Dyno Day - VFR1200F
edit: add me to the list of people who are pissed about Honda's "traction control for dummies". I thought this bike was meant for experienced riders?
[image: View Post]warrenjrose, on 05 August 2010 - 12:40 PM, said:
Note that we were at roughly 135mpg in 4th gear. :smile:Holy shit that is some good mileage :laughing6-hehe:
[image: View Post]gpd211, on 05 August 2010 - 01:44 PM, said:
Holy shit that is some good mileage :laughing6-hehe:Ooops, fixed... Silly fingers...
those are some impressive numbers. my pathetic little 800 has its tail between its legs
Get a TORO CHARGER problem solved
While we were running her through the break in process, I took a video of that pesky exhaust value. You can see it open at the beginning of the video, but with all the noise from the fans and the bike you can't really hear the noise difference.If you say so. :unsure: Sounded to me like you could, both accelerating and decelerating. Whatever; the sound with it at full throttle and the flapper open was OK. :fing02:
Almost as good as a 5th Gen....
:+1:
:biggrin:
Did the "Dyno Truck" have any forced fresh air venting?
If not, at 200+ CFM I bet the oxygen was used up quickly...
[image: View Post]phobe, on 05 August 2010 - 01:06 PM, said:
I thought this bike was meant for experienced riders?You must not have read anything about the VFR1200F, it is the sport tourer that anyone can ride, even a woman.
Now I can see how they did it.
I can't get the front wheel off the ground with the throttle alone on my VFR1200F like I can with my Blackbird.
Quote
it is the sport tourer that anyone can ride, even a woman..I know a few women who could ride circles around every member on this board, and there are several women members of this board too - so just keep that kind of comment to yourself please - it does not represent vfrd.
[image: View Post]Franko!, on 09 August 2010 - 08:10 PM, said:
Did the "Dyno Truck" have any forced fresh air venting?Absolutely... It has some huge fans and is downright windy in there when everything is fired up... Reminds me of some of the server rooms at Sun when I was working in Colorado.
Well, that answers the question as to why Honda put such a small gas tank on it! :goofy:
http://vfr1200fa.blo...8/dyno-run.html
fwiw my bike has the flapper disconnected.
Why?
I had my VFR on the dyno today.... but I had the torque recorded as well.http://vfr1200fa.blo...8/dyno-run.html
Wow!!! I really appreciate that... It looks like we got very similar power out of our bikes...
It's VERY interesting to note, that the torque curve actually goes DOWN from 3K to 5.5K...
As far as fooling the bike into thinking that it's in a higher gear all the time, there have been TRE's available for Suzuki's for a long time. Suzuki's use a timing retard system for a variety of reasons in the lower gears. The TRE is a Timing Retard Eliminator that sends a signal to the ECU telling it that it's in a higher gear all the time.
http://www.ivansperf...cts.com/tre.htm
Thank you very much for sharing the dynographs.
To do for me :
get rid of the speed limiter of 250 km/h ( I get blown away by GSXR600 bikes :(
get rid of the power limitations in 1st and second gear.
Can some tell how the speed limiter works ? is it initated bij the 6th gear signal or by the speed / rev signal ??
Thanks in advance !!
[image: View Post]Dutchgixxer, on 26 August 2010 - 07:19 AM, said:
get rid of the speed limiter of 250 km/h ( I get blown away by GSXR600 bikes :(Hi Kerst,
I read about some politicians wanting to increase the speed limit but surely not over 250?
:biggrin:
[image: View Post]HispanicSlammer, on 10 August 2010 - 12:06 AM, said:
Quote
That was how the bike was presented at the International Motorcycle show, they said "Even a woman could ride it"
The women around this board know I am not directing that statement att them.
You, a man worrying about it leads me to think differrently about you.
Quote
Someone smarter than I once stated: "If you find yourself standing in a deep hole, perhaps you should stop digging."
Just a thought.......
Quote
I know a few women who could ride circles around me and you, that is for sure but, I never claimed to be a racer.
[image: View Post]fasterspider, on 26 August 2010 - 01:01 PM, said:
I know a few women who could ride circles around me and you, that is for sure but, I never claimed to be a racer.Point........................................MISSED.
Wonder what is causing the bucket in the torque curve between 4 and 6k rpm in the 3rd and 4th gear runs?
What about 1st gear--does it have torque limiting bucket like the 2nd gear also?
Looks like 9k rpm is the shift point if making a shift chart for maximum acceleration/track purposes. Actually you will never feel the 2nd gear hole because you will be above 6k after the 1-2 shift, and a WOT acceleration run will keep you above 6k rpm in all the gears anyway so it's nothing to worry about (i.e. the 15 hp difference at 5k rpm vs the 135hp at 9k).
You will need some big ones to be riding it at the upper power levels, so, for those about to rock, i salute you...
Beck
95 VFR
Quote
Cool down you guys, the advertisment comment was aimed at seat height and the weight balance of the bike.. :dry:
Anyway, someone will probably come up with an easy way to fill in the hole in the torque curve soon. :comp13:
