I just bought a Shindengen SH847. Still waiting to get it, but wanted to find out what people have done to mount it. I just figured I'd buy or build a bracket to mount it in the original location. Is that the "best" option?
Best Bracket for SH847
I safety wired mine on years ago. Works fine. 🙂
My friend Angus MacGyver used chewing gum and a paper clip on his.
There's a thread somewhere here that shows the Roadster mount on a 5th gen, it needed some hacksaw work, but looked clean when done.
Mbe a member can find it, post the link.
18 hours ago, ZifferI just bought a Shindengen SH847. Still waiting to get it, but wanted to find out what people have done to mount it. I just figured I'd buy or build a bracket to mount it in the original location. Is that the "best" option?
This is what I did: 5th Gen Needs New Rec/Reg, Other examples on this thread.
If I had to to it over, I'd use rivnuts.
Other mounting examples from VFRW
Good luck
8 hours ago, bmartI safety wired mine on years ago. Works fine. 🙂
I saw that. If I ever want to recreate the Sanford and Son truck, I'll look you up!
8 hours ago, Captain 80sMy friend Angus MacGyver used chewing gum and a paper clip on his.
Well that's just silly, everyone knows you don't have any friends.
6 hours ago, mello dudeThere's a thread somewhere here that shows the Roadster mount on a 5th gen, it needed some hacksaw work, but looked clean when done.
Aw, I started this thread specifically to draw you out, cuz I thought you may have some gen5 brackets left... And you wouldn't answer my PM!!! [image: image.gif.6f654492fe70664f5ae3e1333deee049.gif]
3 hours ago, TirsoThis is what I did: 5th Gen Needs New Rec/Reg, Other examples on this thread.
Good luck
Ah, finally, someone with some useful information. I took a quick look at the provided info... I'll probably just drill and tap the subframe. 👌
Btw, the bike is now 25 years old, and I believe it's still running the (now malfunctioning, me thinks) original regulator/rectifier! No burnt wires or connectors, just not putting out a reliable voltage. Did the stator test, seems fine. That's a pretty good run for a subpar electrical system. I think what did it in is switching over to almost all LEDs, plus I had the front fairing (and headlights) off of it for awhile, and would test run it that way sometimes. That means almost all current from the magneto had to be shunted to ground.
1 hour ago, ZifferAw, I started this thread specifically to draw you out, cuz I thought you may have some gen5 brackets left... And you wouldn't answer my PM!!!
Dude, I never made 5th gen brackets.
15 minutes ago, mello dudeDude, I never made 5th gen brackets.
Oh, then how do you account for this post...
And I quote: "- I have a 5th gen design if asked..."
Bwahahaha... I gotcha!
Edited January 7 by ZifferTo be even more devious.
10 hours ago, ZifferWell that's just silly, everyone knows you don't have any friends.
Ooooofff!!!! Haha!
Never made any... whatever dude...
34 minutes ago, mello dudeNever made any... whatever dude...
Aight, dude. I think I've decided to just drill and tap the subframe anyway...dude.
Tirso, 1/7/2025 at 3:27 AMThis is what I did: 5th Gen Needs New Rec/Reg, Other examples on this thread.
Good luck
:fing02: I love Rivnuts. Especially stainless steel ones (but use anti-seize).
JZH
mello dude, 1/6/2025 at 11:03 PMThere's a thread somewhere here that shows the Roadster mount on a 5th gen, it needed some hacksaw work, but looked clean when done.
maybe here - Regulator / Rectifier Upgrade (SH847)
39 minutes ago, toreckmanmaybe here - Regulator / Rectifier Upgrade (SH847)
That's it! :fing02:
2 hours ago, mello dudeThat's it! :fing02:
Looks like the ones you made, mello dude. 🫢😉
20 minutes ago, Captain 80sLooks like the ones you made, mello dude. 🫢😉
Not quite, made for 6th gen, maybe could be adapted for 5th, never tried it...
Have a handful left, but MDG is kinda outta business...
26 minutes ago, mello dudeNot quite, made for 6th gen, maybe could be adapted for 5th, never tried it...
I was joking...
It has been awhile but I think that I just drilled and tapped the frame, careful not to over torque. Rivnuts was plan B.
[image: image.thumb.jpeg.1ccee3ddcdf2854c110caa962efe7942.jpeg]
I just made a simple adapter out of some 1/2' x 1/8" flat stock, and some spacers. An added advantage is getting it away from the hot subframe. I even added a little axial fan. Probably not needed, but it can't hurt.
It's not that difficult if you have a hacksaw, and a drill.
