Hello once again ! I will try to put this as short as possible. Thank you for your patience =D.
So I recently bought a Honda VFR 750 RC36 1990.. The bikes look is modified (I am finishing what PO started)I think the only related to my"problem" in this could be the 190 rear tire. The engine is as far as I know complete stock (except the wings slip on).
So here is the thing, the bike starts from the first crank,even if it sits for month, no choke needed.Works like the perfectly healthy bike (i noticed a little knock sound while idleing,but I think it is because of too low idle (it is about 800rpm, even lower when hot) or maybe the clutch bearing (since the sound almost completly go away when I engage the clutch). If you rev it a little in neutral the throttle reaction is amazing and fast..There is a issue with temp. gauge.. The gauge never goes up past 1/4 no matter how long the ride is,and it is obvious that the bike is warm (vent/cooler starts while waiting on the traffic lights,huge amounts of hot air coming from a bike, so I am not suspecting a thermostat)
While riding: 2 things I noticed: 1st there are no quiet detonations/backfireing like on "normal bikes with slip on" but while engine braking there pops a LOOOUUUDDD BOOOOMM.. The loudest I heard on the street bike ( and I had a few "poper bikes").
If I accelerate little more aggressively and then let off the throttle the pop would be even louder.
2nd. I was riding it like a granny all the time so I decided to give it a little speed. So I opened the full throttle in 1st, the bike jumped to 10 000rpm and kinda stoped there , shifted it to 2nd opened full throttle bike jumped again very fast to 10 000rpm and just stoped there.. No more power producing from there, it didnt sound like the limiter, it just stand there powerless and couldnt pass that 10 000rpm..
And now the problem: While riding it granny style , low rpms etc for entire gas tank. the best I could get is about 22MPG , or about 60 miles per tank ( while gauge got to red reserve mark i tanked it to full, and got 60 miles to that same gauge position).
While looking at the consumption experience from my other bikes and from other vfr owners this is brutal.. And gas is very expensive here.. The bike is probably running rich ,but there are no hard gas smells or something.
So as this is my first vfr, does this bikes have some known issues (except R/R) to be related with consumption , or should just classic carb detail clean, new air and fuel filter , carb sync, spark plugs do the trick?
Thank you!
