I thought I'd start a thread to document my efforts to give my 'new to me' red 1998 5th gen a bit of a refresh and to address any deferred maintenance items on this 20yr old motorcycle. A little recap: I picked the bike up last September from it's second owner, it had been serviced at the local Honda dealer throughout it's life, had a good history, and presented and ran well. The price was right and I managed to put about 1000 miles on it after a checking it over and installing new tires (Bridgetstone T30 evo), and a Battery Tender brand lithium ion battery.
Here is where it all started for me, my first ride at 12 years old:
[image: 84806-yamaha-razz-riva-50cc.jpg?dl=0]
It isn't hard for me to see how I ended up where I have or why my preferences are what they are. Here is the VFR shortly after bringing her home:
[image: 20170929_142716.jpg?dl=0]
LiPo batteries are truly tiny compared to traditional lead acid or AGM. I picked this up from Walmart for a bit under $100 (ordered online and picked up in store):
[image: 20171002_175256.jpg?dl=0]
A few things I noticed after riding this bike for a few months: The engine ran well, fuel economy was ok but could likely be better, suspension is quite under-sprung for my weight (240lbs), and the bike was running cool and not getting up to temp, and the regulator was not putting out the correct voltage at RPM's above idle. It started reliably but didn't fire immediately like a well tuned bike should. Over the winter I also noticed a couple of drops of coolant under the bike at one point. After a bit of research I realized that a thermostat replacement meant digging in/past quite a lot of other things/systems, I decided I would address a bunch of stuff in one go this spring.
Things I have done already (I will try to include some pics and info on these items also later on):
- new rubber, Bridgestone T30 evos
- new brake pads front and rear, EBC HH all around
- new headlight bulbs - I am running some LED units, but am going to also try some Osram NightBreaker Laser H4's soon (on hand) also
- clear indicator housings with LED switchbacks
- clear, LED tail light
- LED instrument panel swap - currently blue ( I tried red and purple also, they weren't bright enough)
The to-do list: completed items
- new tstat, replace cooling hoses and clamps, replace water joint o rings, clean/inspect/flush radiators and water pump
- new plugs, COP mod
- PAIR delete
- injector cleaning and flow testing
- new vacuum hoses for the throttle bodies
- refinish or replace exhaust headers, don't forget the new donut gaskets
- 520 chain conversion, +2 teeth rear sprocket
- new regulator and wiring (thanks to roadstercycle.com)
- new braided stainless brake lines, brake system flush, caliper rebuilds if necessary
- new braided stainless clutch line, slave cylinder flush and inspection
- fuel tank inspection, fuel filter replacement
- general cleaning and inspection of the seldom seen areas of the bike and engine, inspection/cleaning/lubing all electrical connections
- replace suspension with parts valved correctly for my weight and riding style (currently holding out to see what Jamie's in-house rear shocks look like)
Digging in / Inspiration / Resources: Much thanks to this site and VFRWorld and members for covering most of these items already in detail. I have a factory manual that has been invaluable as well. Big shout out to user GreninDenver for his excellent tear down & rebuild thread.
