How did you guys who have blazed this trail before me rig/connect/etc the three pistons for the rear brake so all three pistons work with one brake line? Does someone make a piece to hook the two banjo points together or did you have something custom made? If so, by who?
Delinking brakes for RC-51 fork install
11 posts Started 15 Feb 2010 Last recovered post 4 Mar 2010 Wayback Machine snapshot 23 Mar 2010
Someone did this by making a brake line as short as possible without kinking worries, and looping it on the caliper connecting both banjo bolts.
Tok Tokkie trusted his welding/brazing skills enough to make a solid metal double-ended banjo of the correct length to bridge both points.
Still others I have seen have drilled the passages internally inside the caliper to connect all 3 piston bores. You then would put a "dummy" bolt and washer to block off the unused port on the outside of the caliper.
I'm sure you saw how I handled it with 2 lines. It was the easiest/cheapest solution, so I thought.
from the PCV there will be a double banjo bolt, just use that on the 2 lines from the rear brake caliper to the rear master cylinder.
Some reckon the feel from the rear is too soft and replace it, but I found it to be fine. I can dig up some pix if you need them.
Put the PCV and the hard lines in the cupboard to gather dust after you've flushed thme of brake fluid :)
Pete, you have a PM. :biggrin:
[image: View Post]AB-Oz, on 14 February 2010 - 10:39 PM, said:
from the PCV there will be a double banjo bolt, just use that on the 2 lines from the rear brake caliper to the rear master cylinder.Some reckon the feel from the rear is too soft and replace it, but I found it to be fine. I can dig up some pix if you need them.
Ab-Oz:
A pic or two would certainly be appreciated. As I was telling Russ in a PM, stripping the bike of the linked hoses/pipes/tubing/connector/etc/etc seems like the most time consuming portion of the fork swap.
Pete
[image: View Post]Veefer800Canuck, on 14 February 2010 - 10:38 PM, said:
I'm sure you saw how I handled it with 2 lines. It was the easiest/cheapest solution, so I thought.Got a pic my Canadian friend?
I can't see the pics, because they are blocked here at work, but it should be in post #7 here:
http://www.vfrdiscus..._1&#entry336318
Lemme know if that does it for you.
Thanks a million Veefer! Just the reference post I was looking for.
here's the pic of the rear double banjo:
http://www.vfrdiscussion.com/forum/uploads/1266061317/gallery_1129_237_49362.jpg
IMG_3971.jpg double banjo bolt
And when you blead the rear brakes take the caliper off and place it on the top of the disc:
http://www.vfrdiscussion.com/forum/uploads/1266061317/gallery_1129_237_11123.jpg
IMG_3973.jpg correct way to bleed rear
It was Mello Dude who had a short braided line made to connect the 2 banjo bolts on the rear
Mello Dude delink
I like this plus then you could do the "fish the new stainless brake line through the swingarm �bermod".
Brake line through swingarm
Bren
Mello Dude delink
Bren
on mine i didn't bother to connect them , i just left the middle piston unused and it works ok , i have heard that you can replace the master cylinder with a CBR600 itme and that gives back the braking on just 2 pistons
End of thread · 11 posts recovered Wayback Machine snapshot 23 Mar 2010
