6th Gen, Free Extra Storage.
15 posts Started 15 Mar 2009 Last recovered post 3 Jan 2011 Wayback Machine snapshot 27 Mar 2011
Several people have contacted me on how I made my extra storage unit. I thought it easier to just do one how-to.
First remove the right cover, opposite side of the battery. 3 clips.
Here is the piece I made. I made it from a battery cover from a Honda car.
Here is the piece on the bike. The notch on the lower left corner and one zip tie hold it in place very well.
I can then put my slime mini compressor.
Tire plug kit
Assortment of fasteners
I put the compressor in first.
All in my free extra storage space. I wrap everything up in 3 zip lock bags and ck on it every several months. The items are invisible with covers and seat on.
Under the pillion seat I also utilize space to carry break down stuffs and the rest of the compressor parts. I have the power supply and air hose for the compressor. A roll of duct tape. A roll of electrical tape, lot of zip ties
There is a bit of space under the sub frame rail and the plastic as well.
[image: View Post]soichiro, on Mar 15 2009, 06:30 PM, said:
Please move if neccesary.
Several people have contacted me on how I made my extra srorage unit. I thought it easier to just do one how-to.
Brilliant!
Just a reminder boys and girls...make sure anything stored there can take the HEAT... :dry:
Brilliant!
The only problem that I have had with heat was some latex gloves stuck together. I imagine it does get pretty hot there.
Non Abs only. D-oh!!!!!
Cool deal-i-o.
I drilled out the holes on the cover along with the tabs on the frame and added the clips that come on the battery side. It makes for quicker access to the goods stored in there and I don't have to fiddle with the other clips.
Great stuff guys, I've been looking at that spot for a long time as it's one of the few if not only open space on a vtec(non-abs). :biggrin:
THat right side location was where I found the oem tool kit, after 3 years of ownership...... I had bought one as I thought my bike didn't come with one. I've heard that others have found their tool kits there as well.
with ABS the only thing I put on that side is a Powerlet for charging the battery, or running roadside gear...non switched of course.
I guess I'm gonna have to pull that thing off when I get home today and see whats inside. Hmmmmmmm..
For the ABS version I had to go this route:
OOPs, I ddnt even think of the abs being diffirent, sorry. I will alter the title.
It really is a good storage area. It seems to stay realatively dry and clean. I have had the pump there for over a year. I pull everything out every couple months and the pump still works great and nothing has melted even in 100F NC summers.
I did have a set of latex gloves stick together but they werent melted or burned.
You could also put 2 chickens or a pound of the finer columbian back there. What ever suits your fancy, :laugh:
Neat, man! Thank you!
Two chickens? Fo' real? :excl: :biggrin:
filled that spot already with fuseblock and switching for powerlet etc.
Well done with the compressor and patch kit idea tho...
I have added even more stuff. Everything for the plug kit, the compressor and misc. items will fit in the little cubby hole. It's amazing what will go in there if done right. I still havent had any heat issues other than the oiginal pair of hot latex gloves.
It' simple to make and you could put tools, or whatever in the there. It keeps a lot of stuff out of my tank bag. I could fabricate some nice ones and sell if people wanted, It works awesome. Pump is at least 2 years old if not 3 and still works. It stays dry in there.
I guess you could put a speedoheler and a power commander in there. Adding the frt. piece makes it weather resistant. A little dirt, a little heat, thats it.
What size drill bit do you use to be able to make use of the (much sturdier and easier to use) plastic clips like the ones on the battery side???
I�ve been using that spot to store a complete set of spare bulbs in a flip-top plastic tub (the one�s you can get XL packs of chewing gum in) for years now. I have a fuse box aft of the brake fluid reservoir thanks to Wiremybike.com.
End of thread · 15 posts recovered Wayback Machine snapshot 27 Mar 2011
