This one looks cool but it has built-in battery so quite heavy for traveling by VFR:
[image: portable%2Btire%2Binflator.jpg]
[image: Black-Decker-ASI500-Rechargeable-Cordless-Air-Inflator.jpg]
Really don't want this - China one, slow, hot, broken down quickly:
[image: 300x300_b8eefdd4e5bf6a486a7e3c3ad8575c8d.jpg]
Anyone knows about this - quite compact, is that a real Good year?.
[image: Goodyear+i3000.jpg]
This is also cool:
[image: The-Jump-Start-Store_1376.jpg]
GOODYEAR i7000 12 VOLT 130 PSI HEAVY DUTY DIRECT DRIVE FAST INFLATOR WITH WHISPER SOFT TECHNOLOGY
DESIGNED TO INFLATE CAR TIRES, BIKE TIRES, ATV TIRES, SPORTS EQUIPMENT. AIR MATTRESSES, BEACH TOYS AND OTHER INFLATABLES
DIRECT DRIVE INFLATORS HAVE LARGER PUMPING CYLINDERS AND A HIGHER RATE OF AIR VOLUME DELIVERY
POWERFUL, SMOOTH, QUIET AND VIBRATION FREE
HEAVY DUTY WITH FAST AIR DELIVERY OF 30 LITERS PER MINUTE
INFLATES P185/RIR TIRE FROM 0-28 PSI IN 3 MINUTES OR LESS
PLUGS DIRECTLY INTO VEHICLE’S 12 VOLT ACCESSORY OUTLET OR CIGARETTE LIGHTER SOCKET
FEWER MOVING PARTS MAKE THIS INFLATOR LAST LONGER THAN GEAR DRIVEN 12 VOLT INFLATORS
1 FT RUBBER HOSE WHICH CONNECTS TO A 16 FT PVC COIL AIR HOSE
BUILT IN ANALOG PRESSURE GAUGE
TWO COMPARTMENT CARRYING BAG
TWO 15 AMP FUSES
THREE INFLATION ADAPTERS
12 VOLT 10 FT POWER CORD WITH 15 AMP FUSE
QUICK CONNECT COUPLER
BUILT IN 4 LED WORK LIGHT
WEIGHT: 5 LBS
DIMENSIONS: 8”L X 6”H X 3.5”W
MADE BY BON-AIRE
1 YEAR WARRANTY
