I'm trying to find the thread discussing remote chain oilers. A couple of members presented some compelling evidence that they are a bit pointless but I can't find it.
Can anyone help?
Can anyone help?
You’re right, seems very difficult to find that topic on this forum/site, lotsa discussion elsewhere if you wanna wade through all the claims of “superior system” that exist. I have 1(cameleon), but only because I’ve failed to locate a centrestand for my ‘86. Bit of a PIA to install & keep delivery system adjusted so it oils correctly.
Hiya Skids
Helpful facts to ponder... auto oilers lube only the external roller and
between the roller and the sprockets (red area in my drawing)... they
do not lube the X rings nor behind the X rings so any oil applied
in that effort is wasted fling off... The running oil leak lowers the
operating temp where the factory installed grease has a chance to live
longer before the first adjustment... but the fact remains adjustment
is taking up the slack cause by metal to metal wear at the critical
pin and roller junction because the factory installed grease is
beginning to fail... you can submerge the chain into a sea of oil and
not one molecule will migrate pass the effective X ring seals to
reverse this metal to metal wear...
What we are lubing are external roller and between the roller and the
sprockets (red area in my drawing)... we are not lubing the X rings
nor behind the X rings so any oil applied in that effort is a waste
and will only fling off...
[image: 14746956046_fb75bdf189.jpg]
I recommend Motul Chain Paste... squeeze the white grease from the tube and load
the brush... Hold the loaded brush to the inside of the chain rollers to transfer the
white grease... After a couple of spins of the chain it's lubed like from the Factory...
Motul Chain Paste clings with no flings...
[image: IFSsIxV.jpg]
[image: sNNeKhh.jpg]
[image: gaR69pV.jpg]
36 minutes ago, BusyLittleShopHiya Skids
reverse this metal to metal wear...What we are lubing are external roller and between the roller and the
and will only fling off...[image: 14746956046_fb75bdf189.jpg]
the brush... Hold the loaded brush to the inside of the chain rollers to transfer thewhite grease... After a couple of spins of the chain it's lubed like from the Factory...
What kind of mileage are you getting out of your chain with this lubrication method?
My next chain will be the new bmw 525 chain that you do not have to put anything on. Problem solved finally! 🙂
6 minutes ago, SparkieMy next chain will be the new bmw 525 chain that you do not have to put anything on. Problem solved finally! 🙂
What is the price for this set up?
3 minutes ago, FritzerWhat is the price for this set up?
TBD. I've heard double the price of a normal chain. But if it performs as advertised, I can't wait!
You're really buying that? Chains have to be kept clean of grit and dirt, and lubed some to keep the rollers and sprockets from prematurely wearing out. So, if one thinks the BMW thing is going to be permanent with no lube, I seriously doubt it. They claim this new material for the side links, well, hate to say it but good chains already have them and are way better than they were years ago. I love marketing. Save yer money.
42 minutes ago, raYzermanYou're really buying that? Chains have to be kept clean of grit and dirt, and lubed some to keep the rollers and sprockets from prematurely wearing out. So, if one thinks the BMW thing is going to be permanent with no lube, I seriously doubt it. They claim this new material for the side links, well, hate to say it but good chains already have them and are way better than they were years ago. I love marketing. Save yer money.
If you read busy little shop's post, you should know how an xring chain is permanently lubed at the critical points, and what you apply to the chain never actually gets to these points. So I'll keep it clean, but won't have to oil it and it's supposed to last much longer. The coatings absolutely can increase the life of a chain. I'm a CNC machinist and I have used all kinds of tools in the last twenty five years. A proper coating on a tool can increase tool life and efficiency in an unbelievably dramatic fashion. So, yes, I believe this chain is a better design. And I'm going to buy one when it's time to replace my chain.
Getting back to oiling the chain, I think a automatic oiler would make a giant grease mess. For that reason, even if it worked well, I would not use it.
When I acquired my beloved '99 22,500 miles ago, the chain was toast. The chain was worn out at the connection pins which caused a huge stretch issue and rollers were done. The previous owner liked to spray on a waxy chain lube, but it did not work. After I took possession, cleaning off all of that messy build up took a little effort.
Correctly lubing a chain takes a little bit of effort but it is not that bad. Looking back in my logs, on average, I remove, clean and oil my chain about every 2,000 miles. About every 800 miles or so, I install a drop of oil at each roller to side plate intersection. This procedure takes five minutes.
This is what I do to maintain the chain. let me know if anybody has a better system.
Remove the master link. I use a clip master link since the chain comes off on a fairly regular basis. I have never had a clipped master link fail but it is very important to be sure the clip is solidly in the pin notch, rounded end facing rotation.
Once the master link is off, I usually hook an old chain onto chain to be cleaned. Then thread the old chain thru the counter sprocket about 1/3 way. Let it hang in place. When the time comes you will hook up to the old chain in place and thread the cleaned chain through the counter sprocket.
Once I get the chain out, I put it coiled up in a pan for cleaning with kerosene. I don't have a parts cleaner so this works. Kerosene will not damage the x seals and is a lubricant in its own way. I spin the rollers to make sure solvent is washing out the roller to pin area. I do this cleaning 2 or 3 times depending how dirty it is. When I am done with cleaning, I air out the solvent,
Now the coiled up chain goes into the pan with engine oil. Spin the rollers to make sure the roller/pin area is saturated.
I use a S hook and hang the chain off my garage door rail over night. Wipe it down after it is done dripping and reinstall.
Total time for removal, cleaning, oiling, and reinstall is about 40 minutes.
With this method, I have never had a chain stretch problem. Always is a roller wearing out and getting 1 -1.5 mm play is what takes the chain out of service. My current chain is not showing significant amount of wear yet. I am thinking it will probably make it 30,000.
Well, it really sounds great that chains don't really need any lubricant, but I do wonder how real world that opinion is and how well it has
been documented, or whether it is just one guy's opinion. Lots of stories related about chains being shot in fairly short mileage. I don't
think I've read of any that say they get 25,000 miles out of their chain and they never lubed it. I've seen quite a few, okay lots, chains that
were obviously not lubed because they were rusty/saggy as hell. I suppose it's possible that all the ruined chains I've seen were not X-ring
chains and therefore need some lube. But almost all modern chains are O-ring, X-ring chains so that seems against the odds.
So I think I'll keep using my HawkOiler, and be happy with the 25,000 miles I get from my chains.
BusyLittleShop's thoughts sound fantastic, but how realistic they are is open to debate. When I can talk to someone who has never lubed
a chain in 25,000 miles, okay even 10,000 miles, and it's still like new, I'll take it a bit more seriously.
I have to apply some form of lube to help mitigate against the winter weather and chemicals they apply to our road surfaces.
It's not even cold over here yet I went to work in the wet last week and there is already the dreaded white spots growing in various places and even some parts of the chain are showing telltale signs of external rust.
The Ol'BattleStar burns oil. So I ran a hose from the Valve Cover Vapor-Condenser bottle to the chain;
[image: 20181021.jpg.0490afa54e04c80bb059d035e6a92d81.jpg]
Can't rember last time I manually oil'd it.
I have a Scott Oiler on the Adventure Bike, it gets real dirty.
It gets Power Washed after, then I go for a ride with Oiler turn'd UP, till the chain gets wet with Oil, then turn'd OFF, till it needs oil again.
It gets pretty ugly at the Primary Sprocket, like an Alien Lifeform in there.
I remove that cover for Power Washing, in the backyard, where I need the water on the lawn anyway.
When I got my first VFR800 in '06 I became quite lazy regarding lubing the chain. A new one lasted less than 8,000 miles. That was about a half year's worth of riding for me in those days. The cost to replace a chain and sprockets put that lazy attitude right in the poorhouse trash can. Careful lubing every 500 miles has me going a couple of years (~15,000 mi.) on a chain. That is a guess on my part because they have become a rare occurence lately.
The unofficial offical claim about the Regina/BMW no-lube chain is that you DO still need to clean your chain, but don't need to lube it, and should get 30k+ miles from it.
But if someone is interested in a Scottoiler, I think I still have one that's never been installed.
I've never used an oiler, but I've seen bikes where the oiler malfunctioned, releasing too much oil, and coated the rear of the bike with oil. No thanks.
I was never great at chain maintenance as far as cleaning went, but I did apply spray-on chain wax every 300-400 miles, applying it just after getting off the bike so the chain was still warm, and then letting the bike sit for 10-15 minutes for the wax to stick. This worked well for me. I probably replaced my chain and sprocket sets a little earlier than necessary, but usually do so at 18-20K miles, usually with a Regina or DID set. I never had any issues of any kind, other than the wax buildup in a couple places.
But no more chain lube or maintenance for me, as my new bike is shaft drive. 😉
Fritzer, 11/14/2020 at 1:55 PMWhat kind of mileage are you getting out of your chain with this lubrication method?
Mileage is a loose standard because wear depends on so many variables...
A more accurate standard of chain wear is after the 3rd adjustment because that
is undeniable evidence that the factory installed grease is beginning to
fail to lube the critical pin roller junction hidden behind the X ring... the
length of the chain is growing because of this metal to metal wear... I can
not call a chain serviceable that is grinding metal... it's like saying that a
dry bearing that runs ruff is acceptable... the net result is another 2 to
3% drop in RWHP as more energy is lost grinding metal behind the X
ring...
This is what we don't see behind the X rings... metal to metal wear
every time we adjust the chain that eats into our engine's available
HP... a new pin measures 206.5 and wears down to 205.5 at the 8K mile
mark... looks good to the naked eye but multiply that 1 thousand of an
inch times 108 links and you have 108 thousands of an inch wear or
about the range of the green marks provided by Honda's wear gauge...
202.8 show the very visible wear at the 12K mile mark... the pins are
turning red from extreme heat of grinding dry metal... a chain in this
condition may consume up to 6 to 8% of our RWHP... not to mention it
may snap into and cause case damage...
[image: gallery_3131_51_50064.jpg]
Honda provided a handy guide to monitor chain wear... stay with
in the green and you'll be looking for a new chain and sprockets at the 8 to
10K mile mark...
[image: gallery_3131_51_39609.jpg]
Fritzer, 11/14/2020 at 4:24 PMCorrectly lubing a chain takes a little bit of effort but it is not that bad. Looking back in my logs, on average, I remove, clean and oil my chain about every 2,000 miles. About every 800 miles or so, I install a drop of oil at each roller to side plate intersection. This procedure takes five minutes.
Chains are pain to maintain... only a belt spells relief...
I've removed my X ring chain and thoroughly cleaned in an gas bath...
But lubing an X ring chain in an oil bath was not successful because
If you wish to lube the critical pin and roller junction just cut and remove all the X rings...
[image: TalkingChain08.JPG]
[image: TalkingChain09.JPG]
[image: TalkingChain06.JPG]
Fritzer, 11/14/2020 at 7:24 PMRemove the master link. I use a clip master link since the chain comes off on a fairly regular basis.
Every chain manufacturer recommends you use a riveted master link and avoid a clipped on master link. Maybe you would consider their advice?
Back in the '70s, we would take our (non-O-ring) Dirt Bike chains OFF and Boil them in Grease.
11 hours ago, BusyLittleShopI've removed my X ring chain and thoroughly cleaned in an gas bath...
First of all, I would never use gas to clean my chain, It is very dangerously flammable, has ethonal in it, so any amount getting through the x seals will degrade the lubrication (they are not a perfect seal). Kerosene is a lot safer and is a lubricant. Any that makes it past the seals does not degrade the lubrication. I feel confident about this since I have not had a problem with the critical pin wearing out and the chain "stretching". I never have to readjust my chain.
The point of wear on my chain with my method is always the wear between the outer in inner roller. That area is not sealed, gets grit in there and the roller gets the most pressure put on it from the sprocket torque. So cleaning is about getting the grit out of the inner roller area then saturate it with oil. After letting the chain drip out, very little oil gets flung about.
As far as the clipped master link goes, I know that the manufacturer advises a riveted ML. I feel the clipped ML is just as strong as the riveted but leaves room for clip installation error by the mechanic. It is easy to think the clip is in the pin notch when it is not. This would potentially cause the plate to come off and have your chain wad up at the counter sprocket area making for automatic chain lube system.
I have been doing this method for 35 years and the same results described above have been the outcome.
But, everybody has there own way of doing things. If you are happy with your outcome, stick with it.
1 hour ago, VF1000FeBack in the '70s, we would take our (non-O-ring) Dirt Bike chains OFF and Boil them in Grease.
That and the smell of castrol.... Those were the days🙂
44 minutes ago, FritzerThat and the smell of castrol.... Those were the days🙂
Castrol R.....😎
8 hours ago, SparkieEvery chain manufacturer recommends you use a riveted master link and avoid a clipped on master link. Maybe you would consider their advice?
True but consider this... chain manufactures are advised riveted by
their liability lawyers not by their engineers... speaking as a
engineer I believe clipped ML on a X ring chain are safe... that is
because X ring links are pressed on... but the one step home mechanics
miss doing is side loading the clip once it is homed in the groove...
this step insures it will stay put... I've witnessed many customers O
or X ring chains missing their clips... they have no idea just how
many thousands upon thousands of miles covered in this unsafe
condition... but if a clip is tossed on a non O ring chain... the
chain it tossed all most immediately...
For some riders clip ML are unsafe... they would spend too much
attention on the clip and not enough on where they're going and what
they're are doing... it short it's a barrier for which only a riveted
link can solve... so even thought they may not find the right words to
express their fear... I urge everyone to respect their choice...
I also forgot... you may FIPG the link clips to keep it being tossed...
2 hours ago, FritzerFirst of all, I would never use gas to clean my chain, It is very dangerously flammable, has ethonal in it, so any amount getting through the x seals will degrade the lubrication (they are not a perfect seal). Kerosene is a lot safer and is a lubricant.
I mainly employ gas because its handy... I've used K but its goes bad and stinks...
If there is one chemical our chains can handle its good old gas...
petroleum products have no lasting effect on the X W or O rings
because instead of rubber chain manufactures today actually use a
highly fluorinated fluoroelastomer known commercially as Viton or
Kalrez... very tough stuff... It has a excellent resistance to most
chemicals including sulfur... sulfur chloride... sulfur dioxide...
sulfur hexaflouride to name a few... most important it doesn't need
protection from drying out... they will far out last a chain's life...
BusyLittleShop, 11/14/2020 at 10:17 PMHiya Skids
Mine does lube the X-rings and keeps them clean so they last longer wich helps in keeping moisture and other contaminants outside and the factory grease inside. Also I don't think a single drop of oil every 4 miles cools the chain down by any measurable amount. Chains don't get that hot that it affects the longevity of the grease anyway.
I replace my chain shortly after the first adjustment. That is when it has done about 70.000 km in varying weather conditions.
Sparkie, 11/15/2020 at 12:30 AMTBD. I've heard double the price of a normal chain. But if it performs as advertised, I can't wait!
Correct. Here the regular chain for the S1000XR/RR is €138, the endurance chain is €268.
2 hours ago, V4 RossoChains don't get that hot that it affects the longevity of the grease anyway.
Chains do get that hot and heat affects the longevity of the factory installed grease...
2 hours ago, V4 RossoThat is when it has done about 70.000 km in varying weather conditions.
Post a photo of the critical pin and roller junction and you'll see that your chain was pretty on the outside and wearing metal to metal on the inside...
21 hours ago, BusyLittleShopChains do get that hot and heat affects the longevity of the factory installed grease...
[image: 107ChainTemp.JPG]
107F? That's about ambient temperature in southern Europe. I guess it's the same for California during the summer months?
Riveted vs Linked.
From ANSI roller chain tech documents, a slip fit chain is 20% weaker than the riveted chain. Some chain designs it's less. Have to look at technical details from the MFG.
The last chain I saw that used a clip-type master link, also was a very tight fit. Basically the side link
had to be pressed on just like a riveted master link. There was no "slip fit", like the old clip-style
master links I've seen, and used in the past.
Hate to say it, but for all the bling-gotta have it-add on enthusiasts - in my experience following the chain and motorcycle manufacturers maintenance instructions actually works. Yes, a chain needs to be cleaned every so often. So do it. And it needs a LITTLE lubrication (90W gear oil - not engine oil, fish oil, toothpaste, chain wax, CRC, silicon spray or olive oil) for the purpose of lubing the external plates and keeping them from going rusty.
I was nearly drawn into the chain oiler money waste prior to a 20,000km jaunt around Europe and the Western Sahara on a Transalp. And 30,000km around Australia on another Transalp - mostly red roads and 4WD tracks. Hmmm....sand and sticky oil residue. Sounds like a great base for a valve lap abrasive. Over that distance I consumed perhaps 20ml of gear oil. Clean well. Lube each plate/pin junction with a TOUCH of oil. Rotate a few times to distribute, then WIPE OFF all excess. OMG! That sounds amazingly close to what is recommended!
Ok, I'm just your average Joe with a few years on two wheels. Along my way I met up with a French dude who had competed in the Paris-Dakar (yeah, the one between Paris France and Dakar Senegal (that's in Africa for the geographically impaired) twice as a privateer on a KTM. Morocco to Senegal was almost 100% off road and predominantly sand. I asked about chain maintenance in such extreme conditions (sand, competition, abrupt on-off throttle, extended periods of full power). He took me downstairs to his garage to look at his old KTM. It had sat idle/as a monument? after nearly completing his last P-D (broken con rod almost in sight of the finish). We looked at the chain - clean, dry of any oil residue and still nice and tight fitting around the sprocket. His mechanic's daily maintenance protocol for the chain? Thorough clean, minimal gear oil lubrication, wipe clean of residue. No auto chain oilers, no chain wax, no miracle molybdenum super non-throw chain lube.
Brave man if you're considering punting a VFR around any P-D - but it serves as a real world example.
11 hours ago, KiwiwannaflyHis mechanic's daily maintenance protocol for the chain? Thorough clean, minimal gear oil lubrication, wipe clean of residue.
It's no P-D stage but I do commute on my bike and when I get home have never found those mechanics waiting to service the chain on my bike. And after a days work I am not so keen on doing it myself every day. That's why I have a chain oiler, not for the "bling or "got to have it add on"
Each to their own. Enjoy the chain fling clean up.
17 hours ago, Sparkie
Watched that a while ago, helped me change my mind about chain lube and auto chain lubers.
How about auto chain lubers loaded with gear oil? 🌝
JZH
Chainsaw lube!!!! :fing02:
I use ordinary engine oil in the Chain Saw (Bar Oil).
I have used Gear Oil in the Auto-Oiler, it works, but Gear Oil smells.
And it still flings off, (I have a speed problem, right wrist control).
Worst, the Gear Oil is Very difficult to wash off. If I handle the bike before cleaning (most of the time), it then gets everywhere, including me.
I even doubled the size of the Chain Guard, still get oil splash (at speed).
I've back'd up to using 15W40, out of the 19Liter pail I gots for the Ol'BattleStar (oil burner).
When that runs out I'm going to 20W50.
Ordinary Engine Oil works fine and I can "lube" the chain while still riding by just turning a knob.
When chain looks happy, I turn it OFF till needed again.
Engine oil Power Washes OFF easy.
I used to turn oiling UP on Gravel Roads, keep it wet, but I could empty the 50ml supply in 1 day.
Now I let it run dry and "oil ON" when I get back to pavement.
Sport Bike?,,.. I manually lube with Chain Wax Spray (if needed).
BusyLittleShop, 11/18/2020 at 1:31 AMPost a photo of the critical pin and roller junction and you'll see that your chain was pretty on the outside and wearing metal to metal on the inside...
I found this old pic I once took of a link (on the left, next to a new connecting link) I removed when cutting the old chain. Looks quite OK to me. I will try to remember to get some more measurements (e.g. of the rollers) the next time I swap the chain. This can take some time as the current one still has at least 50K in it 😉
