I just noticed an odd clunking/clicking in my front end. Lock to lock I can feel no notches or tight points, very smooth and linear effort to turn the bars left to right.
If I hold on the brake and push down to collapse the forks momentarily or when I'm braking hard enough to get a bit of weight transfer to the front end, I feel and hear it. Once on compression and again on the rebound.
Also, when taking off I can hear and feel a clicking thunking, usually about three times or so before it goes away. I'm thinking I need to inspect my wheel bearings as well as the steering neck.
I'm thinking the proper way to check the front wheel bearings is to prop it up under the forks and push/pull the wheel to see if I have any play. Could something be wrong with the brakes? I took them off their hangers, looked for anything out of the ordinary, and reinstalled everything paying attention to torque them properly. I also disassembled, cleaned them thorougly, and changed the pads about 6 months ago when I removed the forks for servicing.
The bike's got over 30k on the odo so I figure I'm just going to replace the steering bearings anyway.
