I got into a traffic jam with my 93 VFR and my temperature gauge was agout 3/4 of the way up in the temerature range ( it never got into the red) yet the fan never came on I was wondering at what point the fan should come on.
ENGINE TEMPERATURE FAN CUT IN POINT
12 posts Started 25 Jun 2012 Last recovered post 11 Jul 2012 Wayback Machine snapshot 26 Sep 2012
About halfway it should kick on. In my experience with digital readout Honda's its been on at 216F or thereabouts and will turn itself off at 212F. If yours went that high I'd say unless your gauge is faulty, your fan isn't working right.
My 3rd Gen kicks on about slightly above half
The fan should kick in at around 95C (that's somewhere between halfway and three quarter on my VFR's temp gauge. You can check if the fan is still working by bypassing the fan motor switch which is located on the rear left of the radiator. Bypassing is done by shorting the fan motor switch wire to ground.
V4 Rosso, on 26 June 2012 - 10:29 AM, said:
The fan should kick in at around 95C (that's somewhere between halfway and three quarter on my VFR's temp gauge. You can check if the fan is still working by bypassing the fan motor switch which is located on the rear left of the radiator. Bypassing is done by shorting the fan motor switch wire to ground.Thanks for your help I will sort it to ground
miweber929, on 26 June 2012 - 07:57 AM, said:
About halfway it should kick on. In my experience with digital readout Honda's its been on at 216F or thereabouts and will turn itself off at 212F. If yours went that high I'd say unless your gauge is faulty, your fan isn't working right.Thanks for your help
JayJay, on 26 June 2012 - 08:37 AM, said:
My 3rd Gen kicks on about slightly above halfThanks for your help
So . . . does your fan work?
mk2davis, on 27 June 2012 - 01:57 AM, said:
So . . . does your fan work?I have not had a chance to check it out I will probably get to it this weekend
FYI, the switch point is usually marked on the body of the switch, in C.
I shorted the fan to ground and the fan came on I will order a new sender to be safe.
The fan should kick in at around 95C (that's somewhere between halfway and three quarter on my VFR's temp gauge. You can check if the fan is still working by bypassing the fan motor switch which is located on the rear left of the radiator. Bypassing is done by shorting the fan motor switch wire to ground.I shorted ou the fan wire to ground and the fan is working I have ordered a new sender to be safe thanks for your help.
End of thread · 12 posts recovered Wayback Machine snapshot 26 Sep 2012
