Can you use a Vfr800 front wheel on a 94 VFR?? And if so what mods are needed, seems like the rotors sit approx 1/4" too wide ! I have a polished VFR 800 front wheel that I'd like to use along with a 5th gen rear wheel that I'd like to use for a set of stickier tires on my 94, that way I can have a set of wheels with Dunlop Roadsmarts and another set with Q3's or Pilot Powers! Thanks PS already notched the rear! Got good valves and springs in the forks and a Penske rear shock!
VFR 800 front wheel on a 4th gen ???
I'm virtually positive that the front end needs to be changed out. I know for a fact it won't work from a 3rd to 4th gen. Clearances are different and I'm nearly certain the same is true for a 4th to 5th gen.
4 hours ago, trjermCan you use a Vfr800 front wheel on a 94 VFR?? And if so what mods are needed, seems like the rotors sit approx 1/4" too wide ! I
Yes, the rotor spacing is too wide even though the rotor offset is the same, IIRC.
Custom rotors with reduced offset ? $$$ plus I'm not sure there would be enough clearance for the calipers.
Machining the mounting bosses on the wheel ? I doubt that there is enough "meat" for that, though. :mellow:
I'm afraid there is no practical / cost effective alternative to getting the correct front wheel. :unsure:
RC46 triples, axle and front fender might do it, I'd guess. Measure first!
