6th gen ECU), I need to fit a Power Commander to dial out the VTEC behaviour etc. This has been done successfully in the UK with just the standard maps, although when I fit a different exhaust, I intend to get a custom map sorted.
My question is do I really need a PCV for the VTEC, or will a PC3 suffice?
Are you asking whether a PCIII will "dial out the VTEC behaviour" in a 6th Gen engine? The answer is absolutely it will. That's what I am using with a custom map. If you want to see the dyno charts, let me know and I'll PM you.
An 1980's TV commercial for a toilet cleaner (called water closet duck) had a punch line that said "We from WC Duck advise you to use WC Duck".
Now synonymous for "would a chef say his food tastes awful?"
I assume you mean well candy, but with your sign line, it does look a bit biased. Look, for you will have the dyno chart to prove your point. No offense meant.
If you are fitting a 5th gen engine into a 6th gen chassis, there is no VTEC. The motor simply does not have it, so you don't need to do anything. You'll just need to use a 5th gen ECU.
Thanks for the timely feedback guys - your support is much appreciated.
The Fi ECU versus VTEC ECU is a moot point - I think I'm correct in saying that the Fi ECU would require the Fi harness to work correctly - this would require separate plugs and coils from the Fi, as opposed to the VTEC's coil-on-plugs, which is another factor to consider. A loom change may require other modifications; perhaps to the various light connections - I'm not sure.
An ECU change would also require a HISS change, unless I went for a pre-HISS model, which could complicate insurance matters. When I decided whether to take the plunge and retain the VTEC ECU or, I recognised that both options had its pros and cons - I've pretty much committed myself to retaining the VTEC ECU now, and fitting a PC to adjust the fuelling accordingly, especially as it's likely that I'll fit a different set of cans at a later date.
Both options probably cost about the same, given the additional parts that need to be purchased/fabricated.
I don't think the firing order is different - if it is, something is awry with the bikes that have already had this conversion carried out...
I suppose my question should have been 'does a PCIII work with a VTEC ECU?' The feedback thus far suggests that it will, so that's what I'm going to order. Thanks again folks :)
Let us know how it goes. To me fitting the 5th gen engine has traditionally been done by fitting the 5th gen ecu/loom. Honda is allergic to change so maybe all the sensor connectors/etc are all the same.
Edit: I really don't see how this is going to work by slapping a PC3 on in hopes to fully disable VTEC via a tune. The PC3 only does fuel mapping changes, not VTEC engagement. I don't think you can say "don't turn on the extra valves here".
Are you aware of Mark (from IoM) on the Bikersoracle site? He did the 5th gen into 6th gen swap several years ago and started a thread about it. No need to re-invent the cam gear, so to speak...
I am thanks - he passed me his number just before Christmas - I've been working so doggedly on the bike and returning to work, I've yet to get back to him! I'm pretty much following his approach - if you can't trust a pilot, who can you trust? ;-)
End of thread · 20 posts recoveredWayback Machine snapshot 8 Jul 2017
