21 hours ago, bmart
Substandard globe. Doesn't that just tie up the daily news in a nutshell!
VFR 5th Gen gets these:
Tail lights Sylvania Zevo Super Bright Red 7443R LED fins 12v .4W/1.5W
Headlights H4 with the two tabs cut off.
17 hours ago, Grum
Your charging voltage is fine, anything from 13.5v to 14.5v is good.
These M.C.S. globes could be made anywhere, might be a Chinese cheapy who knows?
As mentioned try a pair of good quality long life H4's.
As a replacement of the OEM, I've previously used Philips Long Life Eco Vision H4's 60/55w on my 6gens, not had one of these blow.
Use some tin snips to cut two tabs or bend them back to suite as suggested by bmart.
Make sure the socket connectors are making good gripping contact to the globe contacts.
[image: 20211214_180003.jpg]
What these guys said.
Was blowing bulbs about every 1,00 miles or so. I do not live anywhere remotely near to a Honda dealer, so it was a pain to source, no idea why they needed "bespoke" bulbs anyway.
Finally at 0430 am one morning as I started the bike to head south one of my bulbs blew again. Thinking it was a connection I played around with the bulb, no luck closer inspection showed a burned filament. As I was going for about 12 days I was in no mood to delay, so I grabbed an H4 I had for one of the cars. Thought I was going to have to bodge it with duct tape, glue whatever, until I looked at the respective patterns. IIRC I bent two of the tabs back and forth until they broke, the bulb fit perfectly, with minor adjustments.
I bought another H4 enroute. The right side has 40+k on it, the left 37K since replacement.
For the record, they were bog standard Slyvannia car bulbs in a 97VFR.
