5th gen blue gauges
55 posts Started 12 Apr 2006 Last recovered post 5 Mar 2014 Wayback Machine snapshot 5 Jul 2022
Welp, as I was relocating my dual Fiamm horns last week, I finally did the blue gauge mod.
I had ordered 5 inverted-tip, wide angle LEDS from http://www.superbrightleds.com/mini-wedge.html
[image: user posted image]
The inverted-tip causes the LEDs to emit a broad beam which avoids "spotlighting" the gauge face near where each bulb is located.
Installation is exactly the same as replacing the stock incandescent bulbs, see your service manual if unsure.
Only 1 caveat and that is the bulbs are polarized, so they only work when installed in one direction (+/-). I put mine in with the ignition on, and the garage semi-dark so I could tell if each individual bulb lit up. There were a couple I had to turn the base 180' to get them to light, easy as cake.
fing02.gif The end result:
[image: Click for full size]
Oh, and I might mention that I had previously tried some #194 incandescent bulbs from the local auto store that were painted blue (from the factory) and they were very dim.
Even in the darkest night, the gauge faces were too dim to be immediately readable, but the LED's are a whole 'nother story! tongue.gif
veefer800canuck, Apr 11 2006, 09:40 PMOh, and I might mention that I had previously tried some #194 incandescent bulbs from the local auto store that were painted blue (from the factory) and they were very dim.
That looks great !
I think I know what my next mods will be: LED's and the horns.
Looks awesome... do they make those in red? Wonder if I could do that to my 6th gen.
Mr Pheer, Apr 12 2006, 02:17 AMLooks awesome... do they make those in red? Wonder if I could do that to my 6th gen.
They DO make the lights that I used in Red, but Unf, the 6th gen already has LED lights and they are soldered to the electonic panel of the gauges.
It's a bout of electro-surgery to replace them, but you can have it done here and in colours other then blue:
http://www.bluegauges.com/motorcycle/vfr800.htm
If any 5th gen owners wanted red gauge lights (or other), they could certainly go ahead using the same type LEDs I did from the supplier above.
Thanks for the picture. Any problem seeing the needles with these leds? In the picture is looks like they aren't lit up.
Looks great! My Jetta has blue gauges, and I like the way they look. I might have to do that to my VFR just to keep everything in harmony.
Looks familiar.
Looks very nice. Might do that myself. Thanks for the photos!
How much did each cost? On the following product page, the top three all appear similar, with prices of 0.89, 0.79, and 1.49; just wondering exactly which ones you got.
http://www.superbrightleds.com/cgi-bin/sto...8.26576&next=50
Payne
I did that to mine a couple of years ago, but I can't see my needle worth a crap. Let me know if you figure out a solution.
pseal, Apr 12 2006, 08:45 AMHow much did each cost?  On the following product page, the top three all appear similar, with prices of 0.89, 0.79, and 1.49; just wondering exactly which ones you got.
I got the ones that are $1.59 with 4 led's.
ratfink, Apr 12 2006, 10:14 AMI did that to mine a couple of years ago, but I can't see my needle worth a crap. Let me know if you figure out a solution.
I have no problem with seeing mine, it is kinda purpleish in color, but can see it fine.
sily_rabit, Apr 12 2006, 05:04 AMThanks for the picture.  Any problem seeing the needles with these leds?  In the picture is looks like they aren't lit up.
ratfink, Apr 12 2006 @ 10:14 AMI did that to mine a couple of years ago, but I can't see my needle worth a crap. Let me know if you figure out a solution.
chris2992, Apr 12 2006, 11:08 AMI have no problem with seeing mine, it is kinda purpleish in color, but can see it fine.
+1.gif +1.gif +1.gif to Chris' reply.
They're kinda purple but they are more noticeable than in the picture. The camera is a bit stingy with the actual look of the needles. They're not bright orange as stock, but still quite legible at night, purple they are, yes.
pseal, Apr 12 2006, 09:45 AMHow much did each cost?  On the following product page, the top three all appear similar, with prices of 0.89, 0.79, and 1.49; just wondering exactly which ones you got.
D'oh. Dumb me; the first two are red and amber only.
Payne
Sorry, but I'm an idiot. I can't figure out which ones you bought. Would you please be so kind as to post the part number(s)?
Thanks.
Lobster, Apr 12 2006, 12:48 PMSorry, but I'm an idiot.  I can't figure out which ones you bought.  Would you please be so kind as to post the part number(s)?
Thanks.
pseal, Apr 12 2006, 08:45 AMhttp://www.superbrightleds.com/cgi-bin/sto...8.26576&next=50
4th Bulb down in the link. WLED 4-LED bulb
chris2992, Apr 12 2006, 01:27 PM4th Bulb down in the link. WLED 4-LED bulb
Oh, you got the ones with the 4 LEDs?
Like this:
I got these puppies and they're quite bright even though they only have 1 LED in them.
I really like the wide angle tip, it illuminates the gauge face evenly:
I was concerned that the 4-LED ones would be TOO bright at night and thus be distracting. The ones I wound up with are perfect, IMO.
Yes I have the 4 led ones, they aren't too bright, but emit an even light. Our pictures look almost identical, mine is a bit brighter, but that is likely the camera and I was in a pitch black garage.
chris2992, Apr 12 2006, 02:24 PMYes I have the 4 led ones, they aren't too bright, but emit an even light. Our pictures look almost identical, mine is a bit brighter, but that is likely the camera and I was in a pitch black garage.
Would these bulbs be called "combination meter bulbs" in the manual on page 19-9?
I take it that removal of the front cowl etc. is required to do this?
On page 19-9 it shows a removed bulb in the lower pic. Are those the ones you are talking about replacing?
Thanks Veefer and Chris. I wonder if the difference in the LEDs created the difference in ability to see your respective tach / speedo needles?
teleskier, Apr 12 2006, 03:26 PMWould these bulbs be called "combination meter bulbs" in the manual on page 19-9?
No, on page 19-9 those would be the turnsignal indicator bulbs as shown.
Look on page 19-11 and in the top pic, it shows the backside of the meter panel. The top two bulbs are the turnsignal indicators, the bottom 4 (real close together) are the idiot warning lights. It's the "other" 5 that light up the gauges.
Of course, there's nothing to stop you from changing the 6 (total) indicator and idiot lights to LEDs, but since they shine through coloured lenses, you would probably want to use white LEDs for them and blue/red whatever colour you prefer for the gauge faces.
There are 3-10mm nuts that hold the instrument cluster to the upper fairing stay. I removed these and pulled the cluster loose to facilitate changing the bulbs more easily.
veefer800canuck, Apr 12 2006, 05:57 PMNo, on page 19-9 those would be the turnsignal indicator bulbs as shown.
And don't put the blue LEDs in the turn signal holes. With the amber lense it turns green, and you CANNOT see it in daylight. You think it is a pain taking the front cowl off once? Put them in the signals, and you get to take it off twice.
chris2992, Apr 12 2006, 04:24 PMYes I have the 4 led ones, they aren't too bright, but emit an even light. Our pictures look almost identical, mine is a bit brighter, but that is likely the camera and I was in a pitch black garage.
Ok maybe another dumb question unsure.gif , im getting ready to order the bulbs, how many do i need?
im going to order both colors to see what the red look like..
thanks
Michael
6, I orders 7 for a spare and used it as one of the 6 didn't work. But after Veefers post on polarity, I'm thinking that I didn't turn the bulb around and that could have been the problem.
chris2992, Apr 13 2006, 10:05 AM6, I orders 7 for a spare and used it as one of the 6 didn't work. But after Veefers post on polarity, I'm thinking that I didn't turn the bulb around and that could have been the problem.
Thanks Chris, i will order 6 of each color (Red / Blue) and check them out...
thanks
Michael
didn't the original post say you needed 5? that is how many I ordered.
Maybe I am wrong, but I am almost confident that there were 2 bulbs for each display (tach, speedo and LCD). Fuzzily recalling that maybe the tach and the speedo shared a bulb in the middle?? Veefer??
teleskier, Apr 13 2006, 09:49 AMdidn't the original post say you needed 5? that is how many I ordered.
Page 19-11 in the service manual shows 5 (as well as the two for turn signal indicators.)
Payne
veefer800canuck
loufuhi veefer,
from ur pix it shows tat ur gauges all shown in KMH, u got it changed or its a stock gauge?? i would like to have mine in KMH n not MPH....
PS: oso anywea i can get a service manual for my 5th gen?? i would like to try out the LED mods too...
Hi, welcome to the forum.
The gauges are stock, we in Canada have embraced the Metric system.
You might find a set of used Metric gauges on EBAY, good luck!
Also, the service manual can be found in the Downloads section: http://www.vfrdiscussion.com/forum/index.p...um=10&st=10
thx alot... mayb i'll juz hav to get use to the miles system odometer n tripmeter... coz at least the consolation i hav is my speedo is in KMH... tis is important to prevent me from gettin the speeding tix... :fing02:
oh ya, and also the prev owner din teach me how to reset the tripmeter... any gd souls out there to enlighten me?
loufuoh ya, and also the prev owner din teach me how to reset the tripmeter... any gd souls out there to enlighten me?
Press and hold the TRIP button on the RH side of the dash to reset.
Pressing the TRIP button for only a moment switches between A and B tripmeters, but a long press resets whichever is currently on display, but not the other one.
veefer800canuckPress and hold the TRIP button on the RH side of the dash to reset.
thk you so much.. i guessed so too, but it juz didnt reset when i did a long press.. mayb my button is not working...
i've just fitted them on mine the inverted type
excuse the quality i took this on my phone and its useless in the dark
[image: gallery_14529_3902_4400.jpg]
where have you guys got the rev counter dial faces from with the vfr emblem on
Edited June 11, 2008 by scottyrocket
veefer800canuckThe inverted-tip causes the LEDs to emit a broad beam which avoids "spotlighting" the gauge face near where each bulb is located.
I don't think you would have any bright spots anyway. Interesting that if you look at the spec, you'll see the bulbs you chose have the narrowest beam pattern of all possible configurations. Only 32 degrees. I was more interested in the colour. I've just ordered some LEDs for my RWB 6th gen, and I ordered 2 different sets to compare colour and brightness. I'm planning on cluging up a dimmer when I do the surgery.
Of course, I'll do a write up with pics for anyone who's interested.
I ordered white LED replacements for my dash today, I dont care about changing the color I just wanted to save a few watts and help extend the life of my stator, ordered the mini ones too for the nuetral, highbeem, fi lights too, I ordered an extra of each type in case I get bad ones
6 | WLED-x4 LED bulb | $ 2.59 |
90 Degree White WLED-W4-x 1.00 - DASH BACKLIGHTING
3 | WLED-xHP High Power LED bulb | $ 4.95 |
Pure White WLED-WHP - TURN SIGNALS
5 | 24-xHP Wedge Base LED bulb | $ 2.49 |
White 24-WHP - FI, NUETRAL, OIL PRESSURE, HI BEAM indicators
HispanicSlammer
Recommend not to change the FI bulb - since the resistance is so low on the LED's the PCM will assume its blown
rest should be fine. I had done the same. they look great - have put the 6 LED bulbs on the dash - they are nice and bright.
Will post pictures later
If a bulb is blown its resistance is infinite high? How can low impedence give you a blown indication? Do you mean the opposite? They probably have a 470 ohm reisister in there. I have been changing these darned things out seems like twice a year now, LEDs and 100,000 hours sounds much better to me. IF THE FI LIGHT IS BLOWN how does the ECM deal with that, is this just speculation? Dont tell me the fi light comes on HEH :cheerleader:
HispanicSlammer
You are right - its the other way around...brain :biggrin: not thinking straight in the heat of excitement :goofy:
Just a speculation - let me know if it works for you
AnikMankar
HispanicSlammer
If a bulb is blown its resistance is infinite high? How can low impedence give you a blown indication? Do you mean the opposite? They probably have a 470 ohm reisister in there. I have been changing these darned things out seems like twice a year now, LEDs and 100,000 hours sounds much better to me. IF THE FI LIGHT IS BLOWN how does the ECM deal with that, is this just speculation? Dont tell me the fi light comes on HEH +1.gif
You are right - its the other way around...brain :beatdeadhorse: not thinking straight in the heat of excitement :cheerleader:
I could see the fi light error pulses comming in at a different pace, or issues with that perhaps? I will try it, they do match the impedence with the led bulbs to the OEM bulbs with a built in resister, its right there in the photo.
[image: post-491-126882678901.jpg]
scottyrocket
Late to the party on this one, but the 2000-2001 VFRs had the VFR emblem on the tach as standard.
I've been looking for one for quite awhile, but every one that comes up on EBAY is worth an arm and a leg.
Veefer800Canuck
I did the same thing when I built my bike, Rob. I loved the look of the later gauges (and had to have that little VFR logo) and went through multiple clusters on ebay before I had the proper combination (it seemed like I could only find metric units for some reason). I wonder how many other '98-'99 owners have updated to the newer gauges?
Guys, just send member Throttlepimp a PM. He does excellent work & can make you any gauge faces you want! +1.gif
Have used these
LED 8
to get this
[image: gallery_16926_4827_228646.jpg]
Dashboard
regards
Anik
SEBSPEED
Guys, just send member Throttlepimp a PM. He does excellent work & can make you any gauge faces you want! :laughing6-hehe:
+1!! Custom 6th gen tach face thread coming soon!
Ryanme17
SEBSPEED
Guys, just send member Throttlepimp a PM. He does excellent work & can make you any gauge faces you want! :fing02:
:dry: He's a stand up guy! :laughing6-hehe:
weaselphd
chris29926, I orders 7 for a spare and used it as one of the 6 didn't work. But after Veefers post on polarity, I'm thinking that I didn't turn the bulb around and that could have been the problem.
thanks
Michael
I went with Red just to be something other then blue
Has anyone ever done this LED dash light mod with UV light (black light)?
TNRabbit
.....guess not.
I've ordered 5 UV lights to give that a try & see how it turns out. In theory, it should really POP!
Edited July 11, 2013 by TNRabbit
Replaced the signal indicator & LCD backlight bulbs with LEDs on my bike this week; blue for the LCD & amber for the turn signal indicators:
Looks great! 3 of the 5 instrument bulbs were burned out so I can now see how fast I'm going at night~
[image: 20130712_213106_zps888bdf3d.jpg]
I'm thinking about trying UV (black) light LEDs to see if it gives the instruments any additional "pop"..
TNRabbit
Did you ever try this?
I have trouble seeing my gauge needles at night with the blue leds, should I just get brighter LEDs or?
White.
Blue behind the LCD.
You could try red, since the needles are red. The red plastic filters out all the colors except red if you are using incandescent bulbs. By using blue LEDs there is no red to come through. That's my understanding of it anyway. That's why you should use red LEDs for red lenses, amber for amber, etc.
I just ordered 6 of the lights in Amber. Should go nice with the yellow bike. I hope. Ha ha.
I'll send pics in of the progress when they arrive. I won't be doing them for a few weeks yet, but when they go in I'll get snapping.
KevCarver
White.
+1
LEDs have very narrow wavelengths of emitted light. Even the white LEDs don't have a lot of red in them so you should use the red LEDs through red lens otherwise they will be dimmer. White LEDs are a mixture of a few wavelengths that the eyes perceive as white but they don't cover the full spectrum. There's more available red light to reflect off a red needle using a red LED so it should stand out more... at least the physics makes sense...
Amber LED on a red needle might make the needle look black because there is little or no red wavelength to be reflected... kinda like how tropical fish lose there color the deeper you go and the other wavelengths of light are filtered out by the water... shine a light on them with the right wavelengths and the colors pop
Quote from TheLEDLight.com, "...using colored LEDs to illuminate similarly colored lenses produces better visibility and overall appearance."
End of thread · 55 posts recovered Wayback Machine snapshot 5 Jul 2022
