Yeah, I'm coming late to this discussion but John (JZH) shared a Honda press document with the technical details of the 2002 VTec VFR. It included this discussion of the updates to the linked braking system:
Newly Revised ‘Sports’ Dual Combined Brake System
Equipped with one of the most advanced and compact versions of Honda’s
brake control-assisting Dual Combined Brake Systems, the VFR delivers a
confidence-inspiring balance of brake operation that brings it to a quick and
sure stop with an optimal balance of front and rear braking forces, whether the
rider uses both the hand and foot brake levers or only one of the two.
Since giving the VFR a more sporty balance of performance was one of the
foremost goals of its total redesign, attention was also paid to giving its
advanced brake system a more sporty and aggressive package of braking
characteristics. This was achieved, through careful evaluation, by re-routing
the lines controlling its calliper piston actions.
Where nearly all Dual Combined Brake Systems till now have the hand
brake lever controlling the two outer pistons of both front 3-piston callipers,
the new VFR’s front brake lever operates the two outer pistons of the left-side
front calliper and all three pistons of the right-side calliper, as well as the
centre piston of the rear brake calliper (by way of the secondary master
cylinder), resulting in more front-oriented braking response that feels more
closely matched to the aggressively responsive Super Sport road machine that
the VFR has always been.
The foot brake pedal that previously actuated the two outer pistons of the
rear brake calliper and both centre pistons of the front callipers now actuates
the same two rear brake calliper pistons, but only the one centre pistonof the
left front calliper. This revised balance of braking force is administered
through a direct-side proportional control valve (PCV) mounted inline
between the foot brake master cylinder and the rear calliper. During light
applications of the foot brake, most of the actual braking force is applied at the
rear wheel, with only the slightest amount of front brake input at the one leftside
calliper providing a steadying influence on the balance of front and rear
brake control without causing unsettling shifts of weight and its related frontend
dive. However, this balance of operation changes in response to strong
pedal operation, in which case the system adjusts for an optimal balance of
front and rear braking forces.
As in other Dual Combined Brake Systems, the compact secondary master
cylinder integrated into the left-side calliper’s pivoting mount increases rear
calliper brake pressure through a servo-side PCV as its own braking forces
increase in response to front brake lever actuation. This results in a smoothly
progressive application of combined braking forces that starts with greater
emphasis on the front brakes and gradually but firmly applies a balancing
amount of rear braking force whenever the situation calls for it.
Taken together, these two brake operation scenarios provide a more
aggressive distribution of braking forces that both enhances braking
confidence for a wider range of riders and skill levels, and provides a more
familiar combination of braking characteristics for hard-core riders who insist
that their own braking skills are second to none.
