Saturday project, give me some feedback
12 posts Started 21 Feb 2010 Last recovered post 27 Feb 2010 Wayback Machine snapshot 16 Jun 2012
After mounting my new (to me) Scorpion exhaust, I didn't feel like my Nelson Rigg soft bags would handle the heat. So after digging through the scrap metal dumpster and a trip to the hardware store, this is what I came up with. I may modify things a little to make them more attractive, but they should do the job. Any input for changes would be appreciated, and sorry about the crappy cell phone pics.
Started off with 4 band clamps, then JB welded a 1/4" bolt to each with an extra nut for a standoff
Then mounted the clamps to the cans, one on each end
Found some scrap aluminum and bent angles in the brake, then painted with BBQ black paint
Mounted them up with a couple acorn nuts
The JB weld says its good for 600 deg, but I may tig weld the bolts to some more band clamps and replace those. Also I may roll some aluminum to the same radius, and make a set that is rounded instead of squared off.
My experience with JB weld, is that it does not stand the test of time, with high temps or vibes.
As I tell them at work, you can have good, fast, or cheap... pick two.
Mac
I've been pondering this myself for a set of Coretech sport saddlebags, obryap.  Very nice solution to a vexing 6th gen soft luggage issue.   :comp13:
I threw the bags on a ran it up to temp. The bags do not contact the exaust anymore, hopefully no burns. I'm going to get some more band clamps & weld the bolts on them, but this serves the purpose as a template to work off of. I'm also going to make a set out of stainless steel to see if I like the polished look better than the black. Looking forward to more input for improvements.
[quote name='obryap' date='21 February 2010 - 06:14 PM' timestamp='1266794099' post='684838']
I think they look really nice although I'm surprised you need them.  I have Leo Vince Carbon Fiber cans on my 6th gen and they don't get very hot--definitely not hot enough to melt bags...  Is it because I have CF instead of Stainless???  Anyway...again they look nice and the polished look may be even better???
Looks pretty mice. Flat black and all.
I'd see if I could get them made out of a composite instead of stainless. Stainless will probably hold heat instead of blocking it. Then again, I doubt it's going to get hot enough either way. Put some of that aluminum reflective tape on the exhaust side and that should help a bit.
So what do you think of your new exhaust?
Looks nice, simple and effective :fing02:
Maybe put some (glassfibre) cloth between the clamps and the exhaust against scratches and it's an even better heat insulator.
I thought of trying to cut some out of carbon fiber sheet, but I am not sure how to form this material, but I agree it would be better
So far I like the growl of the Scorpions, not as loud as I thought they would be, just a nice deep tone.
Rubber mount the clasp - will avoid any scratches on the pipes.
I finally got some free time to cut and bend a set out of stainless. After mounting them up, I like these much better than the black, from a distance it looks like the factory exhaust. Just need to get some stainless nuts to swap out the old black ones.
End of thread · 12 posts recovered Wayback Machine snapshot 16 Jun 2012
