Hi there, went to start my 2014 VFR the other day and it attempted to turn over briefly then next time did nothing, tried jumping it still nothing. Noticed the starter relay was clicking when I pressed ignition, got new starter relay from Honda, exactly the same problem. Any ideas helpfully received. Thanks Paddy
Clicking Starting Relay
Hi Paddy.
- Have you tried starting the bike with the Sidestand Up and the Clutch pulled in?
- And, is your Neutral Light working correctly?
- Have you checked that the Battery Terminals are clean and tight?
- I know you've tried jumping the battery with no success but how old is the bikes battery? And is it well charged?
- If you have a voltmeter clip it to the battery terminals. What is the voltage and what does the voltage go to when pressing the Starter Switch?
Answers will give a greater insight to your issue.
🤔 the ol switch stand thing is a high probability. But your battery needs a meter on it. Take battery off, test it and charge it, then test it again
Clicking relay is typically sign of insufficient battery power
Also when jumpstarting, make sure it's from know-good battery. Verify battery can start car it's in. But leave car off when jumping bike. Also wiggle jumper cable's clamps to get good bite. I've also encountred bad battery cables
Final ultimate test:
1. battery voltage with everything off. Volts = ??
2. battery voltage when pushing start-button. Volts = ???
If you think its a low battery, put lights on & if when relay clicks the dash lights dim out & sometimes the lcd too. Then you know its battery power. Put some jump leads on the battery from your car, if its starts OK its your battery.
normal voltage in a battery (with key off) should be close to 12.6 volts, so use your volt/ohm multimeter to check. recharge with 1-amp charger for 6-8 hours. if voltage does not rise to 12.6 the battery is bad, but check your charging system output too.
Flat battery put on charge.
refreshing charge... wait 30 minutes... measure terminal voltage...
12.8 or higher is a good battery...
12.0 to 12.8 is a insufficient charge... recharge...
12.0 or lower... battery unserviceable...
Hi All.
Sorry to post this info again. But seeing the OP is referring to his 2014 8gen exactly like mine, and he most likely appears to have battery issues. Thought I might once more add this valuable info.
Battery terminal voltage does not represent the true health of the battery, its capacity to deliver plenty of cranking amps when needed.
Here's the OEM battery from my 8gen. It would charge ok with no errors from my intelligent charger yet was reluctant to crank the Starter.
As you can see its voltage was 12.65v but failed miserably when load checked. The Battery rated at 210 cranking amps could only deliver 99amps. A new battery solved my cranking issues.
So the bottom line here is, any doubts about your battery, charge it, remove it, and take it along to any good Automotive Parts store where they will Load Check it for free.
For the Aussies - I had this test done at both Autobahn and Supercheap Auto.
Cheers :fing02:
[image: 20200626_104144.jpg]
We do this with our car batteries a week or so before the 100% warranty runs out...and usually get another free battery.
Hate to say it, but this is somewhat typical.
VFR owner cries for help, we all in good faith chip in to help out.
All we want is an answer back on the fix so we can all learn from the experience, sadly you never here the outcome.
Kinda pisses me off! :mad:
Yeah, how rude!!!
Still cant resist following along on interesting threads, despite having been left hanging too many times over the years. Must be another of my character flaws ..
Grum, 10/27/2022 at 6:11 AMHate to say it, but this is somewhat typical.
Yeah nothing more annoying. It’s getting as bad as fb. Full of Pandas 🐼, eats, shoots and leaves.
2 hours ago, finkYeah nothing more annoying. It’s getting as bad as fb. Full of Pandas 🐼, eats, shoots and leaves.
Haha. Sounds like the Wombats we have over here, eats roots and leaves!
