Note: This is for a 5th gen. Everything here is MY observation, on my bike, and I have not elided those bits where things didn't go smoothly simply to try and be helpful. Your experience may be different. Your bike may be different. Your headers may be somehow different. Deal with it yourself.
OK, I got started on my installation after work today. So far I have removed the old (Delkovic) headers and gotten some things cleaned up. I ran out of light, so I'll put them together after work tomorrow or Saturday morning.
Additionally, since you have to pull the exhaust to add or remove the centerstand, I started by pulling the stands off and repainting them. the Delk exhaust has a gazillion slip joints, so I was able to just grab the section behind the heat shield and get them out enough to get the stand off, but the new headers are one piece. If I want to add or remove in the future I have to remove the whole exhaust, so now was the time. This happened earlier this week (There's a thread elsewhere with pics).
Steps I followed for disassembly:
Strip the lower fairings off the bike.
- Both sides.
- Chin fairing.
Remove the slipon and connector pipe.
Check the fit of the connector pipe before continuing.
- My connector doesn't fit over the TBR size exit, so I had a local shop stretch it to fit.
- Remove the chainguard.
- Remove the heat shield from behind the right foot peg holder.
- Remove all sensors (two if stock 00 or 01, mine has a third for my Rapidbike).
- Remove the nuts from the studs on the rear cylinders.
- With the collector still attached to the mounting bolt underneath, remove the front nuts from the mounting studs.
Remove the mounting bolt holding the collector can.
- Delks come apart in pieces, so that was a matter of popping them apart.
- Stock (and the new) headers will come apart at the rear downpipes, but the front will come off as one large unit. You'll learn to wrassle it around when you see it.
- Remove the old crush gaskets from the exhaust ports.
- Clean up and get ready to put it back together.
I'll have pictures below of a few things I found on disassembly.
Steps I will follow to assemble (Note, they aren't the same as in the service manual):
- Attach the centerstand.
Insert the 42mm round crush washers in the rear ports.
- Use Delkovic round 42mm washers.
- These are the only ones to use! They are proven to work, anything else is likely to give bad results.
Loosly attach the rear downpipes.
- Use high temp Antisieze on the studs before you put the nuts on.
Do NOT Torque the nuts!
- At this stage you want the ends holding the crush washers in, but the pipes should have a little wiggle room.
- Insert the crush washers in the front ports.
- Put antisieze on the front studs.
Wrestle the larger headers into place.
- Line up the ends with the slip joints and put them together loosely.
- Get the front downpipes lined up with the ports.
- Put nuts over studs finger tight on the front.
- Make sure the rear slip fittings are tight, then put springs on.
Torque the nuts down
- Go slowly -- this pushes the crush washer into its seat
- Toque is NOT much -- 9ft/lbs or 12Nm according to the manual
Reinstall the sensors.
These don't seem to have consistent torque specs... I've seen everywhere from 15-30 lbs.
- hand tight and a quarter turn like an oil drain plug is conventional wisdom.
- They have a crush washer and threads, they're not going to leak with reasonable, 20lbs torque.
- You can't fit a socket over them anyway, so it's all just a well calibrated elbow and a wrench.
- Use antisieze.
Give a brief prayer to your deity of choice that the connector pipe will line up adequately, and fit the connector and slipon.
- Get a snug fit.
- Line up the can in the clamp/holder behind the rear pegs.
- Tighten the clamp over the connector at the headers.
- Tighten the bolt holding the canister.
So far, I got the old stuff off. I didn't install the Delkovic system, the previous owner did. He told me he had problems with leaks and he wasn't a great mechanic. Handy with tools, but overtorqued everything and didn't understand anything beyond the step by step instructions, so I have redone a lot of really bad work he did. However, he didn't overtorque the exhaust nuts!
That said, he used incorrect washers and held them in place with high temp gasket maker goop. Everything is coated in the copper Permatex. Heh. Anyway, I have it all off now.
First, I got the the slipon and connector off, then I got to work on the sensors:
[image: Removal_190425_171704.jpg]
I want to note that this is the ONLY time I ever use that wrench for actual wrenching. Though I use it a lot. It's the perfect lever for popping the left side of the throttlebody out of the boots, and I've done that more than a few times. But now I get to use it as designed!
[image: Removal_190425_171846.jpg]
[image: Removal_190425_174512.jpg]
So, now the muffler is off and the sensors are out. I suggest you start the bike at this point and rev your engine for at least 10 minutes. This will both make sure all the exhaust is blazing hot AND will assert your authority over all your neighbors. Chicks dig a man who can handle 500 degree metal, and love confidence. The glorious, unmuffled noise will let lesser men know that you are dominant. The equivalent of being the baboon with the biggest, reddest ass. There's no downside here.
Next, I took the back downpipes off and got a look at the ports:
[image: Removal_190425_155825.jpg]
[image: Removal_190425_160049.jpg]
Yes, he did hold the crush washers in place with copper permatex. He's a nice man. Enough said.
I was worried the washers would be frozen in place, but he used too small a washer so there was a lip I could hook and pop them out:
[image: Removal_190425_160648.jpg]
[image: Removal_190425_160652.jpg]
[image: Removal_190425_160657.jpg]
More about that lip later.
I pulled the front off and was also greeted with not overtorqued nuts. Thankfully. I was able to just pop the downpipes out of the slip connectors (you won't be able to do this for stock or the new system) and got a look at the front ports:
The front of the engine is really grungy.
[image: Removal_190425_174102.jpg]
Lots of permatex:
[image: Removal_190425_174205.jpg]
Again, I was able to pop these washers out because they had a goodly lip on them.
And here's why we use the 42mm Delkevic washers that SFDownhill has proven work properly. Take a good look at the black part of this crush washer:
[image: Removal_190425_175029.jpg]
That's all INSIDE of the inner diameter of the Delk downpipe. That pipe is osensibly 34mm id, but this crushed out washer is a couple mm less id. The black parts actually stick in to the port a bit, so there's about a mm lip I could feel, and was able to hook to easily pull this washer out. On the one on the right you can see it formed INSIDE the header, but not outside. Lance's photos show the crush ring smooshed into the corners of the ports, wrapped around the pipe, and not restricting the pipe or the port itself.
It's amazing what a difference a couple of mm here and there can make.
So here's some comparison pics before I put the new pipes on. The port ends are actually pretty close to the new ones. The Delks are 1mm less inside and outside diameter:
[image: Removal_190425_163549.jpg]
[image: Removal_190425_163600.jpg]
The new ones are beeflier farther down, though:
[image: Removal_190425_163645.jpg]
[image: Removal_190425_175422.jpg]
here's the fugly merge on the Delks:
[image: Removal_190425_175349.jpg]
I'm sure between the gaskets sticking into the ports and this clusterfuck of a collector I was giving away a couple of horsepower, just from workmanship.
I cleaned that permatex crap out of the ports and was out of light, so I put the bike in its shed for the night.
[image: Removal_190425_180652.jpg]
More coming in a later post when it all comes together.
Here's the roommate's dog who was taking his afternoon constitutional while was photographing exhaust gaskets. He's ugly on the inside, too.
[image: Removal_190425_175041.jpg]
