Remove speed limitation
42 posts Started 15 Oct 2010 Last recovered post 27 Apr 2011 Wayback Machine snapshot 11 May 2011
Ok i think i found the way how to derestrict the speedlimitation of the VFR1200f.
The abs modulator has a output Vsp to both dash and ECU.
Remove Vsp (wire red/green black connector) to the ECU and gone is the limitation. No further concequenses are to be expected. Speed indication on the dash keeps working.
Not tested yet.
Not tested yet.
Please test your theory and let us know.
Flash
Not tested yet.
Just cut the wire?
Not tested yet.
Just cut the wire?
Yes or remove nicely from the black connector nr 27 ( you can put in the wire later back in if you want. So cutting the wire is not needed )
[image: Attached Image: VSP.jpg]
Not tested yet.
Just cut the wire?
[image: Attachment] VSP.jpg
Can this also be the case for the 1200 DCT?
Just opened up my tank and found my ECM. 4 connectors not 3. Any help with this? The schematics you posted were extremely helpful but don't want to cut/pull out the wrong wire I guess they were for the clutch version. :blush:
Looking forward to a GPS screenshot with the top speed...... :fing02:
Best head east across the border... :laughing6-hehe:
Is the stock HP not enough? My K1300s has more HP than I'll ever need on a public road, I cannot imagine the VFR1200 needing more than stock. But what do I know, maybe I am a slow rider...
I've had my VFR up over 250Km/h but no desire and no space here to safely go faster than that. I don't think I'll bother removing the limitation.
Out of curiosity, when does the speed limiter kick in?
[image: Attached File]  Mugello scrnsht 2010.bmp (319.74K)
@251 km/h 266km/h on the dash
[image: Attachment] Mugello scrnsht 2010.bmp
Only 6% speedo error on the new beast eh? My 2004 has about 8-9% error...
Please tell me you don't want to go faster, unless you're on a race track... :blink: :blink: :blink:
c
c
:tour: yess i want to get faster because i was overtaken by a 954 fireblade from 2002.
I figure its not possible to carry out this mod on the DCT as the ECM controls the gearbox as well as the engine. Seeing that is as it is, then, removing this Vsp will also disable the gearbox as the bike will not know what speed you are in and so will not change gears appropriately. :mad:
Just a thought. Any others?
I think its not possible to remove the power restriction in 1 st and secondgear But its no problem to remove the VSP signal from the ecu.
Witch gear is desicided by trottle opening revs mode and selected gear. Should be working.
If not just remove mod.
Any idea if the color coding for the wires might be the same for the FD as the F? Any idea if the Vsp wire also goes to the ECM via the same plug 27? FD version has 4 plugs to the ECM and not 3 like with the F.
Maybe I'm wrong, but I think they are talking about the apparently excessive computer mandated power reduction in the first two gears under certain conditions. It seems to be a half-assed effort at traction control.
Right you are sir!!! As in wrong you are
We are talking about top speed on this thread!!! :fing02:
That's 156 mph for those of us in the states. Wasn't the old gentleman's agreement 300 kph?
But there is a different thread about the first 2 gear power problems.
Yes I can confirm that the wiring is definitely different for the FD version.
No red/green or pink/green wire to the black connector. And like I said there are 4 connectors (a White one in addition to the Black, Grey and Blue connectors). So the question is; Does any one have the wiring schematic for the FD version? :blush:
Sorry i do not have the wiring schematic for the FD version yet. I will post it when my manual arrives.
Thanks :fing02:
Interesting thing though!! Iput my bike up on the center stand, put on the engine, and engaged the gear. With 1st gear engaged and indicated, I revved her up, hoping to get a gear change. But no such thing. Switch to manual mode and sport mode; no gear change, revving to red line. Instead the ABS light started flashing.
Thanks :fing02:
The bike refuses the change gear as long as the front wheel is not rotating. In standard mode it is not possible the dyno the bike.
I have made a holder to mount the front ABS sensor on the rear wheel together with a cable extender. In that way we have dynoed my mates VFR1200FD.
Well done!!! :cheerleader:
Funny, the magazine test all said the speedo had no error and was dead on. my 6th gen was 10%off.
So what is the top speed unrestricted? What revs does it cut out. It has a giant front so anything higher may be aero limited. Maybe they limited it for a a reason.
I think they agrred upon 189mph.
It was 300 kph which equates to 186 mph.
On a certain back road in UT, that was straight for miles, in the middle of the desert, I've taken the VFR1200 up to 156 mph. It went from 154 to 156 fairly slowly so I assumed that was roughly the top speed... Now you're telling me no... Hmmmmm.... Interesting...
Not to beat a dead horse, but why does one need to ride faster than 156mph on a public road?
Who says that it HAS to be a public road? I know that I ride track and others do as well. Furthermore, to the same point that WarrenJose just made, there are stretches out west where you could ride 156mph for ten minutes and possibly not see another human being. On a cross country trip in 2009 I rode my K1200S at 120 mph for almost two solid hours heading through the desert in Nevada and only saw about 3 other drivers the entire time.
Because one can!
Any more news abou how to remove the limitor of VFR1200F DCT?
what else should one do at 3am, when I95 is calling so loud that deaf guy can hear it? [image: Posted Image]
Speed is intoxicating. From the first day I got something with wheels on it, I wanted to see how fast it would go. I don't think I'm alone here. An empty straight road out in the desert in the middle of nowhere seems to be the perfect place to do this.
Ah yes, the top secret test location. It's out there along Avenue X. :happy:
I must admit chasing those 800's up and down the mountains of Oregon and Idaho this last summer I was hoping there would be more low end gunt availible in 1st and 2nd, the high end is not my thing anymore. So I am looking closely at the threads that defeat the limiter on the first 3 gears. I dont need top speed anymore I owned a Busa so thats not my thing anymore. Its great for a 10 minute romp on the loneliest highway in America hwy 50 in Nevada or along the Colorado New Mexico boarder for 185mph but every where else then its just cops impounding your bike. I hardly ever go over 100mph, but I did it all day long on the veefalo crossing the sparce state of Wyoming last summer, would not see a car for 15 minutes, then I was all alone again.
It is 186, but the current VFR wouldn't see that even if it could be de-restricted. Stock gearing brings it to a theoretical top speed of @175 in 6th at redline. (which it will never hit).
Believe it or not, a 6th gen has a higher theoretical top speed of 176mph and a 5th gen is around 170mph.
This is all based on 100% efficiency. No clutch/wheel slip. No drag, no tire growth.
no shit thats it? i figured itd be way higher... but then again it does have a pretty low redline.
i bet with the limiter off, and a slip-on, pc, and filter it would run to the rev limit in 6th.
Hi all,
does anyone know why the limit is 250km/h!?
Ralf
[image: Attached Image: SDC10685.JPG]
You got that right! 2hours=200 miles in west Texas and east New Mexico. Three cars in two hundred miles,not one lizard or bunny rabbit,bird,deer.Plenty of sand and highway.FUN FUN FUN even on a rt.[image: Attached Image: nevada and east 001.JPG]
[image: View Post]Ralfralf, on 28 February 2011 - 02:53 PM, said:
Hi all,
Ralf
Some Honda mechanic on a UK forum said the bike could be come unstable at higher speeds. But thats neither here nor there.
Dutchgixxer is working on a project that could see the end of the limiter :fing02:
For those who are intrested. Thurn Motorsport in Germany sells a module to derestrict the speed limitation on the VFR 1200.
How does it work? (according to Thurn Motorsport)
"Serially the ABS sensor on the rear wheel transmits the speed to the control unit.
This is used to activate the speedo, as well as restricts the maximum velocity (<250 km/h). By the Vmax modul the sensor reads the signals, analyzes it in a microcontroller and transmits modified signals to the control electronics of the motorbike. So the control electronics will not recognize speed as more as 240 km/h."
The fact that it restricts you from doing something is enough for most people to bypass it.
End of thread · 42 posts recovered Wayback Machine snapshot 11 May 2011
