[image: View Post]phobe, on 07 September 2010 - 10:53 AM, said:
I've removed the PAIR (or smog pump) from the last 3 Honda sportbikes I've owned, as well as my CRF250X dirtbike. It isn't really a performance-increasing modification but it removes a lot of clutter from the engine compartment, making servicing easier. And it gets rid of the popping on closed throttle. It also makes the bike easier to tune with an air/fuel reading taken at the exhaust. It's a purely vaccuum-run system with no wires so you don't have to worry about any trouble codes from the ECU when you take it out.
I've been waiting for someone to develop a plate to block off the PAIR ports on the 1200 but after studying the parts diagrams I think I've got a solution.
The front cylinder head appears to have the same size and shape of (double-valve) PAIR port that is used on all of the CBRs. The rear cylinder head has 2 smaller PAIR ports which appear to be the same as the ones on the RC-51.
I ordered up a CBR kit and a RC51 kit from Kyle Racing. I might not get around to installing them until winter but I'm 99.99% sure they're the right ones. I'll bump this thread with a link to my blog post when it's all done.
I have only one concern... the 1200 has a 02 sensor at the exhaust collector. I wonder how the computer will interpret the altered oxygen readings? Will it interpret the reduced oxygen in the exhaust as a "rich" condition?
Disabling the PAIR system on VFR800�s is a common practice.
It seems to be a common practice for most bikes with a PAIR system.
Local Honda dealer does it as part of their PD.
Supposedly, the injection of fresh air confuses the O2 sensors.
Did you notice any improvement to low speed throttle response or driveability?
Did you have to increase your idle speed following removal?
I blocked the PAIR system on my VFR800 recently and noticed an improvement in throttle response when transitioning between closed and open throttle at low speeds. Prior to this, negotiating roundabouts and tight corners was a real problem.
Now much improved but not completely.
Others report some improvement as well, others nothing.
Need some more time to be sure the tweak works.
I also read that the O2 injection gets the cat up to temp quicker. I am somewhat concerned that if the cat does not get hot enough, it may in time block up some and become more restrictive. Maybe a good thrashing now and again will fix this issue. An �Italian� tune up I have heard it referred as.
