I am JUST starting to plan for the Winter Upgrades / Maintenence on the 90 VFR. I have been ordering parts to get me stocked up for the winter
In about 2-3 Weeks (End of October) the bike will be put away for the winter (once the daytime temps drop below 32F/0C) , at that point the fun will begin.
Project#1: Custom Givi Mount One of my plans for next year is to do some longer distance touring, but I have found that the current Softbags really do not cut it, so I wanted to add hard-bags. The Hard bags will provide better security for my belogings when commuting to work, and they will be easier to take on and off than the softbags Since the Mount kits for the 3rd Gen are long out of production, I have two choices, wait for a used set to come up ... Or fab up my own. I chose option#2. I found a Givi Wingrack (NOS) that was a dealer display that I grabbed Cheap. Last week I got a set of Giv E41's at a good price. Today I picked up some mild steel flat bar, round bar and 3/8" tube to fabricate the mounting adaptors/brackets to attach the wingrack to the bike.
Mocked up the Wing Rack - using Zip ties to get an idea of the rough placement so I could get an idea of the clearances and mounting options for the hard-points.
I then attached the Bags to see the actually placement and clearance ... it definately has to move rearward to allow comfortable access to the passenger pegs. But I am excited ... I think it will work well and look pretty good.
I will be interested in this because I am doing the same thing on my Seca2. I'll tell you this from my first try: it isn't easy and if it moves a fraction of a mm on the bench, it will flop all over the place on the road. Detailed photos, please so I can steal your ideas.
I have downloaded the original Givi install instructions to get a good idea of where the bike mounting tabs could/should go. I plan to build the mounting tabs, bend and fab the mounting arms, position the wingrack, tack the arms with the Mig, test fit with the bags, tweak as nessessary, then move the rack and tabs to the bench to do the final Tig welding. Then off to the powder-coater
Well as the weather lately has been crappy (wet) and cold (regularily dipping below freezing) I have thrown in the towel and brought the bike in for the winter and start on the Givi Project. I appoligise for the picture quality, I was using the camera phone, which is not particularily good
Rolled the bike up onto the work stand and striped it down
So I measured up some 1.0 x 0.125 cold-rolled flatbar and made two straight tabs that I could bolt up and lie the tail section up against to figure where the bends need to be to clear the body work
So I had the rear brackets fabbed (Triangulated) so I need to fab the front bracket It was a bit convoluted in terms of fitting it, so I grabbed some copper wire to make a template I could use to bend the flat bar to.
I think I am going to add this arched lower brace (Tabed and bolted inplace) to increase stiffness and stop the weight of the bags roll the bottom of thebags inwardand downward.
Then I decided to work on the stiffening support that helps tie the lower part of the give brackets together Made up a short tab, drilled and bolted it to the existing mount.
I am pretty happy with the latest brackets, they add a huge amount of stiffness to the Givi Rack. There is very little deflection in the bracket itself.
That’s it for now on the Givi mount, I will sand and prep it at some point and then put a couple coats of black paint on it.
