2 caps screwed on the right side, mid fairing?
5 posts Started 25 Apr 2019 Last recovered post 29 Apr 2019 Wayback Machine snapshot 14 Oct 2019
1991 VFR 750F. Couldn't find the parts in the manual & I'll bet most of you could tell me what these 2 caps are screwed onto. I'm eager to learn more about my VFR.
Spring is here in Denver and I've got the riding fever, so I've been using B-12, B-60 High Mileage Rejuvenation & Sea Foam to help clean the carbs a bit before I'm forced to spend $700 to have my local shop clean them.
Apologies if I went about asking the wrong way according to your forum rules.
[image: IMG_0485.jpeg]
[image: IMG_0486.jpeg]
[image: IMG_0490.jpeg]
I assume that based on the last picture, you are asking about the Oil Filler Cap and the Oil Dipstick.
5 hours ago, COS_VFR
Exactly, thanks COS. I've been reading about Seafoam-type products being applied directly into the oil tank. I've waited to make sure that what I was looking at was actually oil caps. I'm happy to say the Seafoam and Berryman's B-12 have already proven their effectiveness even after 24hrs of the solvent being in the fuel lines, carbs, etc...
It's already idling choke-free and very steady RPM's (1900-2100), which it could not do the day before. It'd only run w/full choke plus a little throttle every 10-15 seconds.
Thanks again for reply!
you need to download the owner's manual for your bike.
End of thread · 5 posts recovered Wayback Machine snapshot 14 Oct 2019
