[image: View Post]Veefer800Canuck, on 02 December 2011 - 05:30 AM, said:
[image: View Post]2FAST4U, on 01 December 2011 - 10:47 PM, said:
[image: View Post]Veefer800Canuck, on 01 December 2011 - 08:20 PM, said:
The big bore kits for the vfr750s are 840cc and the ones for 800s are 870cc
TTS makes the piston kits IIRC.
870 cc's seems a little high. Given the original displacement is 781 cc's, you're talking about an increase of over 11%.
Dynamo Humm from Canada used to offer the 870 kit, Not sure who made the pistons, I think it was JE.
It would boost the VFR's output from 100 HP to 120 HP at the rear wheel.
I don't think you can get them anymore.
120 rwhp also seems a little high.
Every dyno chart I've seen for a stock 5th gen. VFR has rwhp between 97-99. At 99 rwhp, that's .12676 hp per cc (using 781 as the denominator).
Applying this ratio to 870 cc's would yield 110 rwhp. If somebody got 120, they must have been running catless headers, aftermarket exhaust cans, a freer flowing air filter and a PC3.
I still say 870 cc's is too much. Big bore kits typically increase displacement about 8%. At 8%, this would bump displacement to 843 cc's.
