ss_burns, Mar 2 2007, 01:57 PMok, just to clarify... Smokey, your bike is a 94? if so, that's 4th gen (look for the NACA ducts!) .. Jamie's (ebay) shock is setup for a 3rd gen.. anyone know for sure if the mounts are the same? I thought they were different, but I could be wrong.
You are correct. They are different. The part Jamie made was to make a new bottom mount, where Smokey would need the spacer added for the top mount.
SmokeyDP, Mar 2 2007, 02:00 PMYeah my bike is a 94....
Stock, what suspension settings do I have that can be changed on the bike? I assume the forks have no adjustments?
Forks are adjustable for preload only. The OEM shock is adjustable for preload and rebound damping. The 929 shock adds compression damping.
You can get the stock one rebuilt with a new spring, oil, and seals, and it will perform as well as it did when it was new. You can also get a "gold valve" added from a place like Race Tech to get a little better action, but you don't gain any more adjustment.
You can go to Race Tech's web site, and they have a "thing" that shows you all that they offer for your particular bike. There is also a spring rate calculator there.
As far as aftermarket goes, Ohlins no longer makes a shock for us. You are left with Penske, Wilbers, Hyperpro, Teleflex, and possibly others. The four I listed make the shock custom for you, and most have a menu of options. So, you could start in the $4-500 range, and go up to $1200, depending on the options. Penske seems the most expensive for what you get. IMO, Roger has enough money, so I gave mine to the "little guy".
We hashed a lot of this stuff out recently,
(HERE) and
(HERE)and many of us went with Wilbers at the end of last year. I went for the full-boat one with almost all the options. I am still working on a better permanent installation, but after my test ride, I'm amazed at the difference. I can also vouch for excellent customer service. I had a problem finding a good spot to mount the remote reservoir, and I worked with Klaus from Wilbers via phone and email. He just sent me a nice bracket today, and I didn't even have to ask. He just said to let me know how it works, or if it needs any modification. That scored big points in my book!
