8 hours ago, Slide46
Thank you. You are very helpful. A new 6th Gen SMC will be my last resort due to no availability in new 5th gen SMC. I have read every forum pertaining to the linked brake issues. I am going to take my chances on rebuild kit and removal of the green filter screen. Nobody has mentioned HOW to remove this exactly ? What is the way to remove without damaging. If the answer is compressed air, where do I direct the air exactly ?
Up to 2009, 5th & 6th Gen use exact same 2nd master cyl, part numbers are identical.
6th Gen front calipers are no use on a 5th Gen, piped up different & piston sizes & how it's linked is different too.
Re:
Green check valve in 2nd master cyl.
Once master cyls off the bike, pull the piston assembly, remove the bolt off brake pipe union that holds the Green return valve in place, O'ring is all that keeps brake fluid in so don't loose it, ideally replace if you can size match it, note valves orientation (Take pics).
To get valve out:
Block off the bottom banjo bolt hole, stuff some rag in, blow into piston bore & green valve will just pop out, I wouldn't use an airline, a good blow with mouth is enough (trumpet style) it's not a tight fit, but it is a snug fit, keep a hand over it, if you lose of damage it, you're fucked, you can't buy em & master cyl can't be used without it, you'd never get a fluid seal on the bolt off pipe union, give the insides lots of love, to avoid scratching stuff I use Ice lolly sticks split in half as pokers with paper towel soaked in brake cleaner to get the gunk shifted from the bottom of the piston bore, when all the schmoo is out, I lightly hone the bore with 2000 wet , dry or a grey scotchbrite to ensure a good fluid seal.
Green return valve has a filter screen on each side, carefully pry it apart, ball bearing & spring is all that's inside, surgically clean it all, along with the bore it came from, there's a micro hole all the way thru the valve, ensure you see daylight thru it, this is held closed by the ball & spring.
If you source a Tourmax repair kit (best available) they come fully assembled, easier to fit to master cyl if you remove the clevis mount from the pushrod.
Have fun😊
