I posted a bit of a blurb about these over on VFR World, so figured I'd post here as well...
I do a bit of buying our of Japan through the Yahoo auctions. Got my SP1 wheel and rotors from there, and a few farkles for my Liberty (Legacy) wagon.
Anyway, I occasionally look for "spares" for the VFR, and sometimes the search will return results for RC49 bikes.
For those that don;t know, these are ostensibly 5th-gen bikes, modified (at factory) for Police use. They were made from 2001-2008 (according to the Wiki page I read), and have a few interesting features.
1) They do not run linked brakes.
2) They DO run ABS
3) The rear rotor is ventilated (think mid-80s FJ1100 for a similar style of rotor).
4) Completely bespoke instrument cluster, to show bike and target speeds and a pile of other crap.
5) Cut outs in front fairing etc. for lights etc.
6) 3-row oil cooler.(I mention this as I saw one advertised and have purchased it, along with the lines, in the hope that it will be a bolt in (slight) cooling upgrade on my bike.)
7) Probably a fair bit of other stuff as well. (The ECU, for example, has three plugs running into it, rather than the two a standard 5th gen would have...presumably for the ABS...?)
I saw in another thread where someone discussed retro-fitting ABS on to a non-ABS 6th Gen. Must admit, I thought (for about 5 seconds, give or take), about purchasing enough RC49 stuff to do that to my bike. Even without seeing that other thread, the conclusion I quickly reached was that you would probably need to purchase an entire bike, in order to strip and retrofit all of the ABS crap to it. Not only that, I wouldn't give up the SP2 front end anyway, so it was a non-starter.
Still, interesting to think that they were made until 2008 (Then replaced with a Police-spec CB1300).Might make for a few extra spares for the 5th Gens for at least some parts. BTW, the designation they carry is VFR800P.
