What lighter weight front wheel would you recommend to replace my current stock 5th/6th gen front wheel?
On my 2001 5th gen, I have DMr F4i forks, RC51 SP2 calipers, and stock 5th/6th gen front wheel/rotors. I have no problem with this setup - I love it. I am shopping for a second set of wheels, so for the second set, I’m looking for a front wheel option that weighs less than the stock wheel I’m currently using.
My budget is $400 for a front wheel and front rotors ($400 does not include bearings, dust seals, custom spacers etc, which are separate budget items). Donor candidates for a lighter front wheel could be CBR600RR, CBR600F4 (1999-2000), CBR929/954RR, CBR1000RR, Ducati 848/1098, or any other workable solution.
I feel certain the front brake rotor diameter/offset/width, axle diameter, and axle spacer data I seek is on our website in easy-to-extract spreadsheet form, but I have failed to unearth it.
This thread seemed perfect, but no longer functions:
Thanks Oz and Rush. I’ll check into the F4/F4i front wheel options. I’ve got an F4i axle and spacers left from my front end conversion - thought I’d need them w the F4i forks, but only the 5th gen axle and spacers fit.
I have the F4i wheel, its only 12oz less them the VFR wheel. Keef has a 848 wheel, I don't know the weight. I would save another 400 and get a OZ F4I forged alloy wheel. As you get weights and fitment info please keep us informed, Im wanting something lighter as well
According to Keef the cast 848 is only 1.6 oz lighter than the plug and play F4i... now if you go forged your dropping 2 more pounds of unsprung rotating mass :wheel:
