How To Ride In The Cold...
38 posts Started 3 Nov 2007 Last recovered post 29 Jan 2008 Wayback Machine snapshot 11 May 2016
I installed and tested the grip warmers tonight and I can't believe I've ridden sixteen years without them.
One of the best "Bang for the Buck" mods out there.
I headed out and it was 45 degrees which I can handle without warmers, so it wasn't bad. Felt good to try out the new warmers and see how they work.
The ride home was 33 degrees, and the warmers were definately helpful. Along with all my riding gear (layers), I was very comfortable and could've ridden a long distance in relative comfort if I had to. The half hour ride home was great.
I was actually surprised how hot the grips get. Riding through town the High setting was too hot, so I switched to low. But on the highway, the hot setting was perfectly adequate to do the job.
Here's what I wear whenever the temps get below 50 degrees. It took a while to figure out what works best. The key is layers and making sure there's no exposed skin. The Under Armor is awesome. It's like a second set of skin. But you have to use the tight fitting synthetic stuff that's not very breathable, it works the best. Here's what makes me comfortable down to at least 30 degrees:
Under Armor
Cotton T Shirt
Turtle Neck Sweater
Icon Leather Jacket w/ Liner (Sleeves of liner cut off so my arms aren't too bulky w/ the sweater, etc.)
Icon Timax Gloves
Balaclava (like a ski mask, w/ no mouth hole and one oval eyeport made of synthetic material)
Icon Helmet
Sweat Pants Under Jeans
Boots w/ Thick Cotton Socks
Symtec Grip Heaters
Every year I will ride regularly until the first real snowstorm brings out the salt and sand trucks. Then the road surface is pretty much shot until spring. I'll still ride on the occasional nice mid-winter day though.
Goodnight...
Gerbing heated jacket liner and gloves get me through the cold. As far as socks go, I've been using the socks by BMW that wick the moisture away from your skin. REI also sells some nice socks.
Nice post, Alien TLR. Your cold weather gear list sounds similar to mine. I don't have any heated gear, or grip warmers for that matter. But for most rides between 30F and 50F, I'm wearing:
long-johns under my jeans, plus for longer rides rain pants over jeans
heavy socks with some wool content and maybe a pair of thin dress socks under those
long-johns shirt under turtleneck or mock turtleneck
pair of winter windproof/waterproof gloves
windproof balaclava plus maybe a scarf for a bit more warmth
my usual leather jacket with or without liner, depending on how cold it is
Gotta say the windproof balaclava is awesome. I couldn't ride in cold temps without it. It's amazing how quickly your chin gets cold, and just a scarf won't help that.
And if I get a little too warm wearing all this stuff during a longer ride, no problem - I just open the zippered jacket vents for awhile and maybe stow the rain pants, plus I'll always carry my regular leather gloves so I can also stow the winter ones.
Rode to work yesterday with 26f showing on the dash thermo. Chilly but not unbearable. My Sidi Doha boots dont really cut it, but my legs are warm thanks to Joe Rocket Alter Ego pants. I love those things!! Worn over khakis even without the liner zipped in they were warm enough. My MotoGP jacket has a few zip in layers which make it perfectly warm over a t shirt. Ditto on the balaclava! (any suggestions?? I use a silky one from wal mart cuz its the only thing thin enough to fit under my helmet. When I use the "real deal" designed for motorcycles it just doesnt fit under my helmet....any ideas?) Any suggestions on gloves? Mine dont cut it under 35 degrees. <_<
:beer:
Love the Gerbing jacket liner and have their socks too for the really cold days. Heated grips, long john bottoms, a long sleeve turtle neck my leather pants and jacket, balaclavas and I'm good into the 20's(start out) and run my 3-400 mile loops.
Feet have been the biggest problem w/o heated socks until I finally bought some water proof boots that have so insulation in them too.
On the really cold days I throw my rain coat over everything else as a wind break that works fantastic!
Ride on! :thumbsup:
I've riding to work every day to keep from burning gas in my truck, and it's been getting chilly this week with temps in the 20's every morning.
I stay pretty warm, the only piece of gear I'm missing is a balaclava; my nose, cheeks and forehead get pretty cold.
Otherwise I wear:
-long sleeve tee with a regular tee over it
-jeans
-thick cotton socks
-Icon mainframe helmet
-Schampa fleece neckie(the bandanna kind)
-Tour Master Advanced 3/4 jacket w/ liner in(REAL warm, even in the 20's I get to work with almost sweaty pits...)
-Joe Rocket Alter Ego pants - I haven't been using the rain liner, because it's a pain to get them on over jeans with the liner in, but I find just having
the extra layer and especially the knee pads helps a lot!
-Alpinestars Storm gloves
-Oxtar TCS Evo boots, they're not perf'd, so they do a good job at blocking the wind. I keep a pair of steel toe boots at work to change into.
I'm also using grip heaters, they do make a world of difference. Another thing I'm thinking about is Slammer's heated seat mod, being that the kits are cheap, and somehow all the cold air spills over the screen and tank directly into my crotch... :joystick:
I installed a digital temp contoller when I installed my grips. It gives you so much more control than a HI/LOW switch. I mounted it on the left "wing" of the panel. It works by cycling full power on and off to the grips. Full high leaves the power on constantly. The slowest setting cycles the power on for about 1/10 of a second and off for a full second. It gives a very wide heat range. Another great thing is that it actually cycles power and does not simply dump heat (and power) wherever you hide the resistor.
Available, of course, at Aerostitch/RiderWearhouse.
I'm in NC...was 29 the other morning. But warms up quick. I wear alot less than the other it seems.
Jacket w/ liner..golf shirt (work).
Joe Rocket gloves..non insulated but they do great
Jeans or Khaki's with thermal pants
Shoes or Sneakers with Columbia winter socks
Balaclava...is a must and key to being warm...if your face is cold everything else seems cold and make the worse
I think I have more insulation than everyone else..I weigh 280lbs and it helps
For long rides in cold weather, I also use the foot warmer inserts. At a stop, you can feel the warmth. At speed, your toes don't get so cold.
Another vote for the Gerbings here.
Last year I had to ride 400 miles in 35 degrees to get home with only heated grips and not nearly enough clothes. As soon as I parked the bike I walked inside the house and ordered the Gerbings. No more freezing rides....gloves are next.
I tried the gloves and hated them... my hands slid around too much in them. I just wear thick leather and use the heated grips. I think over the last year I have become winterized http://www.vfrdiscus...tyle_emoticons/default/smile.gif
I tried on a pair of the Gerbing G3's and will agree with you on the sliding bit but last weekend at the cycle show I tried on a pair of Powerlet gloves. They felt much better like a standard pair of gloves in my opinion.
Ohhhh.... I will have to check them out!!! Thanks!
My experience, if you not only want to be warm but stay warm, stay away from cotton. Layer with synthetics and if ya add heated gear, ride'n below freezing is no problem...Other than traction. http://www.vfrdiscus...tyle_emoticons/default/+1.gif
I decided long ago that the best solution to deal with cold weather riding: Move to where there's no cold weather !! :thumbsup:
Olympia AST jacket with the lining
heated grips - soooooooo good
turtle neck sweater.
Darien pants.
Duofold expedition long underwear.
Technic boots.
good for at least 25 degrees and windy.
good enough for over the Delaware Memorial bridge on cold windy days.
snow, fugedaboutit.
the rainpants as overalls is intriguing.
I like Darthbling's approach to cold weather riding for your hands and lower arms. Heated handgrips plus handlebar mits. Combined cost of $40 for weather proof sleeves with wool lining to keep the heat on the hands.
Add to that I wear:
Cortech Sport XL will full liner
Moteck Winter gloves
Wool socks over cotton ones
Joe Rocket 2.0 overpants
and the usual under gear such as t-shirts, thermal undies, etc
The worst I have suffered is cold toes and am seriously contemplating some heated socks or insulated riding boots but that is usually only a concern once the temps hit the mid 30's here. And I ride year round unless there is snow on the roads.
I rarely ride in cold weather except on tour. Sometimes in the Winter the temps can drop in the 30s at 6K ft in the San Diego MTs but mostly it never drops below 40.
Our tour I find repetitive days in the cold can beat you up. UP and over the Sierras a couple of times can get cold.
[image: med_gallery_2144_2004_750125.jpg]
My current cold weather/tour setup:
[image: 2696083820099738507S600x600Q85.jpg]
  • Two Piece Aerostich RC
  • Synthetic thin long underwear……and maybe another thin layer on top.
  • Wood/synthetic blend hiking socks with Goretex touring boots
  • Grip heaters .........also use wool glove inserts or winter lined Goretex gloves. I also have the Aerostich Goretex mittens in reserve.
  • Bicycle arm and leg warmers which you can pull off without totally disrobing when it warms a bit
  • Aerostich windproof electric vest
  • Helmet liner
I also slow down and if it really looks to be cold I take this!
[image: 2603892360099738507S600x600Q85.jpg]
vanion2I like Darthbling's approach to cold weather riding for your hands and lower arms. Heated handgrips plus handlebar mits. Combined cost of $40 for weather proof sleeves with wool lining to keep the heat on the hands.
Just some generic ATV handlebar mitts. Available in camo too. :P
[image: tn_gallery_4208_389_434095.jpg] [image: tn_gallery_4208_389_252767.jpg] [image: tn_gallery_4208_389_443210.jpg]
The mitts work pretty well, but I stopped using them. The material is pretty flimsy and it's kinda tight inside the mitts to reach all the controls. I find it's too much of hassle to take them on and off all the the time. I didn't like using them in town because if you take you hands off the bars, say at a red light, it's hard to get your hands back into the mitts quickly. Plus, since I have an electric cruise control, the mitts had a bad habit of pressing against the front brake lever from the wind which would cause my cruise control to disengage.
I'm thinking my next 'mod' would be to craft a set of homemade handlebar mitts to solve these issues. Then I can leave them on the bike all winter. :D
Edited 16 Nov 2007 by Darth Bling
Hey - Good to know I am not the only one who rides in the Winter. I am in NYC and it can get pretty cold here. I am usually good up to 40 degrees providing the wind is not too crazy. I gotta get some heated grips, but aside from that I do ok with: under armour tee, long sleeve cotton shirt, Tourmaster Decker Leather pants (with knee and hip CE armour), AlpineStars Gore-Tex boots (with wool socks), First Gear Fire Leather Jacket w/neck warmer and thermal lining, (sometimes I wear my naked leather crusier jacket with a full sleeved thermal liner, or my Fieldsheer MottoBar Textile jacket, or my Cortech Denim riding jacket w/ thermal lining) and I cannot forget my TourMaster Winter Elite gloves (great gloves for winter riding). I am going to be upgrading to some Frank Thomas gear soon when I get some cash.
It's too bad that Honda doesn't make a clip on handguard. I've often thought that if I just had a shield that diverted the induced wind my hands would stay warm. Kind of like the ones you see on dual purpose bikes.
Did you guys by Honda or aftermarket grip heaters?
Well, I can sit around no more. I'm getting ready to go ride two bikes on 80 mile twistie runs in 32 degree weather. One bike has heated grips the other doesn't.
I'll just layer up, enjoy the empty roads then fill up the hot whirlpool tub... :rolleyes:
BentWell, I can sit around no more. I'm getting ready to go ride two bikes on 80 mile twistie runs in 32 degree weather. One bike has heated grips the other doesn't.
I'll just layer up, enjoy the empty roads then fill up the hot whirlpool tub... :goofy:
Rode before daylight (26 degrees), then it had warmed up to a "toasty" 33 degrees after I got back after sunrise......a little "nippy"............... :goofy:
skuuter trash
Me too... rode in the 25 degree weather this AM... but I was not cold with the gerbings gear smile.gif I got some weird looks from the cagers...
house
skuuter trash
I get those every day.......... :P
johngaIt's too bad that Honda doesn't make a clip on handguard. I've often thought that if I just had a shield that diverted the induced wind my hands would stay warm. Kind of like the ones you see on dual purpose bikes.
A friend put a set of off road hand guards on his RC51 and he said it made a world of difference in keeping the hands warm. I've looked at several brands but there is absolutely no room to mount them on my '02 bars.
Did 190+ miles yesterday in from 32 to 26 degree weather (26 on top of the mountain). Just layered up and enjoyed nobody being on the roads. Couldn't have ridden all day though without another layer. Going to check out some good "underwear" as a better first layer though. Ride on.... +1.gif
BentDid 190+ miles yesterday in from 32 to 26 degree weather (26 on top of the mountain). Just layered up and enjoyed nobody being on the roads. Couldn't have ridden all day though without another layer. Going to check out some good "underwear" as a better first layer though. Ride on.... +1.gif
No pics please................ :P
Aftermarket, Symtec, see my installation thread: http://www.vfrdiscussion.com/forum/index.php?showtopic=37220
They're working great. +1 for Gerbing stuff.
skuuter trash
fake Old Navy underarmor
sweatpants
fleece balaclava
Rev It pants with liner in
Tourmaster Cortech with liner in
Powerlet Proform heated gloves
Gerbing socks with top elements only
still need overgloves and rain booties
I just bought the heated gloves and a dual temp controller from Powerlet at the Seattle MC Show, then meandered over to the Gerbing booth to buy socks (since Powerlet doesn't make 'em yet), where I learned that I had saved $30 by getting the dual controller from Powerlet. Sweet.
My legs and core never get too cold as long as I layer up properly, but hands and feet were bitterly cold last March riding in a Colorado sleet storm, even with the "water-proof" boots and gloves I had then. HA! They didn't let any water escape... <_<
radMy experience, if you not only want to be warm but stay warm, stay away from cotton. Layer with synthetics and if ya add heated gear, ride'n below freezing is no problem...Other than traction. :goofy:
:beer: on that!!! I don't have much experience riding in cold weather, but my camping experience tells me that a single layer of cotton will make you freeze your tail off!
Layer with synthetics, silk, or wool, and you will be much better off.
I am bringing up this topic again because my gloves suck! Actually they are fine to 35 or so, when combined with the heated grips, but my fingers totally freeze after that. The heated grips keep my hands warm but not my fingers.
Anyone have a review on the Powerlet gloves? I might try them if they are pretty good.
I have found that a sweatshirt under my MotoGP jacket(not leather) with the rain insert keeps me fairly warm, only where the jacket zips together do I feel the cold. MotoGP overpants with quilted liner keep my legs warm enough, I start to feel the cold at 25 degrees, but not uncomfortable. Socks take care of the worst of the feet issue, I haven't needed to upgrade to wool there yet.
I added some el-cheapo grip heaters from Cycle Gear (the resistor type with the same size clutch and throttle side pad sizes) but the difference was amazing, I don't have to wear my heavy winter gloves when it's only 45 anymore smile.gif The install was pretty easy and I got to get some new grips that have a pretty good matching yellow in them :salesman: Definitely worth the $40 investment (with grips)
Alien TLRI installed and tested the grip warmers tonight and I can't believe I've ridden sixteen years without them.
Under Armor
Cotton T Shirt
Turtle Neck Sweater
Icon Timax Gloves
Icon Helmet
Symtec Grip Heaters
Goodnight...
Sorry about not reading any posts but yours.. I've never tried grip warmers, and have ridden in 0 degree climates daily for years with just a heated stitch vest (5 years worth of winters), and I think that warming the core, the spot with most of your circulating blood helps the most. Although, I'd think that the couple of times I got to my destination with hurting cold numb hands should have prompted me to get the grip heaters long ago!
I freeze below 40F as all my gear is built for hot weather riding out here in AZ. But when I lived in Michigan I wore a thick traditional leather biker jacket with a sweatshirt and long johns underneath, leather chaps, pants and long johns. Some water proof snowmobiling boots, bacalava and gloves finished me off. I often rode in 25-40 degrees dressed up like that.
Anyone have the Motoport liners? They are suppossed to be rated down into the negatives and are waterproof.... I should just buy them as I already have the mesh pants and jacket.
I usually just put my Fieldsheer 1 piece suit over jeans and a sweater. I have a fleece pullover I like to wear to keep my neck warm, and that's pretty much it. In combo with Dual Star heated grips, it's helped me keep riding to work. Last Friday morning, it was 23 degrees.
magellanfake Old Navy underarmor
sweatpants
fleece balaclava
REALLY?
aA LITTLE MORE THAN THAT TOO...
I DO NOT REMEMBER WHY (With this 130 pound 5 foot 9 inch tall blond maniac woman over my souldr - seeing me type... so, you know what she is gonna lead to after I'm ffinnissheedeed typing 2 U, U know what I meanszzZ?, right?
It was due to the CORE being cold is all...
rickdick80
TracTTTion? :thumbsup:
Thats all you need for those situationzS!
:goofy: on that!!! I don't have much experience riding in cold weather, but my camping experience tells me that a single layer of cotton will make you freeze your tail off!
TightwadI am bringing up this topic again because my gloves suck! Actually they are fine to 35 or so, when combined with the heated grips, but my fingers totally freeze after that. The heated grips keep my hands warm but not my fingers.
No!
Although, If they can still be found, then the under-the-grips-generic-or-name-brand heated grips will (I've tried them on my BuDDies Bike's-plural-solved any problem... point blAnk!!!
Always be sure to keep the leather ON!!!
Ducatti20I freeze below 40F as all my gear is built for hot weather riding out here in AZ. But when I lived in Michigan I wore a thick traditional leather biker jacket with a sweatshirt and long johns underneath, leather chaps, pants and long johns. Some water proof snowmobiling boots, bacalava and gloves finished me off. I often rode in 25-40 degrees dressed up like that.
Just get a heated vest . Just be sure to check the zippers out before you purchase, unless... Get the Stitch. They have ike 4 versions... Get the vest with the most warmth/draw from the battery!
End of thread · 38 posts recovered Wayback Machine snapshot 11 May 2016
