[image: View Post]JES_VFR, on 05 June 2010 - 04:08 PM, said:
[image: View Post]coderighter, on 05 June 2010 - 02:36 AM, said:
[image: View Post]JES_VFR, on 04 June 2010 - 08:36 PM, said:
I disagree with your saying that the Stock fan works better than the VTR fan when the bike is standing still. Its does not. My fifth gen would just get warmer and warmer if it was sitting idling in the driveway too long with the stock fan. The fan might actually move enough heat around once or twice to cool the bike enough to cycle off, but it would only do it once or twice, then the fan would run continuously and the bike would just keep heating up.
Now the VTR fan kicks in and cycles maybe 17-18 times in a half an hour, but the temp is never above the 223-224 that the fan kicks on at.
Yes the fan pulls from in front of the bike and that means that it gets heat off the exhaust and engine before it gets to the rads, but with VTR fan the heat gets pushed out of the bike. A few seconds after the fan has kicked on the temp is coming down and the momentary blast of heat from the left side vent has lessened.
The stock fan sucks cool air in through the rad and then dump this heated air the engine bay, the heat doesn't travel anywhere really and just warms the entire bike, in an escalating cycle until the display is flashing to get you attention of the impending overheating. To me that just proves that the Stock fan is a turd.
Any you are right no fan that size is going to make a significant contribution to cooling if the bike is traveling faster than 30 mph.
But the point is that the stock fan is a poor design even when the bike is stopped. Keeping heat in the bike is not effective cooling.
I'd rather spend an extra 15-20 seconds moving preheated air out of the bike, than just continuing to pump the heat around the bike.
The absolute best of both worlds would be the pusher vtr fan and ducting that keeps the header and block heated air entirely away from the radiators.
But those ducts are a project full of time and money that I don't have right now, maybe someday when I find someone that will, like there are people that will make those ducts for the rc51's.
Strange, sitting at a long light, if the bike gets to 220, the fan kicks on. The temps immediately start to drop. With in a minute or two the temp hits 210 the fan turns off. I never have a problem stopped. The highest temp I've ever seen stopped is 221 and that was a 100+ degree day in eastern Washington. I'm not sure why you had such a issue with yours. The only time I have problem is if the light turn green while the fan is still running.
I've never experienced the hideous heat vortex of which you speak. However bear in mind if the fan not running, the R/R could be dumping more current, making the frame hotter. It sounds like your fan runs alot more than mine.
By turning fan into a pusher, you lower the efficiency of the fan by 20%, even with the correct fan blades.
http://www.perma-coo...Cat_page16.html
Not only are you pushing hot air across the radiator, you're also pushing about 20% less CFM.
I know that a pusher fan is less efficient than a tractor fan, unless is it's total surface is larger than the total surface of the radiator its has a complete shrouding duct.
But the simple facts are these.
when I had the stock fan blade and I came to a stop on a day like today (the high at 12:45 was 90f out in the open, the heat in traffic was 96f on the cars outside thermometer, and with 55% humidity the heat index was 112.).
Temp would rise to 224 and the fan would kick on, and in 2 or 3 minutes it would have cooled down to 213-214 and the fan would shut off. As soon as the temperature would shut off the temp would start climbing again and in two minutes or so would be right back to 224. The fan would kick on for 5 or 6 minutes this time before it could get the temp down to 213-214 and cycle off. In about a minute (maybe minute and half) the temp would be back to 223 and fan would again come on. From here on the fan would run continuously (with the temp never really coming down), until either I got the bike moving at 30+ mph and clear of the traffic -or- it when past 238, at which point I'd shut off the damn thing, paddle foot it to the side of the road and wait for it to cool off (usually just in time to see the traffic jam start to move).
But since I put the VTR fan on the bike, I never have this problem.
Coolant temp gets to 223, fan kicks on. temp starts to drop. A couple of minutes go by temp drips to 213, fan kicks off. Minutes go by and temp creeps back up to 223, fan kicks on again, temp drops to 213 in a few minutes and fan cycles off.
This cycle will repeat for at least half an hour without the temp climbing above 223 or the fan reaching a state where it can't cool enough to cycle on/off. The on cycles don't appreciatively longer unless the ambient temp also rising (like when you are sitting in that concrete canyon called
Vine st in Philly in the noon day sun, where the outside temperature climbs as you watch!) so I'd say that in practice the superhawk fan is much more effective than the stock fan ever was. Tractor vs pusher fan, drawing air through the bike or not, It just plain works a world better in that concrete oven than the oem fan ever did.
I've seen lots of post describing the same behavior from lots of people on the other VFR Lists so I know it is not just me and my VFR. In fact one of the big disappointments was that Honda supposedly fixed the heating issues with the Vtec editions, yet all through the summer's of 2002 and 2003 there were people complaining about their near meltdowns in high heat and traffic.
I'm sorry Jon, but to me these people that have had issues and those that are just concerned with it now can't all be sniffing vapors, there is a problem with the fan when the bike is standing still.
I don't care if you fill your system with "Pink" or 'limeade", that oem fan is not going to keep the bike down to reasonable temperatures for long when you meet the right conditions.
Now I'm not saying that the superhawk fan blade is the ultimate solution to having the VFR keep it's cool.
I'm just saying that it does a damn sight better than the crap design from Honda. That it is Honda part (so its not some unobtainium part from some rocket manufacturer). Its simple to try and in the end very cost effective.
I haven't heard of anyone saying that it did not work better than the stock fan.
I had the same problem with my RC51, cooking off in the heat from the day I got it. God I wish the solution had been as easy as just swapping a couple of VTR fan blades. In the end, I flipped the stock fan blades over with a little work and reversed the motors, all to try and get close to an efficient pusher fan operation. Even with all the flaws (not a pusher fan blade design, not ducted, drawing air from around the motor and header, less efficient as a pusher over a tractor fan, etc..), again the fans work, the bike doesn't overheat anymore and flatten the battery. I know that when time and funds allow I'll be back to this with carbon fiber ducts, spal fans and some sort of variable fan control system. Come to think of it I'll probably be at the VFR first with these things or at least some other heat management measures.
Honda did us a major dis-service with both these bikes as neither one has an excess of cooling "power" built into it.
Both want to run hot as per external laws, but they certainly need some system improvements.
Jon, I'd bet you that if you tried the superhawk fan, you would suddenly realize that you don't need the control module to switch off the fan when you get moving.
I do believe that with the VTR fan, you've seen improvement in your case. I believe the improvement is slow moving stop and go traffic, not stoplight to stoplight. As far as the VTR fan cooling better when stopped, I'm not buying it. There have been members who have made the switch and posted that while their stop and go traffic temps went down, their stop light temps increased.
We all agree, a pusher fan is only 80% efficient when compared to a puller fan. We also agree that the air in the tunnel is hotter than the air on the side of the bike, I measured a 67 degree difference earlier in this thread. Granted, once the fan starts the temp will come down, but it will never be as cold as the 'fresh' air on the side of the bike. When the bike is stopped, we can safely say the stock fan is the better choice.
We all agree that no fan helps above 30 mph(ish). We all agree that running a fan against the flow of air across a radiator is a bad thing.
I do see a big benefit to the VTR fan swap in the 10-30mph window. I believe, however, a large portion of the benefit is not so much that the VTR fan itself is aiding in cooling, but that you've removed the stock fan. Once the bike is in motion, the stock fan is fighting air flow caused by bike movement. Replacing the stock fan with the VTR fan just stops that fight.
The biggest reason for these bikes running hot, in most cases, is not the fan, but the A/F mixture. From the factory, they are so lean that they just make a ton of heat. Currently, I'm not running a fan control of any kind or a VTR fan, and my bike has no heat problems. Ever since I installed my PCV w/autotune, I've gotten rid of those lean spots and along with those went the high temps. I've found during the last couple rides, that I actually need to change my mapping a little because I'm having a problem with not enough heat. I couldn't get it over 172 on the freeway last Saturday.
All this fan talk is really just a band aid for a lean mixture (and too much/wrong antifreeze). If you really want to fix the problem, fix the mixture. Once you fix the mixture, you should be able to run which ever fan makes you feel better.
