[image: med_gallery_7194_2513_32106.jpg]
Here are some photos of the core and exhaust. i reckon i can just reuse the old packing but if it don't work then my dad is a fiber glassier by trade so i have easy access to that
Well I have cut the end off the can and have pulled out the baffle, i am going to tack the end back on the can with no baffels in just to see what is sounds like, just the metal can, nothing else. should be LOUD! almost defiantly to loud but is just an experiment.
The baffel has 3 chambers with the exhaust entering int the first chamber, passing through a pipe into the 3rd chamber, then back into the middle chamber and then through a pipe out the end of the exhaust.
Above is the shell, core and packing
[image: med_gallery_7194_2513_6539.jpg]
this is the flow of the exhaust, this photo was taken after i cut the end off the core. The RED shows the path of the original exhasut gasses and the BLUE shows the path that the gasses will follow when its complete.
[image: med_gallery_7194_2513_49328.jpg]
this is looking down the baffle with the end cut off, the tube on the right will be the only one that is used now
i went and bought some stainless tig welding rods today so am all set to tack the end cap on and see what just the can sounds like. I'm aware that it will most likely be ungodly loud and may rob some power but its just an experiment.
good idea about buying a core from an exhaust manufacturer, never thought of that. will keep that in mind if the cut baffle sounds like crap
I cut the last cap off, the one near the exit of the pipe, so i am essentially reducing the baffle from 3 chambers to 1. may still be to loud but i got the exhaust 2nd hand for cheap so i don't mind to much if it all goes pear shaped.
if some one could pm me or send me an email on how to post photos i should be able to get them on the site.
if any one was thinking of doing this pm me with any questions
will finish off my little project on Saturday, as i have to go but some stainless rods so i can TIG it up.
