Just my luck. T-Rex no cut frame slider FAIL
29 posts Started 16 Jan 2019 Last recovered post 8 Feb 2019 Wayback Machine snapshot 22 Aug 2019
NYC is probably the ultimate bike protection proving ground. Getting out of my Manhattan office today and noticed that someone moved my bike. By moved I mean from vertical to horizontal and then back to vertical. Looks like the frame sliders I got from T-Rex don't protect. Time to shop for a new mid-fairing...
[image: IMG_20190115_203215.jpg]
[image: IMG_20190115_203224.jpg]
[image: IMG_20190115_203235.jpg]
Oh no, that sux man 😐
Did the bolts break?
That looks as if the thread has been ripped out. Eek.
Not good 😪
Poor show indeed.
I guess I'll cross those off the list of future purchases. Sorry it had to happen to you, though, mate. That sucks a fat one.
I'm in contact with the manufacturer. It might be just a one off production flaw. We'll see what they say
Ouch - keep us posted, this is actually my next planned mod...    I know they will say, it would have been much worse without, but if no real advantage to having them, not sure if I will still buy.
On another note - I actually saw a guy back into, knock down, and then drive partially up the side of a bike outside a burger joint.   I pulled out my phone and recorded him lifting it back up and he got to the exit before I stepped in front and told him it was all on camera.   He said he was just going to go to the back of the restaurant, but this guy was bailing had I not caught him.   :)
Here's a clearer picture. Bolt ripped in half. Pretty sure that's not supposed to happen.
[image: IMG_20190116_165749.jpg]
Bummer that happened Rollos, thanks for sharing!
That's heartbreaking Rollos and ya can't even blame yourself, some other prick did it for you. I just hope you might have insurance to cover the damage and repair, good luck hope your pride and joy is fully repaired ASAP.
8 hours ago, Rollos
that is poor engineering
Is there any chance someone actually hit the bike with a car? Not knowing where it was parked I am just guessing. Interested though as I have a set of these fitted myself and am hoping that they will perform better than this in a simple falling over situation. Hope T-Rex come through for you though.
I've posted before that I've 'tested' these on gravel at 10-15mph and they worked exactly as you'd hope they would, I needed a new slider obviously but the mount didn't move at all (and there's only a couple of mm between it and the corner of the fairing, as you know). It'll be interesting to see whet T-Rex say about yours.
[image: 2017-07-14 damage_2.JPG]
You can easily fix that fairing with plastic welding or ABS glue...but if you don't have bandwidth to tackle it...new fairing will do obviously.
Matt
Wonder if you can see what grade those bolts are?
My guess would be that they are probably Grade 2, it wouldn't be that big of a deal to upgrade to Grade 8 bolts.
That bike must have been hit with considerable force, mine has been knocked over and sustained as much damage as fatshoutybloke or less
None of the other available sliders would have faired any better, it saved your tank though
Those mild steel bolts that have bent and stretched are the design fail point, as in they were designed to fail that way, the least damaging way
Put stainless in there and the heads will snap off, high tensile bolts would either snap or cause a much more destructive failure, like ripping the subframe threads out
Given the bike was knocked over how would you like the damage to 1/4 tonne of motorcycle to be?
As I said your tank was saved, no mention of damage to the crankcase cover, footpeg, etc ..OK the fairing panel is damaged, but that seems to be all
Looking at the puck I cannot see any damage to the outer face, when mine went down the puck looked like fats..
T-REX got back to me. They're issuing a refund on the kit. They also said they're pulling the kit from all platforms. So I'm going to look for another option or run without.
I'm now looking at the GSG sliders from Germany. Looks like they're no cut as well but less to go wrong.
[image: Screenshot_20190117-163546.png]
Rollos, 1/17/2019 at 3:03 PM
Where the heck does one buy them for a VFR/Interceptor?  The only place I found they were $295 a set.  No thank you on that price unless there's an open ended guarantee which there isn't.
I was hoping to import from a seller in Switzerland who was selling for around $120. Unfortunately he doesn't ship to the US. Anyone with a Swiss contact that could help out?
Rollos, 1/17/2019 at 10:03 PM
 I assisted member @huntinggunns who bought 2 sets from them. 1 was used in a tipover. Functioned well, only scuffing the replaceable end cap. Rather than charging, they just shipped a set.
This was a few years ago, maybe they do ship to the US now direct.
5 hours ago, mikeswe
Cant't you tell that's a bad design by just looking at it?
I recommend R&G Racing for crash protection.
https://www.rg-racing.com/browsebike/Honda/VFR800F/2015/
Thanks,
I'll probably go with R&G. Too much uncertainty otherwise. Lost a bit of faith in T-Rex after this episode and noticed that they've changed designs at least three times. I'm thinking the older version might have held up a bit better.
Anyone have the Sato sliders? Or could someone give me an idea to how they compare to R&G? Worth the extra $60?
[image: framesliders_14VFR800F_interceptor_1.jpg]
[image: H-VFR814FS_R1.jpg]
I have had the bike fall over twice, once rolled off the stand and 2nd time I put my foot down in oil both times the R&G sliders saved the fairings.
Hey lads.
OP, I'm sorry to hear what happened with your sliders. I was concerned from the get about the T-Rex sliders' position and design. But considering what happened to you, I probably won't get those. I had a bad experience with them once already... Had a set installed on a '17 Fireblade, and the slider broke off and punctured a hole in the frame during a 25mph low side. Bike was totaled.
I'll probably suck it up and cut a hole in my fairings for those R&G's. Especially considering I have an extra set of fairings anyway.
Terrible that you live in New York man. I'm so glad I left. I hated it there.
Rollos, 1/19/2019 at 10:03 PM
Hey Rollos,
Still looking for a Swiss contact?
I'm in Switzerland if you still need them.
Cheers,
Stewen
Thanks giggs87,
I actually just bought the R&G ones from twisted throttle.
Partsworld had the GSG sliders on sale for around 110 chf but they don't seem to be listed anymore.
End of thread · 29 posts recovered Wayback Machine snapshot 22 Aug 2019
