Hello guys, I had this problem since last year, and this is the situation and what I did and didn't so far.
Last year battery was in better shape, hold charge, but it could drop to 9.6v during cranking, sometimes it won't go below 11v... It wasn't the best.
This problem ONLY happening on hot/hottish start, never EVER on cold start.
What I did so far is:
1. Checked the battery, isn't the best. I need to replace it and I suspect that is the problem but...
2. Check the ground, perfect.
3. Cleaned battery terminals, inspect cables.
4. Cleaned starter relay pins and starter switches.
5. R/R is fine, proper voltage.
What I didn't and should:
1. Change the oil (can that impact the starter clutch)?
2. Change the battery - most important to do just to eliminate that.
3. And ofc I didn't open the case to see the starter clutch and didn't inspect the starter motor cuz, I am not so sure that I can do that (mostly cuz I never done this before), even if Im usually working on my motorcycle, smaller things and services.
Here is the video. First start is ok, and it happens on 2nd and 3rd. My suspect is that because battery is bad, on every other start, it is weaker and weaker and motorcycle produce that sound - not enough power to crank properly?
https://drive.google.com/file/d/1glppXAsErw1zHdbywXvJoQcl7h4qoRew/view?usp=sharing
And what is grinding - starter clutch or starter motor?
Also, what is strange, sometimes I can start it like 10 times in a row without any problems...
It has something with the temperature, cuz it never happens on cold engine... can the heat affect bad battery? Old oil in the case? Bad starter motor, starter clutch? Check the torque on these 3 bolts on the starter clutch?
