I had a couple hours free this morning, so I decided to experiment a bit.
First, I removed the exhaust for the first time and fired it up. It had a nice growl at idle but was very loud and raspy otherwise.
Then I stuck a piece of flexible exhaust pipe on it - same result.
What really made the difference was the automobile performance exhaust I connected to the flexipipe. It now produces a rich throaty roar from idle, all the way up through the powerband. Even when accelerating hard, it still sounds deep and rich while not excessively loud. (Please ignore the temporary mounting bracket)
Besides the tremendous improvement in sound, it replaces 19lbs of exhaust placed high up under the tail with 6lbs of exhaust down low to the ground. The total cost of the retrofit was $51.
For now anyway, I'll keep it on the bike and play with it. Perhaps in the future I'll buy another can and fabricate an undertail exhaust that still weighs considerably less than stock, sounds great and won't break the bank.
Does anyone else have a 4" pipe opening on their can?
How To Make Your 6th Gen Roar
30 posts Started 25 Jul 2008 Last recovered post 4 Sep 2008 Wayback Machine snapshot 10 Jun 2012
:schla15:
[image: View Post]cigarbuf, on Jul 25 2008, 11:00 AM, said:
I had a couple hours free this morning, so I decided to experiment a bit.For now anyway, I'll keep it on the bike and play with it. Perhaps in the future I'll buy another can and fabricate an undertail exhaust that still weighs considerably less than stock, sounds great and won't break the bank.
I did this back around 2003 with an el cheapo set of D&D's I got off ebay. Had a muffler shop make me a mid-pipe to make it a 4-1 so left can was a dummy. Put on a nicer lower clamp after pic was taken:
Custom D&D pipes
I love cheap mods but wouldn't go your route for stylistic reasons.
Cheese and rice dude,now that's a can! :schla15: Prolly sounds AWESOME at speed! :schla15:
I am picturing a dual set of those in place of the stock undertail mufflers... :schla15:
That's the best mod I have seen thus far. :schla15: Keep up the good work. :schla15: :schla15:
I'll give you an A for effort for trying something else. But to be honest, that looks terrible. I know it's just a mock up. But even with a real pipe and slip on..... it still doesn't look good. Just my two cents.
You have too much time on your hands.
But, it does sound good in the clip.
sounds great :schla15:
What diameter flexible pipe works with the VFR?
[image: View Post]aagab, on Jul 25 2008, 02:42 PM, said:
What diameter flexible pipe works with the VFR?That does sound really, really sweet. However, I say forget the stupid looking flexpipe and have an exhaust shop bend you a real piece of pipe to fit. Obviously that is a pretty free-flowing set up (perhaps too much) but ribbed piping is always going to flow worse than flat piping, also, the flexible pipe looks plasticy.
Quote
That does sound really, really sweet. However, I say forget the stupid looking flexpipe and have an exhaust shop bend you a real piece of pipe to fit. Obviously that is a pretty free-flowing set up (perhaps too much) but ribbed piping is always going to flow worse than flat piping, also, the flexible pipe looks plasticy.The project is only an experiment and I have no intention of leaving the exhaust on the bike as it is.
It does make me think that if I could find some off-the-shelf cans similar to what I have but a bit more "conservative" in appearance, along with some fabrication work on the pipes, I'll end up going that route. The sound generated by the VFR through the 2 1/2" channel in the can is fantastic; similar to the deep tone of my old 900ss with Arrow cans.
FotoMoto did a great job of adapting his D&D cans to his bike. I'd like to see if I can setup an undertail system that sounds great, flows freely, is light weight and a quarter the cost of most systems available today.
[image: View Post]cigarbuf, on Jul 26 2008, 10:19 PM, said:
Quote
Ah, I see. But, like you said, you did lose quite a bit of weight, and the weight added is much lower in the chassis. I think that despite what people say, clean it up a bit (mount it a bit better) and you could certainly keep it that way. Some people prefer side exhaust, others underseat, it's a matter of taste.
That is looking/sounding good. Prior to getting my VFR I seriously looked at the Midnight Warrior just because I loved the exhaust styling. Tried to attach an image...but I failed.
Oooh Nooooo....That's a F&F "Fart Can" you have on that poor bike!!! :angry:
Beck
95 VFR
Beck
95 VFR
I had some spare time today and decided to relocate the exhaust under the tail. The bracket is new and the flex pipe is a bit longer.
Total weight for the single exhaust is actually 5lbs 10oz. I'll add another can to the other side for aesthetics which will bring the total weight to 9lbs 12oz. The flex pipe will soon change color to a bluish brown and will stiffen up as the heat sets the bonding material in the joints.
I know it isn't the most attractive setup out there but it didn't cost much, doesn't weigh much, doesn't restrict much and it sounds absolutely fantastic.
"A" for effort, but I'm not much of a fan of flex pipe.
Great for proof-of concept, but if I were going permanent, I'd have a proper mid-pipe fabricated out of 2" tubing.
Quote
"A" for effort, but I'm not much of a fan of flex pipe.Great for proof-of concept, but if I were going permanent, I'd have a proper mid-pipe fabricated out of 2" tubing.
I'll second that, but a stop at a good muffler shop should bealbe to fix you right up in no time.
:rolleyes:
Gee, why don't you take a geologist's hammer to the Piet� while you're at it?
Or were you once a propmaster for 50's sci-fi flicks?
[image: View Post]Shinigami, on Jul 31 2008, 10:01 PM, said:
Gee, why don't you take a geologist's hammer to the Piet� while you're at it?Or were you once a propmaster for 50's sci-fi flicks?
Now, now, no need to grind the guy so hard! He is experimenting and having fun. I have hillbilly exhaust on my old XJ and am mocking up sportster slipons for it.
+1.
Experimentation is what it's all about, if it's not your taste, fine, but you don't have to knock someone. With a proper piece of tubing instead of the flexpipe that's not a bad, cheap set-up at all. I'm all about the cheap do it yourself methods. Anyone can spend a couple of thousand and have a shop install an aftermarket exhaust, but where's the art in that.
[image: View Post]Tomek, on Jul 25 2008, 06:14 PM, said:
That's the best mod I have seen thus far. :blush: Keep up the good work. :rolleyes: :pissed:F for
fail!
Man,
I like your willingness to try this but wtf? I don't get it. Can I sell you a old Snapper mower that has a muffler that falls off from time to time? Seriously, go with a bike exhaust. That looks so far out of balance and takes away from the single sided swing arm's look. just my 2 cents. JD :biggrin:
[image: View Post]leanit, on Aug 30 2008, 10:16 AM, said:
Man,I like your willingness to try this but wtf? I don't get it. Can I sell you a old Snapper mower that has a muffler that falls off from time to time? Seriously, go with a bike exhaust. That looks so far out of balance and takes away from the single sided swing arm's look. just my 2 cents. JD :biggrin: I second that. Maybe you can mount two of those under the seat and get rid of that fender. :blink: VFRs look good in the original configuration. Don't go Pep Boys on your bike. Keep it looking cool. :huh:
I did finish the exhaust by putting it undertail with a dummy can on the other side. If I could have found some inexpensive cans with a little more conventional look, I would have gone that route. Even though it started as just an experiment, I'll probably keep it on the bike at least for a while. The sound is fantastic; not too loud but with a very throaty roar. Weight from stock is reduced by half and the entire setup cost only about a hundred bucks.
Exhaust Finished
Exhaust Finished
[image: View Post]cigarbuf, on Aug 30 2008, 11:04 AM, said:
I did finish the exhaust by putting it undertail with a dummy can on the other side. If I could have found some inexpensive cans with a little more conventional look, I would have gone that route. Even though it started as just an experiment, I'll probably keep it on the bike at least for a while. The sound is fantastic; not too loud but with a very throaty roar. Weight from stock is reduced by half and the entire setup cost only about a hundred bucks.[image: Posted Image]
Exhaust Finished
That looks better but was there not a smaller OD of can you could have used? Keep us posted on performance gains and effect on mpg if there is any?
You must not have kids.... cause that is just aching for a golf ball / tennis ball / baseball to be stuffed down there.
I like the flex pipe, not sure about the cans.
[image: View Post]Lee 2002, on Aug 30 2008, 12:27 PM, said:
You must not have kids.... cause that is just aching for a golf ball / tennis ball / baseball to be stuffed down there.I like the flex pipe, not sure about the cans.
I'm wondering if he can get some spring loaded flappers like from a dump truck stack, to keep the rain out?
That is a very unique looking setup....
It's like a Baby B-King with round flare...
[image: View Post]sirimiri, on Aug 30 2008, 03:27 PM, said:
That is a very unique looking setup....It's like a Baby B-King with round flare...
+1
Definitely reminds me of the B-King's monster exhaust! Looks kinda wicked from the back.
End of thread · 30 posts recovered Wayback Machine snapshot 10 Jun 2012
