LZR-17 _ VFR800 PROJECT _ V4R
26 posts Started 3 Mar 2017 Last recovered post 9 Mar 2017 Wayback Machine snapshot 26 Aug 2017
    LZR-17s - VFR800 PROJECT - V4R
PARTS =
1. 2003 Honda VFR800 = Frame & Bracket
2. 2006 Honda VFR800 = Gas Tank.
3. 2014 Suzuki GSX-R600/750 =
    A. SHOWA BPFs (Gold) - USD Forks.
    B. Rotors.
    C. Front Fender & Rim.
    D. Calipers (Brembos).
4. 2014 Honda VFR800 = Exhaust / Headers.
5. 2004 Honda CBR954 = Triple Trees. Lower Clamp & Stem (NEW!)
6. 2016 HoHey-Design = Custom Upper Triple Clamp.
7. 2006 Honda CBR600RR = Bodywork/Subframe/Fairings.
8. 2011 Kawasaki ZX-10R = SHOWA BPFs. ( Alternate Front Forks ).
9. Michelin Pilot Road 4S = Tires.
PROJECT:
1. Tear Down = Leave motor on a stand. Unbolt everything.
    - Paint Motor = Gloss Black.
2. Powdercoat = Frame & Bracket = Gloss Black
    - For rear sets - still need. (Ebay or Custom).
3. SSSA = Powdercoat or Carbon Fiber Cover.
    - Hide Brake lines. Custom Chain Guard.
4. Front Suspension = SHOWA BPFs (Big Piston Forks)
    - 2014 Suzuki GSX-R600/750 (Gold)
    - 2011 Kawasaki ZX-10R (Black/Dark Green). (Alt).
    - GSX-R =  " , ZX-10R =  " (VFR Match).
5. Front End = 2014 Suzuki GSX-R600/750 -
    - Front Rim
    - Front Fender
    - Rotors
    - Brembo Calipers (Need)
6. Triple Trees & Clamps =
    - CBR954 Lower Clamp & Steering Stem (new-ebay).
    - Custom CBR954 Upper Clamp. Run Bars or Clip-Ons.
7. Rear Suspension = IDK
8. Bodywork / Fairings / Subframe =
    - 2006 Honda CBR600RR (IDK)
    - Custom. Front to Back. Top to Bottom. (YES).
    - Custom Glovebox - on gas tank (Carbon-Fiber).
9. Exhaust =
    - 2014 Honda VFR800 - Headers. Jet-Hot (Silver/Polished)
    - Muffler - Kawasaki Z1000.
10. Electronics =
    - 1999 Honda VFR800 = Dash (Speedo/Tach/Etc).
    - Samsung Tablet - GPS/MUSIC/ETC.
    - Neutrino Black Box (and/or/both) Fuze-Block.
    - Battery-Tender (LiPo Style).
[image: MOTO-17_VFR800-17_020245-EM.jpg]
[image: MOTO-17_VFR800-17_020309-M.jpg]
[image: MOTO-17_VFR800-17_020345-M.jpg]
[image: MOTO-17_VFR800-17_020454-MC.jpg]
[image: MOTO-17_VFR800-17_020502-MC.jpg]
[image: MOTO-17_VFR800-17_020529-MC.jpg]
[image: MOTO-17_VFR800-17_020703-MC.jpg]
[image: MOTO-17_VFR800-17_020744-MC.jpg]
Why the 2014 header? Because you want to use the 2014 radiators?
Sent from my Nexus 6 using Tapatalk
Yeah, I'm using front mounted radiators. Bigger oil cooler with a fan as well.
I'm going to try and attach a set of forks in the rear.
No, I bought the ZX-10R forks supposedly undamaged. Not the case, and only lucked out and got a 3rd ZX-10R fork with the complete opposite part damaged. The ZX-10Rs are exactly the same length as the VFRs. I bid on the GSX-Rs not expecting to win and got them really cheap. They are only about a 1/2 short. Didn't such a radical drop top triple clamp, but it was so affordable compared to other ones, I decided to go with it. And like how beefy it is. $250 compared to $400-$1000. I want to try and run bars.
I also get to run Brembo Monobloc Calipers. Which I lucked out on as well.
Frame goes to powdercoating company this coming week of March 6th. Gloss Black. Cost? Free.
Swing Arm is going to have a carbon-fiber over it similar to the BMW S1000RR Superbikes. Will only look trick.
Will also incorporate a chain guard.
The motor is going to be painted Gloss Black as well. A little nervous about tearing everything down to its basics.
Bought a bunch of totes from Ollies for storage/organization.
Paint for motor =
1. POR-15 method of $50/qt paint and three step process.
2. Duracoat?
Jet Hot = Headers & Rims. In there polished form.
When IDK. Cost =f $200-$300.
Header needs cat cut off. An adapter or whatever to attach a muffler.
Am using a Kawasaki Muffler to fit in place of cat. Or a Supertrapp Universal Muffler.
Though looking at Motorcycle Mufflers, They are so simple. Would rather gut the cat, convert to muffler. Build
a box to make it look better.
Ever since I've changed at least half my gearing, I've been happy with performance. But the Bio-Blade VFR only had the heads/ports polished and a new cam, and it jumped to 120HP. What cams? IDK.
I'm going to attempt a ram-air build. Could add 10HP. Carbon-Fiber.
The biggest hurdle is the bodywork/fairings. Im going to build from scratch using Kydex & Carbon-Fiber.
But I might have to carve the forms out of foam or clay.
Rear subframe & Brackets will be custom.
The brackets connecting the rear subframe will be CNC machined.
Building a prototype now. Make a drawing. Get the parts made.
The bio blade was tuned to run on ethanol= custom fuel & ignition mapping. Ethanol has very high effective octane, allowing for very aggressive ignition mapping. Custom cams can be reground by any competent cam company. Both Mohawk and Highsidenz had their cams reground to rc45 plus a little more specs. The heads were ported and polished, plus milled for some added compression. Don't forget the bioblade had a full custom akrapovic exhaust. To make the power you are taking about, you are going to need a performance header (35mm inner diameter primaries), not just a factory header with the cat cut off.
Make sure you measure the ZX-10R forks carefully for tube diameter. The CBR954RR triples are 50mm upper/54mm lower. I bought a 2011 ZX-10R fork to measure it hoping to use them in my 954 triples, and I think they were 50mm upper/55mm lower. It would be bad to force the lower triple onto the 55mm fork...
Good luck!
Lacy
PanzerAstridBears, ‎3‎/‎4‎/‎2017 at 5:30 AM
Just going to get some Fork extenders then?  That should easily get you there.
CandyRedRC46, ‎3‎/‎5‎/‎2017 at 6:21 AM
Full Akra system?  Why go that far when a performance system can be had for so cheap from ebay?  ;)
Haha oh man, no, there are no performance full systems on eBay. Okay just saw the wink face. Lol
Speaking of performance full systems.
Candy how am I suppose to buy these when you are posting them on every thread here
Lol I am an equal opportunity employer.
Is that a Mach Z in the background of one of those first photos?  Is that in your garage?
Nice build BTW.
Let me say this first off.
Thanks for any input, suggestions or corrections that you post. I need the help.
I thought I knew everything, till I was fired and shown the door. Ha.
Yes, that is a Mach Z1000 in the background.
Just got it. What a beast! Notorious for exploding engines though.
It needs to go the local dealership to read the BUD (or something).
And my VFR is taking priority. Plus my SKI-DOO Home boys are going back
to Canada again, so no help there.
Exhaust? I didnt know that a performance exhaust existed.
I've been looking but coming up empty. Guess I should checked
on VFRD more. So IDK.
Performance/Mods/HP? My cousin keeps me in check.
Ever since I changed the gearing I've been real happy with the
performance. Especially when I REV her up. And I try to keep reminding
myself it's fast enough to go to jail.
Here's where I do need some help.
Everything I'm going to need to run the 954 stem. Bearings, etc ...
And I need to change out my frictions and steels.
Was planning on OEM Honda. Is that what everyone else
uses? Or Barnetts. I've always tried to use OEM when it comes to
Honda. Always fit better, work better. But clutch plates, IDK.
I finally bought my Brembo calipers.
And I'm ordering bolts for the front end from pro bolt usa.
Progress has been slower than I like, but I just got back from
Phoenix, AZ and fun in the sun. And freezing to death at night.
A close friend of mine was murdered in PHX last year, and seeing everyone and dealing with it all
felt like a 2x4 to the side of my head.
Sorry to hear about your friend.
I replaced my clutch frictions and springs a few years ago. When I took out the old ones they were just over 92,250 miles. That's a lot, but they still looked fine. I measured them singly and as a stack, and couldn't see an appreciable difference. Same with springs. I replaced with Honda parts because there was nothing to suggest the OE parts were not up to the task. Steels were completely fine.
I only replaced them because I had scraped up the cover years ago and was finally going to put on a new one.
I used to work part time in a bike shop that dealt with a lot of streetbike squids, and I've seen worn out friction plates and blued steels. Maybe if you're out doing wheelies and burn outs every week at bike night you'd need to replace them, but if not you may not need anything.
17 hours ago, PanzerAstridBears
The only real performance headers made for the VFR800 were made by Two Brothers Racing and Erion Racing about 15 years ago. Not very many were made and they are highly sought after. Nevertheless, they do pop up for sale once or twice a year and when they do, its a big deal. I had to troll the forums for a few years before I found a set and adapted them to my sixth gen.
CBR929 / 954 / RC51 / VFR800 etc all use the same bearings. I am running 929 triples and factory bearings right now.
I would stick with OEM frictions and steels and Barnett springs. If you have a strong grip, even heavier 99 pound Barnett springs work excellent, but the drop in Barnetts are still a slight improvement over stock.
End of thread · 26 posts recovered Wayback Machine snapshot 26 Aug 2017
