Just when I thought I was done wrenching, the VFR needs a front tire (I have one here already) and apparently clutch plates replacement. 1st gear is fine when ridden hard to redline, but 2nd gear has it surging and slipping and sometimes grabbing pretty much every time @ 10k before I can get to redline. 3rd-6th is OK, and I can even get 2nd to get to redline occasionally if I get there gradually and not when I'm accelerating hard. The 2nd gear thing feels like someone is taking the spark plug wire off and then putting it back on....power up till 10k, then surging and bucking.
I can upshift pretty much from 1st to 6th without touching the clutch lever too by just briefly rolling off the gas.
I've also had 2-3k miles of sorta "slingshotting"....I'm behind a car that I need to get around, so I grab a handful of throttle, never touch the clutch, and it sorta spins up the engine noise for a second without much more forward momentum, then catches and slingshots me ahead. It feels like I was losing traction on ice or something where I was spinning the back tire in a straight line, and then it suddenly gained traction.
If it was a nitro Busa I could say it was lighting up the rear tire with hp. But it's not. It's a 18 year old, 100 hp bike with 55k on it.
I am pretty sure, based on knowing the previous owner, that it's the original clutch plates. 55K on these currently. Granted, I ride this thing hard. Really hard. Pretty much every launch is a hard launch, redline, shift, redline, hard on the gas, etc. I know I should take it easy on the old girl, but it's so much damn fun and sounds so damn good it's hard to resist.
So..sound to you like a new batch of clutch plates (steel and fiber all the way around, or re-use the steel ones?) and new springs as well? Do you recommend OEM, Barnett, EBC, others?
I plan on tearing it down this week to see if I need JUST the fiber plates, or the fiber and the steel plates. Apparently from what I've been told sometimes you can get away with re-using the steel plates if they are not blued from heat and are not warped (tip: lay them on glass or a mirror to check). So, before I order everything, I suppose I need to check into it to see exactly what I need. I'm told to get new springs, but...is that all: What's with this judder spring thing...should I swap them too?
And here's my main question, which concerns how I drive this thing: I gather that the small squares of pad material on each friction plate is what keeps the clutch engaging/disengaging...am I to assume that when a clutch slips, those small pads have worn away, leaving that particular clutch plate smooth (or smoothER that it was when new)? I'm asking b/c I'm wondering if it is normal when a clutch starts to slip that it slips in only one gear like mine is doing in 2nd? I guess I have worry creeping in my mind that the dogs on 2nd gear are gone and I may have to undercut the tranny gears on yet another motorcycle on yet another 2nd gear. I've done this on another bike...kinda a PITA. It seems odd to me (and lends me to think the tranny might need to be undercut) that only 2nd gear slips. And now it seems to be slipping & bucking at a different RPM than before...then: 10k. now: 8k. Again, 1st and 3rd - 6th still pull solidly like a freight train, just 2nd has me a bit worried now....
your thoughts?
4th gen clutch issues
I believe that 2nd gear forks and sychronizers tend to be the ones that wear out first on a bike's gearbox as second gear is where a lot of torque is typically used when accelerating a bike from slow speed or a stop. That kinda relates to clutches slipping most on 2nd gear then.
Beck
95 VFR
[image: View Post]Beck, on 04 September 2012 - 03:41 PM, said:
Slipping on second makes sense, especially if it happens when you are trying to redline the motor.I believe that 2nd gear forks and sychronizers tend to be the ones that wear out first on a bike's gearbox as second gear is where a lot of torque is typically used when accelerating a bike from slow speed or a stop. That kinda relates to clutches slipping most on 2nd gear then.
Beck
95 VFR
So...you're thinking that if it's slipping most in 2nd, then the 2nd gear forks might be gone as well?
If your gentle in 2nd but nail 3rd, what happens?
[image: View Post]mk2davis, on 04 September 2012 - 05:31 PM, said:
If your gentle in 2nd but nail 3rd, what happens?Nothing but raw, unadulterated, earth-shaking, VFR power.
[image: View Post]GadiantonRob, on 04 September 2012 - 05:45 PM, said:
Mine had same issue. Replace clutch plates and get stiffer springs. Problem fixed.Same issue on the same bike? Cool. You went with the OEM schtuff for replacement?
I had bad experiences with EBC too, but with their brake pads which ruined (quickly glazed and deeply grooved) the front disc on my Hawk back in the 90's. Maybe their clutches are wonky too...Yup. That or Vesrah plates. Guy who did the work (knowledgeable fellow, I may add) said stay away from EBC, .......
Beck
95 VFR
So now, I don't know what to think. I guess I should take the clutch pack out this weekend and see if anything looks out of the ordinary.
So....when the fiber ones are done, do they get completely smooth?
I have the OEM service manual, but didn't see any reference to tell if any of the plates are within spec or not. Any of you guys know if this info exists?
Everything looks good and clean in there. No obvious marks or scrapes or anything like that.
.. well.. not thinking it all through anyway..
when you get the bike rolling your bike now slips a little.. you may not notice it..
you shift to second.. which is a BIG difference in power transfer .. so you notice..
now your bike is moving.. and you dont notice it too much as you shift higher, because the bike is moving
if it was your shift fork, it would drop out of gear.. and feel very sloppy until it got to that point.
in anycase.. yes.. there is a minimum friction plate thickness.
and NO its not wearing all the material off. :tongue:
yes it IS in the manual... ditto for the drive plates.
i dont have a 5th gen manual but i know its in there.. :fing02:
Clutch lubrication
[image: Posted Image]Energy Conserving (EC) oil can cause wet clutches to slip
Many motorcycles have a wet clutch, where the clutch plates are immersed in oil. Some oils make the friction plates in the clutch slippery so that the clutch does not engage properly when shifting gears, or the clutch slips when the engine exceeds a certain torquelevel. Some oils contain friction reducing chemicals. A properly specified motorcycle oil will still allow for the appropriate lubrication and cooling of a motorcycle clutch, whilst maintaining 100% of the drive to be transmitted by the clutch, even under arduous operating conditions. One element of the JASO-MA standard is a friction test designed to determine suitability for wet clutch usage.[2][1] An oil that meets JASO-MA is considered appropriate for wet clutch operations. Oils marketed as motorcycle-specific will carry the JASO-MA label.
[edit]References
- ^ a b Motorcycle Four Cycle Gasoline Engine Oil (JASO T 903:2011) Application Manual. JASO Engine Oil Standards Implementation Panel. May 2011.
- ^ a b c d "All About Motor Oil." Mark Lawrence. California Scientific. April 24, 2011. Retrieved March 8, 2012. <http://motorcycleinf....com/Oils1.html >
most people use mobile 1.. but its up to you.. i use baby oil.. made from fresh squeezed babies :goofy:
this not an oil thread. :rolleyes:
now that you see the wear on the basket case carefully file them smooth.
remove as little as possible... but get the them smooth. this WILL make a difference.
in anycase.. order some new friction plates and springs and put them in. :fing02:
personally i use barnett.. the hold up to the crazy monster 150ci HDs very well.
New parts ordered. Will report back when I get them in the bike.
Edited by wgregt, 10 September 2012 - 12:34 AM.
Is there some way this could be electrical making it cut out like this?
If not, I suppose the next step is to yank the engine and replace the gears in the tranny?
You are hearing an audible increase in engine speed which corresponds to the tach reading, yes?
If it were electrical, the engine would slow down, not speed up. As in the ignition cutting out or something.
Yes. It really sounds and acts like I pulled in the clutch lever @ 8-9k while still on the gas, and it revs to redline (and past it if I let it). I don't go any faster, the engine revs to the moon instantly. The whole time I don't touch the clutch lever at all. Only happens in 2nd right now (didn't have the room this am to try out anything above 4th, and I didn't get above about 5k in 4th today.)
If I let off the gas, it'll come back down to 7k or so, and resume riding and pulling like normal. Until I get close to 9k again, and then it repeats. At about 9k it has a stutter (which is me thinking it may be electrical when this happens?), then immediately and easily swoops right to redline, even though I don't move the throttle.
I tried to pull it into 2nd, then keep the shifter up, but all it did was go into 3rd.
When I got home I doubled-checked the tightness of the chain (all good) and noticed the shifter peg, while not rotating on the splined shaft, did have some play in it, so I tightened it up. Will ride tomorrow and see if it made any difference.
Good luck
Gary
I keep all the fluids clean and neat, but it's worth a check. If it's something easy like that I will buy every person on this board a beer. Otherwise, I just rode it into work...and it is damn near unrideable at this point. I can short-shift and only stay in 2nd for a brief time, but otherwise it bucks too much (and too consistently in the same place on tach and in the same gear) to make me think it is anything simple. I can't imagine anything in the reservoir would cause it to be so spot-on in the same place every time, but it's worth a look. I'll report back.
thats important!
as the plates will stick if its not smooth.. and you did soak the new clutch plates.. right?
Long story short: My clutch slipped when the bike was hot. I spoke with Honda dealer to no avail.
New clutch disks (twice), steel plates, springs, clutch hose, rebuilt master and slave.
Problem persisted.
Solution per Moto Grand Prix Racer's suggestion. Took the Master Cylinder apart and cleaned the weep hole out using a needle (previously cleaned with pick). It had gunk blocking the hole which did not alllow the pressure in the line to relase and equalize. When things got hot pressure would build up in the Slave cylinder and the clutch would start to slip. Let it cool and the problem would go away.
Cleaned the hole, problem solved. Now, if I had read this post before spending $300. I paid for college, I guess this learning experience is no different.
BTW, the bike had 18,500 miles at the time.
If anybody is in need a good set of steels w/18k and a set of clutch disks with less than 1000 miles on them, give me a shout (sorry, no springs).
Good luck finding your Gremlin.
I guess you can call me a redline wimp, but I don't think I hit the limiter on my bike more than twice or three times on my 4th gen since I bought it in 1995...... :rolleyes:
Beck
95 VFR
I don't use the rev limiter as a suggestion on when to shift though. I've ridden with guys like that. Too funny. I get out of it before it gets that far, and get into the next gear. But yeah, each gear is usually under load. I'm riding...I'm not in a parade procession. That's what Gold/Old Wings are for.
Didn't even look for one. Didn't want someone else's problems in addition to my own on this one. At least with mine, I know the history of it.
Buying a VFR engine is very unlike buying other motorcycle engines. These things are almost always ridden by older, respectful riders that take care of them.
I got a used 97 engine for $500 shipped to my door, I've done nothing but beat the wheels off of it, and all its done is smile and take it. Of course, if I had a great running engine with only a second gear problem, I would fix it myself.
Also, forget the clutch for up-shifting when you're really trying to get down the road, blip the throttle off and click the gear, your tranny will thank you.
UPDATE: Sorry this update has taken so long, but here's where things are: I dropped the engine, split the cases, and found.....a bent shift fork. Pretty significant scarring/gouging on one side of one fork, and the peg/dog for 2nd gear that moves inside the long slot to engage the gear has been significantly rounded off on one side. So, all together I need about $500 in parts for o-rings, gears, gaskets, etc, which I have ordered, and I'm sending the tranny out to be up & down race cut so this won't happen again. Should have it rolling out of my garage in a week or so if all goes well timing-wise.
Good to know that our initial diagnosis was on the right track. At least the mystery's over and it's getting fixed! :fing02:
Hope you get it back on the road soon!
Beck
95 VFR
I am hoping to buy a 3rd or 4th Gen VFR in a not too distant future and stumbled upon this post ! V4 Fanatic: Your introuctory post was most amusing and I admire you wanting to get to the bottom of the problem without resorting to buying whole engines, (although you might want to think about purchasing engine # 2 to keep expanding your hard earned knowledge !).
I think Seb Speed was the only one that insisted on previous ownership issues. The only thing I would add is that problems relating to second gear are often due to pulling wheelies. As your friend sold it to you so he could go racing with a Porsche he might have been able to do quite a few wheelies in the 10k he rode it. Try asking him sometime when he is off guard !
Regards to All
Glad you found your issue. Just for future reference, where in So.Cal. can you get gears race-cut?So, all together I need about $500 in parts for o-rings, gears, gaskets, etc, which I have ordered, and I'm sending the tranny out to be up & down race cut so this won't happen again.
Cheers,
I know the previous owner quite well, I don't think wheelies were in his nature. As for me, I've kept both wheels on the ground. The whole bent fork is rare on a VFR, I'm sure, so I'll see how the next 55k go on it after this fix.
APE. They up & down race cut my ZX-10 tranny a few years back when they were in Burbank. Now, they are out @ the track in Rosamond, CA. http://www.aperaceparts.com/ They really are the only ones in SoCal doing it at all. Even shops/dealers send all of their customer's tranny's there. They seem to be the only game in town, and the only one on the West Coast that does it that I could find.
Also, Orient Express out on Long Island does it too. I've had one cut there before too on another bike when APE was backed up more than a month.
