carb balancing tool
13 posts Started 5 Sep 2020 Last recovered post 5 Sep 2020 Wayback Machine snapshot 2 Dec 2021
Ok fellas, what are some of the carb balancing tools you would recommend, there are many out there, have looked at amazon and there are many available, any recommendations?   bog
Morgan Carburetor synch tool. I had the Motion Pro one with fake mercury and it sucked out loud. Morgan tool, I can do the synchronization on my Gen3 bikes in five minutes with three associated flash lights and a ninety degree screwdriver from my Triumph days. Tool is great as it simplifies the entire process which is key.
Yep agree, Morgan Carbtune is an excellent bit of kit.
Hang it on the bike do a bit of plumbing and away you go. (bottom picture 2009 6gen synch. After adjustments).
[image: DSC00997.jpg]
[image: IMG_2996.JPG]
ok, thanks guys, ill start looking for one..bog
after years of scientifik experimentation and research i can bench synch carbs to near-perfect accuracy without any need for gauges, and it costs nothing.
pm me for details.
1 hour ago, squirrelman
pm me for details.
But, there are no carbs on a 6gen! :sad:  Can you do the same for throttle bodies with starter bypass valves?
^^^ dunno, haven't had any to work with.
16 minutes ago, squirrelman
Well that's a very good skill you have for non fuel injected bikes then. :fing02:
Squirrelman, are you using feeler guages to sync the carbs, i wondered if that method would work.   bog
I havent received my service manual yet so i have a few questions, when syncing the starter valves, do you prop the tank up at the front? I have ordered a carbtune pro 4, should have it in a week. I used to sync carbs back in the 80s with a mercury column tool, worked pretty good. Do youknow if this carbtune pro 4 requires any additional equipment to sync a 2003 vfr 800, tubing adaptors etc...  also i have read that the 6th generation interceptors have different vacume readings for the 4 cylinders to be synced correctly? Any info would be greatly appreciated.   bog
You can download the Service Manual from this forum, download section. Yes it can be done by having the tank in the maintenance position. The carbtune comes with all you need to connect it to the Starter Valve vacuum hoses. It's the 5gen that has the offset vacuum,  the 6gen is balanced and referenced to cylinder 4.
A "haakse schroevendraaier" comes in handy. As go gloves to protect against scalding marks....
[image: image.png.b97a7de7752e9b5b72dd4487c2d2e0a5.png]
6 hours ago, bog
negative, workable but not so exact.
End of thread · 13 posts recovered Wayback Machine snapshot 2 Dec 2021
