Next time you have your bodywork off, take a look at the well nuts that hold your bodywork together - Honda calls these 'cowl setting nuts'. This pertains to any VFR that uses cowl setting nuts to fasten body panels together - the older the VFR, the more important it is that its nuts get a thorough inspection.
I wondered why a couple of the bolt holes in the upper cowl of my 5th gen had cracks at their edges. These are the row of three holes where pan screws go into well nuts in the lower cowl. The PO was very careful and I have not run across any examples of fasteners being overtorqued. At my second oil change, I notice that many of the cowl setting nuts - perhaps original parts - had squished up through their holes over time, creating bulges between the faring panels that they joined. The pressure of the bulges acted like wedges up under the outer panels of the upper cowl, and the pressure of the pan screw was applied to the wedge from the outer side of the upper cowl, resulting in cracks.
Just a heads up as you service your VFR - check your nuts [cowl setting nuts]. New cowl setting nuts have my fairings lying flat and happy against each other.
Prevent cracks in bodywork
3 posts Started 10 Jun 2017 Last recovered post 12 Jun 2017 Wayback Machine snapshot 25 Aug 2017
Good to know. I will be checking mine as I am due to for a 50k aka old bike tear down.
Cool Jon. If you need well nuts and are uncomfortable with the $5ish dineros our dear Honda charges, Duc2V4 shares the following:
"For those wanting to replace your well nuts without going bankrupt, I found that these two models work great for the 5 Gen. The main fastener well nuts also work with the 6 Gen.
Main fastener well nuts: http://www.clipsandfasteners.com/Well_Nut_M5_8_665_Length_p/a16248.htm
Upper front (on the front sub-frame) and rear cowl (on the rear sub-frame) fastener well nuts: http://www.clipsandfasteners.com/Well_Nut_M5_8_554_Length_p/a16242.htm"
End of thread · 3 posts recovered Wayback Machine snapshot 25 Aug 2017
