I would imagine the titanium bolt is stronger, hence being more sleek. But I'm a hack of a mechanic and have a history of bad things happening with brake caliper bolts (on a friend's bike) so don't take my word for it! I'm sure someone with more experience will be by shortly.
Use a washer perhaps? More surface area could never hurt. But more importantly, titanium to aluminum, use anti seize. I forget but research if I remember correctly there is a specific kind for titanium to aluminum connection. I know because I also ride bicycles and had a titanium frame once and the bottom bracket shells are usually aluminum with fine threads and needed to be coated with ti specific grease.
OEM m8 caliper bolts sport special 16mm heads for maximum strength so if you wish to stay within Honda's specification when upgrading to Titanium hardware then all you got to do is find the corresponding 16mm head m8 special caliper bolts complete with predrilled safety wire holes... Safety wire is insurance for the required torque of 30nm (22ft pds)
Where are those from? Not too many people make Titanium metric socket caps, I'd imagine. The ones I got had cut threads, which I wouldn't really trust to hold my calipers on. The threads having been cut (rather than rolled) may be okay, but it just suggests that the manufacturing was done on the cheap.
Like all metal materials, I would want to know the exact grade of Titanium before I use Ti fasteners for calipers. - Generally speaking rolled threads are stronger than cut threads...
The most used Titanium (6al4v) is significantly stronger than the
commonly used grades of steels found in OEM fasteners... what is
desirable about titanium fasteners are its remarkable strength given
its weight... like if you Ti out every fastener you'll reduce about
8 pounds off your bikes burden...
Mr.RC45's OEM steel fasteners that were replaced with Titanium...
I've asked the NL based shop what grade they source for the M10 and M8 bolts.
Will hold off for now.
weigth saving is not so much my aim, but making them resist looking grotty is.... for she will live the life of a "normal" bike. not just summer days. and she's parked outside...
