6th Gen Custom Exhaust
82 posts Started 20 Mar 2009 Last recovered post 26 Dec 2009 Wayback Machine snapshot 16 Jun 2012
So... I meant to post this picture a while ago but I forgot.  Sorting through my pictures today I found this one, and thought I would show off what the final version looked like. Since then, I added onto the ends of the heat shields, painted them black, and polished the lip around the exhaust opening.  I was contemplating creating version 2.0 this winter, but I just picked up a project bike which will more than likely consume all my free time.   I have been unsuccessfully trying to sell the bike pictured, so I have it hooked up to a battery tender until this spring when I'll try again to sell it either with the custom or stock exhaust.  I did take some video footage of the bike on Angeles Crest Highway about 8 months ago, but I never edited it together... I'd like to finish that, but I don't see that happening in the near future .   So I didn't do any editing, I just pasted three clips together but that's better than nothing right?   Here is the original post Quote When I was up in Monterey last summer over the MotoGP weekend I saw an exhaust on another bike that I thought would look sweet on a VFR.  It looked easy enough for me to fabricate but I wanted to do it in stainless, and since I sold my fabrication shop and all the equipment in it I no longer had a TIG welder.  I looked around for a little to try and find someone to fabricate it for me, but I'm just too particular a fabricator and I've been doing it for nearly 18 years so I really wanted to handle the work myself. I believe I mentioned to a few guys at SGVRidgeRunners farewell ride that I had something in the works and now almost a year later I can finally begin!!   Here's a picture of the welder and everything that came with it.  I still need to get a regulator, some stainless rod, and tungsten.  I'll be posting more pictures of the progress in the coming weeks and months to follow. Miller Syncrowave 250
Nice, would like to have one of those one of these days. What is your electrical solution or are you not doing this at home?
And, when can you start mfg on some vf1000r 4-1 exhausts?   :+1:
About 75% of my tools are at work already so that's where I'll be doing this and the power requirements are 230V single phase 110amps.  Theoretically I could wire this up at home but it will be much easier at work.
As for the VF1000R...   :+1:
Good luck to you, I am very jealous! Not only do I not have a TIG yet, but I'm not sure my wiring setup at my home is stout enough to run one either!
So far, I've still been able to sneak the small stuff through at work...
[image: View Post]JTG, on Mar 19 2009, 07:58 PM, said:
About 75% of my tools are at work already so that's where I'll be doing this and the power requirements are 230V single phase 110amps. 110 amps?!?   :blink:
To do that at home you would have to add a whole new fuse panel!   :cool:
Good thing you have some place at work to do it.   :goofy:
To do that at home you would have to add a whole new fuse panel!   :ph34r:
Good thing you have some place at work to do it.   :491:
It helps to have an electrical contractor in the family   :biggrin:
I supply the materials, the beer, the meat and potatos, then he takes care of the rest.  I just have to keep the green stuff off his plate, like salads and broccoli otherwise it's a deal breaker   :goofy:
As a teaser, here are the baffles that I just finished for the new exhaust   :laugh:
Don't ask me why one tube is perforated and the other isn't, I'm just making this up as I go along :biggrin:   I wish there was a way to test the sound before I weld everything together, but I'm just going to cross my fingers and hope I like how it sounds when it's done...
Exhaust Baffles
I also made a cart for my new (to me) welder.  It still needs to get painted and a plywood shelf under the water cooler but I like how it turned out.
Welder Cart
Welder Cart
Nice set-up! Keep posting pictures and updates on your project. Thanks, JD
I think a cart is probably the first thing every new weld machine owner makes, and they always seem to be a little different.
I built a workbench with mine, and stuck the welder underneath.
I'm jealous. All I seem to want to do right now is exactly what your doing. Unfortunately I don't have the funds for a welder so I fabricated my own exhaust can baffle and end cap with my cheap oxy/actly. Little ugly but it worked :fing02: . I look forward to seeing your finished product.
Water cooled tig torch is the best way to go. :blink:   Nice and light, easy to move around. NEVER get hot like an air cooled one welding alum. LOL Like your cart.   :laugh:   Got my eye on a new leftover Lincoln 225 at the local welding supply. Trying to talk the wife into it is HARD!   :blink:
[image: View Post]RustyA, on Apr 6 2009, 06:43 PM, said:
Water cooled tig torch is the best way to go. :cool:   Nice and light, easy to move around. NEVER get hot like an air cooled one welding alum. LOL Like your cart.   :fing02:   Got my eye on a new leftover Lincoln 225 at the local welding supply. Trying to talk the wife into it is HARD!   :dry:
I taught my wife how to TIG a few years ago and she really likes it! So it wasn't too hard to sell her on buying one :cool:
Just tell her that you can make some extra money with it and then you can afford to take that vacation she's always wanted to Italy, or Hawaii, or where ever :cool:
i am guessing this is for a 6th gen vfr. I was thinking of picking up a set of stock pipes. Gut them and make hi-po exhaust internals for the cases. It looks like you are doing pretty much the same thing.
Sort of, except I'm also changing the shape of the cans, the end caps and the heat shields so they'll look nothing like the stock cans when I'm done   :cool:   There will be more pictures of the progress soon!
Yes I should have specified that this is for a 6th Gen, but I'll be interested to see what you come up with for your version   :cool:
Water cooled tig torch is the best way to go. :biggrin:   Nice and light, easy to move around. NEVER get hot like an air cooled one welding alum. LOL Like your cart.   :biggrin:   Got my eye on a new leftover Lincoln 225 at the local welding supply. Trying to talk the wife into it is HARD!   :laugh:
I taught my wife how to TIG a few years ago and she really likes it! So it wasn't too hard to sell her on buying one :biggrin:
Just tell her that you can make some extra money with it and then you can afford to take that vacation she's always wanted to Italy, or Hawaii, or where ever :goofy:
I tried to talk the wife into a couple of my projects. No dice. Now I just take what I need welded to work. I have everything there. One of my duties at work is I'm in charge of the welding maintenance. When ever I need a new toy. I try to fit it in the buget.   :biggrin:
So I made some progress this weekend   :+1:
Here is the exhaust with the bottoms of the cans cut off and the baffles plug welded in place.  You probably can't tell form the pictures but I've also cut off about 3" from the length.
Here are some pictures of the endcaps, with one finished and the other in progress.
And finally here are the end caps welded onto the cans.  I still have a lot to do, but next I'm going to pack the area around the baffles with fiberglass and then cut and weld the sheet metal in place for the bottom of the cans.
I'm still working out the design for the heat shields, but hopefully I'll be able to get to that in the next few weeks   :cool:
Looks good Jon, can't wait to see the finished product!
Here's another picture with the cans all welded together, sorry for the poor quality I only had my cell phone camera this time.  I trimmed the ends and the bottoms of the stock heat shields but they're just resting on top of the cans, I haven't worked out the attachment yet this is just to show their rough position.  Originally I had intended to get a little more creative with the heat shields but I'm quickly running out of interest in working on this project and just want to get it on the bike   :biggrin:
What I can say at this point is that working with the stock cans is a royal pain in the butt, and given a chance I would NOT do this again.  I'm pleased with the result so far but if I do anything like this again I will build the cans completely from scratch.
Enjoy the picture for now and I'm hoping to have this completely wrapped up in the next couple weeks!
Almost done!
Almost done!
Those are looking sweet !!
Those pipes look pretty damm good.  You've gotta put an audio clip of them on here once their back on the bike. :biggrin:
Great looking pipes. Maybe for the heat shields you could use the originals to make moulds and lay some CF ones up?
Thanks for all the compliments, I will definitely work on an audio clip once I have the pipes on the bike   :fing02:
That is a VERY good idea... I've never worked with carbon fiber before but I'm sure I could figure it out... hmm, I'll have to start looking into that but for the moment I think I'll still mount up the existing heat shields.  Thanks for the suggestion   :dry:
AWwwwwwwwwww! You bastard! I'm jealous, like you wouldn't believe, now!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Those look awesome! 10 bucks says they sound just EVIL!
Wanna do mine, next? LOL.
definitely watching this
they look excellent. cant wait to see it mounted
I have been watching the development as well and I have to say that those look SICK!  I can't wait to see them on and have a sound clip!  Great Job!  Anxiously waiting!
That is a VERY good idea... I've never worked with carbon fiber before but I'm sure I could figure it out... hmm, I'll have to start looking into that but for the moment I think I'll still mount up the existing heat shields. Thanks for the suggestion :cool:
Travis, aka,...Riv, "The Travi", MR. A$-HAT. is your man for CF info :biggrin:
You could probably sell CF heat shields to people who like their stock systems but still want a bit of bling.
Are they on yet, are they on yet, are they on yet?
Just teasing.
No but really.
:dry:
Just teasing.
No but really.
:biggrin:
Believe me, I really want to see them on the bike :biggrin: .  I'm hoping to attach the heat shields tomorrow night, maybe get them on the bike Thursday night, and then Friday morning I'm headed out to piss off all the neighbors   :fing02:   If all goes well I may even have a video by this weekend   :cool:
For all you folks that want to get into TIG welding, Miller recently introduced a new "Tig Welder for Dummies".......The Diversion 165. I bought on to replace my Syncorwave 180SD which was simply too big and used too much curent for my shop wiring. I couldn't be more plreased with the diversion. A great, easy to use, cheap ($1200), tig welder. Does Aluminum and Stainless steel extremely well.
Here's the cart I bought from Harbor Freight tools and modified..............
Those are cool little TIG welders, takes all the guesswork out which would be great for beginners.  It also looks more portable than the lump that I bought   :fing02:
Alrightee then, it's done!!... sort of... let me explain, no that would take too long, let me sum up; Humperdink is to marry Buttercup in little less than half hour... uh wrong post sorry   :blush:
Anyway, it sounds great :musik20: I'm not sure yet if it's too loud for me, but I'll give it a few weeks before making that decision.
The fit and finish is ok, I could have done better but I got a little impatient with this.  I may take it off again when I have time and try to clean it up a little.
As for the looks... meh... I think they're a little too small the proportions don't quite work for me, and I'm not crazy about how the heat shields worked out.  What I'm trying to say is that there will be probably be a version 2.0 in 6 months or so   :cool:
I think my favorite part of the whole project was cutting through the label on the inside of the cans that says something about emissions, noise regulations, blah, blah, BRRAAAAHHHKKKEEKDK!!! That's the sound of the sawzall hacking the pipes in half   :fing02:
The welder worked great, I didn't have any problems with it short of me being a little out of practice and sticking the welding rod to the tungsten a few times :mad:   I also forgot to ground the piece a couple times and I had the welder set for High Frequency start instead of using the lift-arc feature.  For those of you that don't TIG weld, with the welder set on high frequency if the piece isn't grounded the current will attempt to find the next best thing to a ground which is usually you! :blink:   It's basically like being electrocuted and it F'in HURTS!!! :mad:
At any rate, here's a picture that I took with my phone at work today.  I will get out over the weekend and take some more pictures and a video.  Oh, and I never did mention what exhaust inspired me, it was on a Ducati 1098 but there were no labels so it may have been custom, but because of that I've been referring to this project as my Duconda 808 exhaust... I know it's cheesy, but it was either that or Hondati   :goofy:
Duconda 808 Exhaust
What is the complaint, with the shields? I'll Trade you for a stock set.? ? ?--????????? .02, would have shot for a 2.0" dia, scaled baffle, for each side, and rolled in some grill work, on the inside of the end cap.
(In my imaginary world). LOL. Wheres that damn sound clip? LOL.
I LOVE IT!!
Lately I am to lazy to comment because I have to login....but I had to for this....
LOVE THEM   :musik20:    :fing02:
My only complaint about the 6'th gen, is the exhaust.....Honda should have made the OEM like that!!
I don't care what you say,,,, those are bad ass.  They are not too short and not too long.  Where's the sound clip?     From the looks of things, I bet they roar.
So since these are the proto types,,,, when are you going into a full production run,,,, "JTG Cans" Has a nice ring to it. :fing02:
Like the pipes, but your shiny RF-1000 teetering on your seat is making me nervous. :fing02:
Love them, do mine please???
Very nice! I like the length, but would be tempted to bring the heat shields closer to the cans or roll the rear facing edges down a bit to get rid of that gap look.
The Duc exhaust you were referencing is made by Zard, european company, if I'm not mistaken...
[image: View Post]JTG, on May 7 2009, 02:42 AM, said:
I think they're a little too small the proportions don't quite work for me, I think they would look better being a tiny bit wider, but still they look great the way they are now. :fing02:
Man - they look "les testicles de chien" nice job!
I think Honda needs to take this as their cue.
Thanks for all the compliments guys!  I think I'm starting to like them more, it's just that what I had pictured in my head was slightly different from what I actually got so I think I was a little disappointed.  In the meantime I'm going to work on some drawings of version 2.0.  I like the suggestions from V4 Rosso and SEBSPEED about rolling in the edges of the heat shields and making the cans a little wider to fill in under the tail light.  I'll see what I can do   :laugh:
The video and audio clip and some more pictures will be coming this weekend... wait for it... :cool:
As for a production run... I'm not so sure about that, I owned a metal fabrication shop for 6 years working mostly in stainless and there are many good reasons I no longer have that shop.  Trying to manufacture anything in the U.S. on a small scale is extremely difficult, especially in a state like California which is determined to put all small company's out of business.  I started this as a fun project for myself not with the intent of producing quantities to sell, but I will at least look into it and see what it would cost to produce a small run of JTG Pipes.  On the other hand if anyone else out there has the ability and the interest in making these, by all means take my design and run with it you have my blessing!   :biggrin:
Oh and yes, I think that Zard exhaust is what I saw on the Ducati.
[image: View Post]JTG, on May 7 2009, 08:08 AM, said:
As for a production run... I'm not so sure about that, I owned a metal fabrication shop for 6 years working mostly in stainless and there are many good reasons I no longer have that shop.  Trying to manufacture anything in the U.S. on a small scale is extremely difficult, especially in a state like California which is determined to put all small company's out of business.  I started this as a fun project for myself not with the intent of producing quantities to sell, but I will at least look into it and see what it would cost to produce a small run of JTG Pipes.  On the other hand if anyone else out there has the ability and the interest in making these, by all means take my design and run with it you have my blessing!   :biggrin: You could sign me up for a set of those SHOULD you do a limited run.  Super hot!  You should have weighed them from before to after to see how much weight you shaved off.   :laugh:
And please don't bash me too hard for this but is there an option to pack them with some noise reducing material?  I love the VFR's growl without a doubt but too loud ends up giving me a headache and attracts the attention of all the LEO's...
You made two, right?  heh
[image: View Post]JayWalker, on May 6 2009, 06:49 PM, said:
Like the pipes, but your shiny RF-1000 teetering on your seat is making me nervous. :comp13:
Meh, I've been doing that for years and the only time I dropped my helmet was when I hung it from one of my mirrors :huh:
[image: View Post]vanion2, on May 7 2009, 07:24 AM, said:
You could sign me up for a set of those SHOULD you do a limited run.  Super hot!  You should have weighed them from before to after to see how much weight you shaved off.   :comp13:
I used the very accurate scale of one exhaust in each hand, and I'd have to say I lost between 5 to 10 lbs give or take 5 to 10 lbs   :blink: I have no idea really but it's definitely lighter   :huh:
And it wouldn't be very hard to make these a little quieter, although once you're at freeway speed the only thing you hear is wind noise :wheel: However around town it is quite apparent that things have become more melodious   :musik20:
Just out of curiosity I have two questions;
1) If these were the same price as a set of Staintunes which would you choose?
2) If these were a significant amount more than a set of Staintunes which would you choose?
And to answer the third question for you, it wouldn't be worth making these for less than a set of Staintunes...  Don't get any ideas though, I'm still about 90% sure I won't produce these for sale.
that looks fantastic! i think this is one of only a handful of mods on the site that really looks awesome on the bike.
if there was a subtle modification to next model year this would fit right in.
would you post dimensions?  mini plans or the like ? i have microns and though i do love the sound ...they are 1. too quiet   b.  too long  and 3.  they don't quite fit the flow of the rear of the bike
I now love them as I love Corvettes, Ferrari's and Ducati's....from a far
It might take me a few weeks to get to this, but I would be glad to   :laugh:   I've been kind of hoping that someone else would give this a try.
+1.  I can absolutely say for certain I love these.  But would never be able to pay what it would be worth you to make them.
And to answer the third question for you, it wouldn't be worth making these for less than a set of Staintunes...  Don't get any ideas though, I'm still about 90% sure I won't produce these for sale. Well, the only reason I don't have Staintunes is because I don't like they way they are shaped.  If you "decided" to make a finished set of these for that price I might be mighty tempted to say yes.  They are totally unique (except for your set) and there for would be worth the price (just as long as you quiet them down just a tad).  http://www.vfrdiscussion.com/forum/public/style_emoticons/default/wink.gif
I don't know the first thing about welding so grabbing a set of your plans would be pretty useless to me unless I can find a local welder willing to do it.   :laugh:
My son has the Zard exhaust on his 1098, they are a big improvement over the stock Duc cans. The big advantage is that the carbon fiber is cool to the touch, even right after turning off the engine.
Looking at the way they attach to the Ducati exhaust, I believe they could be adapted to a Gen 6.
That would be sweet...but I am afraid to ask how much that set would run.   :laugh:
Never mind....$1200 for something that can be found on Ducatis vs $1000 custom built, I think I would go custom.   http://www.vfrdiscus...tyle_emoticons/default/wink.gif
Edit:  But it would be a tough choice.  Can you take some measurements for me?
[image: View Post]JTG, on May 6 2009, 07:42 PM, said:
Alrightee then, it's done!!... sort of... let me explain, no that would take too long, let me sum up; Humperdink is to marry Buttercup in little less than half hour... uh wrong post sorry   :laugh:
Sweet! a Princess Bride reference in a thread that I had been follwoing because it was already so freakin cool.
It looks great for an exhaust that has "been mostly dead all day"...
Wow, looks absolutely awesome!
The CF heat sheilds are a very cool idea.
I might be in for a set too, if you were so inclined to make a limited edition production run.
I'm primarily after weight savings, and haven't been able to make a decision on which aftermarket exhaust/headers to go with.
Mac
My son paid $950 for the Zard exhaust, I will take a tape measure to it, and post them here.
[image: View Post]stic3, on May 8 2009, 11:59 AM, said:
My son paid $950 for the Zard exhaust, I will take a tape measure to it, and post them here. :fing02:   And where did he get them for that price?  http://www.vfrdiscussion.com/forum/public/style_emoticons/default/wink.gif
SOMEBODY DO THAT!!!! I WANT TO SEE THIS   :blink:    It would be kind of an expensive venture by the time you had a custom midpipe made but I bet this would look great!!
Wickedly cool!
An enthusiastic :wheel:    :fing02:    !!!!!!
Quick update;  My wife and I went out on ACH and took some video so you can see and hear the exhaust in action, but I'm still editing it together.  I'm also working on modifying the ends of the heat shields, and there will be a different finish when I'm all done.
In case you haven't read my other thread, I'm selling the bike because my first child is on the way!! However I really wanted to finish this project just for my own satisfaction   :wheel:
By the way, I'm really loving the sound of these pipes now that I've had them on for a while   :fing02:
Can't wait to "see" it in action.   :wheel:
So I still haven't finished the stinkin' video   :blink:
But on the upside I've started working on the tapered ends for the heat shields   :beer:   This is just a rough cut, the ends need to be trimmed to match up with the rest of the heat shield.
Heat shield end caps
We have friends staying with us for a week, so maybe next weekend I'll get these mounted.  I held them in place and I think it will really help the looks of these pipes   :goofy:
This should make Timmy happy but I'm considering finishing the cans in either a flat or semi gloss black   :ph34r:
In the meantime I'll try to get back to work on the video.
Cheers,
Jon
I got the pipes off the bike to do some more work, and weighed them while I was at it.
In this corner weighing in at a svelte 11 lbs is... my exhaust...
So... I meant to post this picture a while ago but I forgot   Sorting through my pictures today I found this one, and thought I would show off what the final version looked like. Here is the original post http://www.vfrdiscus...showtopic=49826 Since then, I added onto the ends of the heat shields, painted them black, and polished the lip around the exhaust opening.  I was contemplating creating version 2.0 this winter, but I just picked up a project bike which will more than likely consume all my free time.   I have been unsuccessfully trying to sell the bike pictured, so I have it hooked up to a battery tender until this spring when I'll try again to sell it either with the custom or stock exhaust.  I did take some video footage of the bike on Angeles Crest Highway about 8 months ago, but I never edited it together... I'd like to finish that, but I don't see that happening in the near future .   So I didn't do any editing, I just pasted three clips together but that's better than nothing right?
That looks great :fing02:
I don't suppose you'd be able to post a sound file?
I like it!  Very hi-tech looking.
was wondering what ever came of this
i really love this exhaust
I think instead of trying to edit a video together, I'll just post one of the clips.  I'll try to get that done tonight.  No promises though   :schla15:
nice and compact ...very sharp   :schla15:
Nicely done Jon!   :schla15:
Added video in first post   :goofy:
Sounds AWESOME!!!  http://www.vfrdiscussion.com/forum/public/style_emoticons/default/smile.gif
:fing02:
[image: View Post]JTG, on 22 December 2009 - 01:29 AM, said:
Added video in first post   :fing02:
Good lord.  Sounds like half a NASCAR racer going around Talladega.  LURV it.   :biggrin:
Nice work and great fab job, they look great!   :goofy:
Now if you can just cut the DB's in half they would be perfect!   :goofy:
End of thread · 82 posts recovered Wayback Machine snapshot 16 Jun 2012
