Slow speed clicking
11 posts Started 11 Jun 2017 Last recovered post 13 Jun 2017 Wayback Machine snapshot 11 Sep 2017
I've just noticed a click or a clunk coming from the bike at slow speeds in 1st gear.  I normally don't notice it as I have music on but I've just been away for the weekend with the missus on the back and she described it as a clicking sound coming from the front.  From my position it sounds to come from the rear and is a cross between a click and a clunk.  It doesn't speed up so probably not chain related.  As the revs pick up it seems to go away but the wind and engine noise could be masking it.  I can't recreate the noise with the bike on the centre stand so I'm at a lose to what could be causing it.  Any ideas anyone?
I've just had a thought, could it be the cam chain tensioners?
Out of curiosity does it sound like a Geiger counter?
Sent from my SM-N910W8 using Tapatalk
More like the old train time boards you used to get in stations that rolled over with a clicking sound but a bit slower.
Tight link on drive chain?
Someone somewhere else thinks it could be the centre stand and I did have the end can off on Friday for a new tyre.  I'll check at lunch time to see if it's hitting the rubber buffer!
16 hours ago, StubyDoo
Wouldn't have thought so, CCT noise is most obvious at idle and disappears when you move off and the chain slack is taken up.
Check both tyres for nails or stones, they make a nice regular noise, but get lost in the cacophony as speed increases !
The clamp for the link pipe on the exhaust had rotated when I took the wheel off and was fouling the stand.  Two minute job tonight to rotate it slightly.
Of all the things... still, glad it was so painless in the end!
Indeed.  A very cheap fix :)
End of thread · 11 posts recovered Wayback Machine snapshot 11 Sep 2017
