The RC51, RVT1000, forks and wheel should bolt right in to the 954 clamps and give enough length. As I recall the spacing is the same with on the clamps between the two.
Quite possibly, but the most direct bolt-on is to use RC51 forks/wheel/brakes and the yokes you have. It's an expensive way to go, but it all works together and looks right.
Trouble is idk how that set up would go with a 4th gen, the leg lengths are what I need to find out...
From searching this forum and seeing other people mods, i changed on my 4th Gen VFR to RC51 SP1 forks, detailed info:
Honda RC51 SP1 Forks - The Forks are from memory 2-3 cm shorter but no problem on clearance travel.
Triple from CBR 929 - ( CBR954 i think it's the same part) - With roller type bearings of CBR 929
CBR 954/929 Top Yoke - With roller type bearings, the original ball bearings would make the triple shake over 100Km\h. The Roller type bearings are a bit "taller" and the clamping is tighter, no problem after that.
Honda SP1 Wheel
CBR 954 Calipers and master cylinder
Honda CBR1000 RR 2006-2007 Front Discs - Alternative option to the SP1's
LSL 2cm "raised" Clip-ons - Installed right under the top yoke - Would smashed the instrument panel gauges - ( i want the maintain the original cluster gauge and functional) - Modified the panel, by cutting the 3 supports stem's and sitting it lower on the bracket
CBR 954/929 - Front fender
Fork bumper-stop - The turning radius is smaller but only drama is when moving bike from stationary to park it.
1st gen R1 or K6 GSXR600/750 forks are about as long as it's gonna get. The latter having the better internals and radial calipers. Offset is much shorter on them though
What year GSXr 750 and what triple for that set up
Don't mean to thread jack but since we're on the subject, are the K5 1000 or K6 600/750/1000 forks longer? I'm not sure if I'll keep the suzuki frontend longterm. That all depends.
Are the RC51 forks that much better than my K5 600/750 forks given both have been sprung and rebuilt for my purposes?
My idea in the meantime is to change my triples to 929/954 and use the gsxr forks I have. See what kind of adjustability I have with the bike geometry and go from there. I kinda want to use as much Honda parts on my honda if I can though so may at some point go RC51 forks.
End of thread · 15 posts recoveredWayback Machine snapshot 30 Sep 2020
