So figured i would post up a thread about what i got up to at the weekend. that is, unexpectedly fitting a VFR1200 shock to my 5th gen.
I had been looking for a budget upgrade to the 55k mile rear shock on my VFR, and looking at the numbers i figured that a VFR1200 shock would be a pretty good match. I managed to snag a VFR1200 shock off ebay a couple of months back for 70£ (mint condition too, bargain!) and i was planning to do a complete overhaul of the bikes suspension, with VFR1200 front end, and the rear shock to match, i have been gathering parts and planning the work to commence towards the end of April
Then on Saturday, while recommissioning my SV650 from its winter hibernation, my VFR decided it was jealous, and decided to spill its rear shock guts all over the floor when i pulled it out of the shed, so after giving the SV its once over. I spent the rest of the day removing the rear shock, and mocking up the VFR1200 shock.
side by side, the shock is about 4mm shorter:
Apologies now for the lack of pictures from here, but i was intent on getting it fitted before it went full dark!
installing it "out of the box" as it were, the pre-load adjustment platform banjo makes contact with the exhaust header, so that wasn't going to work. rotating the shock through 180deg fixed that issue, but brought about 2 more.
1. the rebound adjustment at the bottom of the shock now faced inwards, towards the rear brake pedal and above the exhaust collector, this makes it not easily accessible for making adjustments.
2. the hose coming out of the preload adjuster now pointed forwards, which meant there was nowhere to mount the adjustment body.
so, with the top mount clamped up in a vice i rotated the damper portion of the shock 180deg(it will spin freely, but obviously has a large spring pressing against it, a large adjustable spanner assisted), so that the rebound adjuster now faced the same way as the outlet of the pre-load platform.
then, i cracked off the banjo bolt going into the preload adjustment platform (just enough to allow me to forcably rotate the union, but not enough that anything leaked) and rotated that pipe 180deg, so when fitted it now exits towards the back of the bike, i also did the same to the banjo going into the adjustment knob, so that the mounting tab sat pointing upwards this will let me get a simple bracket to bolt the adjuster knob to the bottom of the subframe.
I still have to fabricate the bracket to hold the adjustment knob, for now its just cable tied to the subframe. and i have ordered a spacer to fit between the clevis and frame to make up for the 4mm difference in length.
it was dark when i finished, but i will get some pictures today when I'm home
i have not been out for a ride on it yet, but sitting on it (jumping up an down on it too), it feels a billion times better, it will be amusing to see how the ancient front end compares to the new rear out on the road, needless to say i cannot wait to get the front end sorted as well.
